Shelly Wave Pro 3 binding
Hi, any help on getting the binding for Shelly Wave Pro 3? I can’t find it in 4.3.3.
Go here
Thanks, but seems it’s just for Shelly WiFi/Blu devices only.
Not an expert on Shelly, but the “Wave” seems to mean ZWave capable. If so, The device can be added and used with the OH zwave binding.
I’m having the same: the zwave-database does not contain the
Shelly Wave Pro 3 device
the ID is:
0460:0002:0091::10.6
can somebody add the device to the zwave-database ?
See the blog for how you update the ZW DB
Hi @apella12
unfortunately the “registration-page” https://www.opensmarthouse.org/user/register.php ist not available. Could you register the device?
Here is the link: Register but you get no option to create a new device unless your account is upgraded. For now I have created a ticket, attached the xml and waiting for any response.
I saw on another post that the developer and DB maintainer was traveling for his work. Maybe he will review your “write” access tickets this weekend. Note that only one device can be created with identical type:id.version. Lastly check that your access has been approved, without a ticket update. There will be a create device button in the upper right
Device added to the database, waiting for the approval.
Hit the request approval button on the overview
Thanks, missed that
I saw that the Device is “Awaiting review”. Can I help testing?
There isn’t really much of an approval process. When the developer has time, he creates and merges a PR from the ZW DB into a ZW snapshot binding. Unfortunately, it looks like he has been busy traveling with his real job. The last update was May 17, but the one before was a month earlier.
I did write a guide to update current jars with the draft ZW DB XMLs if you are interested (to deal with these delays). I pulled the current XML from the DB for your convenience. The folder will be shelly. Also some have found an easier approach if you have a compressed file app that can edit a jar.
wavepro3_0_0.xml (7.3 KB)
Thanks a lot it works great.
It also made the May 31 DB update, so is in the latest OH5 snapshots, too.
Can we have snapshot for 4.3?
I don’t have any control of that (see my last post here). The only option is to follow the guide above with the xml.
