[SOLVED] Persistence developed problems
Hi everyone i’m hoping for some help again
both my persistence services are behaving weird and have developed problems some stuff works but others not both services have errors
services used Infuxdb & mapdb
MAPDB (Restore everything on startup every change persisted)
most of this works fine as far as i can tell but my log is full of errors relating too mapdb differnet items
Example error repeated over and over different items
2019-03-07 20:38:56.999 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl@e65c13' about state update of item Bathroom_Motion_Last_Updated: null
java.lang.IndexOutOfBoundsException: null
	at java.nio.Buffer.checkIndex(Buffer.java:546) ~[?:?]
	at java.nio.HeapByteBuffer.getLong(HeapByteBuffer.java:416) ~[?:?]
	at org.mapdb.DataInput2.readLong(DataInput2.java:104) ~[?:?]
	at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:81) ~[?:?]
	at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:1) ~[?:?]
	at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:449) ~[?:?]
	at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:288) ~[?:?]
	at org.mapdb.Store.deserialize(Store.java:297) ~[?:?]
	at org.mapdb.StoreDirect.get2(StoreDirect.java:486) ~[?:?]
	at org.mapdb.StoreWAL.get2(StoreWAL.java:336) ~[?:?]
	at org.mapdb.StoreWAL.get(StoreWAL.java:320) ~[?:?]
	at org.mapdb.Caches$HashTable.get(Caches.java:246) ~[?:?]
	at org.mapdb.EngineWrapper.get(EngineWrapper.java:58) ~[?:?]
	at org.mapdb.BTreeMap.put2(BTreeMap.java:677) ~[?:?]
	at org.mapdb.BTreeMap.put(BTreeMap.java:643) ~[?:?]
	at org.openhab.persistence.mapdb.internal.MapDBPersistenceService.store(MapDBPersistenceService.java:161) ~[?:?]
	at org.openhab.core.persistence.internal.PersistenceServiceDelegate.store(PersistenceServiceDelegate.java:55) ~[?:?]
	at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:148) ~[?:?]
	at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.stateChanged(PersistenceManagerImpl.java:464) ~[?:?]
	at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:251) [102:org.eclipse.smarthome.core:0.10.0.oh240]
INFLUX (Persistence service for graphs and everything else every change persisted)
This is the same some things are working somethings are not
will edit too update influx errors
The MapDB problem looks a little bit like a corrupted database. If so, about the only thing you can do is delete it and let it get rebuilt. The files are located in /var/lib/openhab2/persistence/mapdb. You probably want to stop OH running before you do this.
Of course, any Rules you have that depend on restoreOnStartup will have problems when it comes up.
Others have reported the InfluxDB problem. Some Items get updated, others do not.
I don’t know if these are exactly your problem. Are you seeing errors from that?
Hi again @rlkoshak thanks for the reply
With different errors I’m wondering if this may be a corrupt card
Deleting the database and letting it rebuild seems too have stopped that error thanks for the advise there
I uninstalled the addon trying too solve the problem got reset it up so I’m unsure of the error myself at the moment
how should i reinstall influxdb using paperui addons section or using ssh openhabian-config add componant
Always a possibility. It try not to always jump to that conclusion first off, but the weird errors could be caused by that.
The actual database needs to be installed using openhabian-config. The binding that let’s OH talk to the database can be installed through PaperUI.
@rlkoshak
Influx problems seem too be fixed sadly I can not report what I did too actually fix the error or even know what was causing the error
At a guess I would say it was a corrupt database the same as mapdb? All of this started after a full restore from Amanda
What I have changed in influx too fix the problem
I reran the openhabian config add influx… I also reinstalled the addon using paperui
All good for now back too adding new features and improvements thanks for the help on that Rich I was starting too think corrupt card or fresh install
Quite old this topic but I faced the same issue and solved it this way without OH restart.
This way I did not have problems with missing configuration of dummy Items or rules that depend on restoreOnStartup after restarting OH without working persistence.
bundle:stop org.openhab.persistence.mapdb
delete /var/lib/openhab2/persistence/mapdb
bundle:start org.openhab.persistence.mapdb
to have a quick update of the persitence I added quick_update strategy to my persistence
Strategies {
	quick_update : " 0 0/1 * * * ? *"
	default = everyChange
Items {
	OnChange* : strategy = everyChange, restoreOnStartup, quick_update
to my default OnChange
