Hi all!
having the intention to use IFTTT with openHAB again, I decided to configure a personal openHAB cloud server, and I succeeded by following the excellent instructions contained here step by step:
I did not use Azure but another cloud service and I used Ubunto 20.04 LTS instead of 18.04. Everything seems to work (access to the cloud server, remote access to my openHAB server, etc.), except for a not insignificant detail for those like me who still want to use IFTTT: I donât see any exposed items, although I have correctly configured openhabcloud.cfg and although I tried to send ON/OFF commands via Karaf to the exposed object . I also tried:
to clear the openHAB cache
to regenerate UUID and secret
to remove and reinstall the openHAB cloud connector
to delete the user with which I had initially registered on my personal openHAB cloud server and register again with the new UUID and secret
to restart the Raspberry Pi on which I have installed my openHAB server (with openhabian)
Needless to say, I verified the openHAB log and found no significant error messages. I have openHAB 2.5.10 Release Build, and I am getting a suspicion: by chance now it is not possible to expose items also on personal instances of openHAB cloud, as happened last year with myopenHAB.org? Or did I make some stupid mistake that is stupid enough to make me not be able to realize it?
Dear Wolfgang,
I was able to get a log only after stopping openhabcloudservice and restarting with sudo node app.js. I do not why⊠Anyway, logging produced this:
2020-11-30 19:55:29:2929 info: openHAB-cloud: Backend service is starting up...
2020-11-30 19:55:29:2929 info: openHAB-cloud: Backend logging initialized...
2020-11-30 19:55:30:3030 info: openHAB-cloud: Initializing XMPP connection to GCM
2020-11-30 19:55:30:3030 info: openHAB-cloud: Connecting to Redis at 127.0.0.1:6379
2020-11-30 19:55:31:3131 info: openHAB-cloud: Mailer will emulate sending in development environment
2020-11-30 19:55:32:3232 info: opneHAB-cloud: Trying to connect to mongodb at: mongodb://127.0.0.1/openhab?poolSize=50
2020-11-30 19:55:32:3232 info: openHAB-cloud: Scheduling a statistics job (every 5 min)
2020-11-30 19:55:32:3232 info: openHAB-cloud: IFTTT is configured, app handling IFTTT capabilities...
2020-11-30 19:55:32:3232 info: openHAB-cloud: express server listening on port 3000
2020-11-30 19:55:32:3232 info: openHAB-cloud: Redis connect response: OK
2020-11-30 19:55:32:3232 info: openHAB-cloud: Redis is ready
2020-11-30 19:55:32:3232 info: openHAB-cloud: Successfully connected to mongodb
2020-11-30 19:55:32:3232 warn: openHAB-cloud: GCM XMPP error: XMPP authentication failure
2020-11-30 19:55:36:3636 info: openHAB-cloud: Authorizing incoming openHAB connection
2020-11-30 19:55:36:3636 info: openHAB-cloud: Incoming openHAB connection for uuid 54ba59bd-04e6-4d6e-9ac6-c1e3fab4d4a9
2020-11-30 19:55:36:3636 info: openHAB-cloud: Connected openHAB with 54ba59bd-04e6-4d6e-9ac6-c1e3fab4d4a9 successfully
2020-11-30 19:55:36:3636 info: openHAB-cloud: uuid 54ba59bd-04e6-4d6e-9ac6-c1e3fab4d4a9 server address undefined:undefined my address undefined:undefined
2020-11-30 19:56:32:3232 debug: openHAB-cloud: Checking for offline openHABs (0)
2020-11-30 19:56:32:3232 debug: openHAB-cloud: Checking orphaned rest requests (2)
2020-11-30 19:56:32:3232 debug: openHAB-cloud: expiring orphaned response
2020-11-30 19:57:32:3232 debug: openHAB-cloud: Checking for offline openHABs (0)
2020-11-30 19:57:32:3232 debug: openHAB-cloud: Checking orphaned rest requests (1)
2020-11-30 19:58:32:3232 debug: openHAB-cloud: Checking for offline openHABs (0)
2020-11-30 19:58:32:3232 debug: openHAB-cloud: Checking orphaned rest requests (1)
2020-11-30 19:59:32:3232 debug: openHAB-cloud: Checking for offline openHABs (0)
2020-11-30 19:59:32:3232 debug: openHAB-cloud: Checking orphaned rest requests (1)
2020-11-30 20:00:00:000 info: openHAB-cloud: every5min statistics collection job started
2020-11-30 20:00:00:000 info: openHAB-cloud: every5min statistics collection job finished
2020-11-30 20:00:32:3232 debug: openHAB-cloud: Checking for offline openHABs (0)
2020-11-30 20:00:32:3232 debug: openHAB-cloud: Checking orphaned rest requests (1)
2020-11-30 20:01:32:3232 debug: openHAB-cloud: Checking for offline openHABs (0)
2020-11-30 20:01:32:3232 debug: openHAB-cloud: Checking orphaned rest requests (1)
2020-11-30 20:02:32:3232 debug: openHAB-cloud: Checking for offline openHABs (0)
2020-11-30 20:02:32:3232 debug: openHAB-cloud: Checking orphaned rest requests (1)
2020-11-30 20:03:11:1111 info: openHAB-cloud frontend is shutting down from SIGINT
The only âsuspiciousâ row is 2020-11-30 19:55:32:3232 warn: openHAB-cloud: GCM XMPP error: XMPP authentication failure, but I am unable to better understand. On the openHAB server side (a Raspberry Pi) I just tried to understand some more details after setting the log level at DEBUG, and the only significant issue that I found so far is:
lampada_soggiorno_1_int is the name of the item that should be exposed and that I still do not see on https:///xxxxxxx.ddns.net/items. I really do not know how to proceed further. Any help is appreciated!
Thank you for your kind reply.
But at this point I feel helpless. What should I do to assign the right values to openhab.serverAddress and to internalAddress?
Please, note that I inserted dummy values for âiftttChannelKeyâ and for âiftttTestTokenâ. Please, forgive me if I am saying something nonsense, but is it not by chance that my problem can be generated by a permissions problem, as often happens in unix systems?
I have worked with UNIX systems for years. The only permissions issues I have never encountered any unexplainable permissions issues. I assume Linux, being a UNIX-like system, is similar/
It looks like you used the config-development.json file as a template for your configuration. I am using the config-productin.json file as a template in my installation. There is at least one difference ( morganOption ). I do ot know what this is being used for.
In case it would be a permission option I would expect to see an error message.
Trying to setup my config.json exactly as it is inside the config-productin.json template (two empty fields) does not work: the openHAB cloud web page becomes inaccessible. Actually, I do not use any user and password to access mongodb. Did you set a specific user/password for mongodb instead?
I spent some more times during the weekend on this issue, but I have not come to the end of anything. I also set up a parallel installation of openHAB on docker on a Synology NAS at my disposal, for the sake of using openHAB 2.4.0 instead of the latest 2.5.0: nothing to do, the result is the same.
I think the problem is in the cloud server setup. When I have time I will make another attempt: I want to install a trial version of openhabcloud within my network and not on the cloud server, just to see if the problem recurs. If the problem doesnât recur in my home environment, then it might be worth looking for a new provider for the cloud service. Thanks again to Wolfgang for his help, I keep you informed!
Unfortunately at the moment I have no time for further tests. As soon as I will have time to spend I will try that âdummy installationâ on a server inside my home network. Knowing Iâm not alone is partial consolation âŠ
You got it!!!
I modified app.js by commenting line 746 in this way:
socket.on('itemupdate', function (data) {
//disabling item updates for now
//return;
and now exposed objects are visible again. I still do not know if IFTTT is working, I had no time. During the weekend I will try and probably I will put SOLVED on this topic.
