[SOLVED] [Google TTS] Chromecast Audio Sink not working
Hi! I’m doing my first script and I need help. I do all the steps to configure Google TTS and add the Chromecast binding.
I using a simple rule for say something:
rule "Say Hello"
  Item Test changed from OFF to ON
  logInfo("default.rules", "Trying to say Hi!")
  say("Hi", "gtts:esESStandardA", "chromecast:chromecast:fc070cef4c0727c90482fabdccf82384:control")
  logInfo("default.rules", "END HI")
rule "Say goodbye"
  Item Test changed from ON to OFF
  logInfo("default.rules", "Try to say Bye!")
  say("Bye", "gtts:esESStandardA", "chromecast:chromecast:fc070cef4c0727c90482fabdccf82384:control")
  logInfo("default.rules", "END BYE")
But nothing happens. In the console log:
23:03:56.572 [INFO ] [smarthome.event.ItemCommandEvent     ] - Item 'Test' received command ON
23:03:56.573 [INFO ] [smarthome.event.ItemStateChangedEvent] - Test changed from OFF to ON
23:03:56.574 [INFO ] [.smarthome.model.script.default.rules] - Trying to say Hi!
23:03:56.574 [INFO ] [.smarthome.model.script.default.rules] - END HI
What I am doing wrong?
Thanks!
I don’t use Chromecast yet (mine is on the way… I ordered it recently :slight_smile:)
can you check the name of the Audio sinks using the openHAB2 console:
openhab-cli console
smarthome:audio sinks
how does it appear there?
Ps: When posting configs, plz use: Code Fences (it makes it easier to read and doesn’t distort some characters)
additionally, this is wrong:
gtts:esESStandardA
it should be:
googletts:esESStandardA
check all available voices using the console and the command: smarthome:voice voices
Please use the code fences when publishing code, thanks
Hi Dim,
Sorry about the code, its changed now.
I did it and I took gtts:esESStandardA but maybe I took it from other column. I will check it later.
It’s not just a Chromecast, is a Googlr Home Mini and I’m trying to send it a command.
Actually, beside the voice, also the sink name is wrong.
You are using the control channel and this is not the case.
You Google Home Mini sink shoud be chromecast:chromecast:fc070cef4c0727c90482fabdccf82384 - without :control.
Check the available sinks as @Dim said.
Ouch! I will change it later and tell you the result.
Thanks!
Hi @Dim
I’ve tried and shows an error saying no TTS service. If I use smarthome:voide voices then I can read:
gtts:esESStandardA es-ES-Standard-A - español (España)
So I think that this is not the problem.
About @Mihai_Badea says, I change it but nothing happens, only one “beep” and nothing more.
OH2 version, platform and java being used?
openHAB 2.3.0 Release Build, Windows 10 and java version “1.8.0_181” with
Java™ SE Runtime Environment (build 1.8.0_181-b13)
How did you deploy Google TTS on OH2.3?
I found it in the community with the name of “org.openhab.voice.gtts-2.4.0-SNAPSHOT”. After download, I put it in the addons folder.
It won’t work on OH2.3.0 core
If it’s not too much trouble: boost your core to OH2.4.0.M6 and use the included voice addon
Ok, I’m going to update.
Hi @Dim,
I’ve updated the runtime. Now I’m in the openHAB 2.4.0.
I retry it and I can see in my Thing Google Home that the status is OFFLINE - COMMUNICATION ERROR Waiting for response timed out.
In the logs:
20:52:11.002 [INFO ] [smarthome.event.ItemCommandEvent     ] - Item 'Test' received command ON
20:52:11.004 [INFO ] [smarthome.event.ItemStateChangedEvent] - Test changed from OFF to ON
20:52:11.006 [INFO ] [.smarthome.model.script.default.rules] - Trying to say Hi!
20:52:41.226 [INFO ] [.smarthome.model.script.default.rules] - END HI
20:52:41.228 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:chromecast:fc070cef4c0727c90482fabdccf82384' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Waiting for response timed out
I would try to delete the existing chromecast thing and re-discover it
maybe? the latest version of the binding has some changes to the way it handles the chromecast things (not sure since I don’t use currently this binding)
did you go to OH2.4 M(ilestone) (build #?) or S(napshot) (build #?) ?
openHAB 2.4.0 Build #1446
Yes, I did it.
I can see this warn when start openhab:
20:58:41.155 [WARN ] [.voice.gtts.internal.GoogleTTSService] - Audio format OGG_OPUS is not yet supported.
that’s harmless. it’s just a warning that all of us have with Google TTS Addon.
Make sure that you don’t have any old TTS jar and/or chromecast jar in your addons folder and use the bindings from PaperUI. Clean tmp&cache also.
21:10:42.301 [INFO ] [smarthome.event.ItemCommandEvent     ] - Item 'Test' received command OFF
21:10:42.302 [INFO ] [smarthome.event.ItemStateChangedEvent] - Test changed from ON to OFF
21:10:42.334 [INFO ] [.smarthome.model.script.default.rules] - Try to say Bye!
21:10:45.526 [INFO ] [smarthome.event.ItemStateChangedEvent] - chromecast_chromecast_fc070cef4c0727c90482fabdccf82384_control changed from NULL to PLAY
21:10:45.528 [INFO ] [smarthome.event.ItemStateChangedEvent] - Google_Home changed from NULL to PLAY
21:11:14.414 [INFO ] [.smarthome.model.script.default.rules] - END BYE
21:11:14.414 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:chromecast:fc070cef4c0727c90482fabdccf82384' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Waiting for response timed out
21:11:29.133 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:chromecast:fc070cef4c0727c90482fabdccf82384' changed from OFFLINE (COMMUNICATION_ERROR): Waiting for response timed out to ONLINE
21:12:10.543 [WARN ] [okhttp3.OkHttpClient                 ] - A connection to https://myopenhab.org/ was leaked. Did you forget to close a response body?
But only sounds a “beep”
audio sinks
voice voices
rule contents plz
