I have already downgraded back to #1512, deleted cache and temp, did a few restarts, reinstalled all addons and did a force reinstall without success,.
Thanks for the quick answer and good to hear I donât seem to be alone with my error. I am on openHABian - Hassle-free openHAB Setup. Bindings installed with PaperUI.
I havenât read thru the issue on git but it may help to delete /var/lib/openhab2/config/org/openhab/addons.config so it is regenerated with correct content. Please note that by deleting this file you will have to reinstall all your binding again (b/c they were installed via PaperUI). FYI If you have them installed in the addons.cfg file then after a restart OH will automatically reinstall the listed bindings.
Sometimes when changing versions you have to delete /var/lib/openhab2/config/org/openhab/addons.config and restart so OH can install everything from a clean slate.
If you would please mark the topic solved by clicking the square box (lower right corner) on the post that provided the solution. This helps otherâs with a similar issue find a quick solution.
I had the same problems after OH2 build #1518 upgrade - no addons and scheduler errors on startup. Iâve stopped OH2, removed /var/lib/openhab2/config/org/openhab/addons.config and upgraded OH2 (yesterday #1521) with no issues and additional commands.
Firstly this is my first post so I would like to say thank you to all that contribute, it has helped me immensely. I have been playing around as a noob for some time now, I have a very limited coding background and wanted to put something here as someone starting out might trip up where I did.
This all started when I updated my network adaptor (/etc/network/interfaces) and failed to add dns-nameservers. The Pi was fine on my network internally but obviously was powerless when trying to discover the outside world, page 1 mistake on my part for not checking this 1st when noticing my cloud service had gone wonky. Anyway before I discovered this I had managed to break everything else and couldnât install any releases. Once I fixed the DNS I could roll version and restore a backup.
If using ZRAM, RTFM! I didnât and it cost me a day. When rolling back/upgrading/cleaning the cache on ZRAM.
My file system was forced to Read-Only in the end âEXT4-fs error (device zram1): ext4_journal_check_start:61: Detected aborted journalâ but you can still follow these steps to recover.
stop openHAB2: sudo systemctl stop openhab2
clear the cache from ZRAM: sudo rm -rf /var/lib/openhab2/tmp/* /var/lib/openhab2/tmp/.??* /var/lib/openhab2/cache/*
stop ZRAM to make it sync to disk (notably the Karaf-generated files in /var/lib/openhab2/cache and âŠ/tmp): sudo systemctl stop zram-config
upgrade OH. Donât reboot (remember automatic startup of ZRAM and OH at boot time). The upgrade process clears the cache so you donât need step 5. Then again, to double check does not hurt.
clear the cache from disk: `sudo rm -rf /var/lib/openhab2/tmp/* /var/lib/openhab2/tmp/.??* /var/lib/openhab2/cache/*.
Thanks for publicly admitting. Most people arenât that bold.
BTW thereâs an upcoming change in openHABian, ZRAM will no longer include the cache but swap, logs and /var/lib/openhab2/persistence only.
You can also edit /etc/ztab to accomplish that yourself.
Thanks Markus, Iâm from an engineering background so mistakes are sometimes required to learn. mistake>learn>move_on, the more we admit the quicker development happens!
Thanks for your work on ZRAM with OH I have been using it since the start of my OH quest with no problems (only on my part). Nice to hear about changes I will continue my exploration.
I also had this read-only filesystem error and failures from core.karaf saying it wouldnât install bindings and Paper UI wouldnât start, etcâŠall kinds of problems. Was going to revert to backup but turns out the overall OS update I did via openhab-config turned ZRAM OFF. Simple fix to turn it back on and reboot but damn, took me a few hours to play around until i realized in the release notes ZRAM is OPTIONAL by default.
Version I use
I use Openhab 2.5.12.-1 and all was working perfectly but now my error log is full of
Error I have
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing âopenhab-binding-snmp1, openhab-action-mqtt, openhab-binding-mqtt1â
And MQTT binding is not working any longerâŠ
=> I still see on the Panel that my mqtt-devices are turned on/off but no MQTT message is sent out
Also homematic binding is not working
What I tried
restart OH2 5x
emptied chache
deleded addon.cfg as proposed somewhereâŠ
restart raspi pi4 several times
red everywhere , saw that I need to add in addons openhab-addons-2.5.12.kar
changed ownership to openhab, gave rw access to all and even execution access
went to the homepage and ```
wget -qO - âhttps://openhab.jfrog.io/artifactory/api/gpg/key/publicâ | sudo apt-key add -
`` Please HELP
I do not want to go to version 3 as I need and want mqtt binding 1.1. The hole installation became useless as no mqtt comands are sent out. It seems that the addons are no longer available for download? But why?
What is remote = set to in addons.cfg in /etc/openhab2/services/ is it set to false resp. put into a comment ? As far as I can see version 1 bindings are not included in the openhab-addons-2.5.12.kar file.
Thanks Wolfgang
So anyone knows how I can add the 1 bindings to the kar files? To use a âstableâ version that is not stable and moving is kinda uselessâŠ
