Hi
I have a Aeotech Wallmote Quad and want to use the switch swipe function in a rule. I’m struggling to find how to extract the direction of the swipe from the wallmote. I have the following rule as a test
rule "quad swipe"
when Item Quad_SceneSwipe1 changed
logInfo("INFO",Quad_SceneSwipe1.state.toString)
where the item is linked to the “Swipe Switch 1” channel. This gives the following in the logInfo file
2019-11-02 14:42:01.266 [INFO ] [.eclipse.smarthome.model.script.INFO] - {"direction":"INCREASE"}
2019-11-02 14:42:01.332 [vent.ItemStateChangedEvent] - Quad_SceneSwipe1 changed from {"direction":"INCREASE"} to {"direction":"STOP"}
2019-11-02 14:42:01.339 [INFO ] [.eclipse.smarthome.model.script.INFO] - {"direction":"STOP"}
So my question is how do I test for the direction in my code as part of an “if” statement.
The idea is to control X-10 lighting via RFXCom using the wallmote swipe feature
Thank you
Tim
