Hi Hilbrand,
I’m on OH 2.5.0.M1 and Spotify Binding (Beta 30/04/2019 23:00)
Hi Hilbrand,
If you’re running on snapshot version. There was a bug recently introduced and fixed related to lists in core. https://github.com/openhab/openhab-core/issues/1040 . This might be a possible explanation in that case. The bug has been fixed and should be availlable in new snapshot versions.
That version should be able to handle changes. If the bridge thing was created with an older version you should recreate it, because it might not have the correct value. Can you check this?
Hi Hilbrand,
I run Spotify Binding (Beta 06/09/2019). I did this by Paper UI, so no idea if this is snapshot or not. I run OH 2.4.0-1. System is updated, but still no lists available with the IOS APP.
BTW: Furthermore I am facing the same issue as @Curtis does.
Sorry for the problem
Hi, I’ve had time to take a look.
I noticed my Spotify Binding had disappeared. I realised it was due to the fact that everything I install is done through my Addons.cfg and I forgot to add the marketplace to my file. Therefore a restart removed what was once installed. I realise that this is possibly not related to my issue but thought I would mention anyway.
I found out that I could not install marketplace bindings this way so I fixed that using a helpful script here.Addon.cfg load market binding?
I really struggled to delete 60 items from my inbox as it crashed constantly. I finally deleted them by adding the following in the console smarthome:inbox clear
I deleted all my old Spotify things
I deleted my caches
sudo /etc/init.d/openhab2 stop
sudo rm -rf /var/lib/openhab2/cache/*
sudo rm -rf /var/lib/openhab2/tmp/*
sudo /etc/init.d/openhab2 start
I then restarted my RapberryPi, added the Spotify Bridge thing and authorised it which made all my echo and sonos devices apear in the inbox but only once.
This seems to have fixed the issue but I’ll find out over the course of the next few days.
Binding is now Beta 06/09/2019
Does the Spotify binding can cause this warning in the log?
2019-10-20 21:10:53.553 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_256_CBC_SHA256 enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.561 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.563 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.565 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.567 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.569 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.571 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDH_RSA_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.573 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_DHE_RSA_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.575 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_DHE_DSS_WITH_AES_256_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.577 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_128_CBC_SHA256 enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.579 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.581 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.583 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.584 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.586 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.588 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDH_RSA_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.590 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_DHE_RSA_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.592 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_DHE_DSS_WITH_AES_128_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.594 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_256_GCM_SHA384 enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.596 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_RSA_WITH_AES_128_GCM_SHA256 enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.598 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.600 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.601 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite SSL_RSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.604 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite SSL_RSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.606 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.608 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.610 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.612 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.614 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.616 [WARN ] [ty.util.ssl.SslContextFactory.config] - Weak cipher suite SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA enabled for SslContextFactory@b3be64[provider=null,keyStore=null,trustStore=null]
2019-10-20 21:10:53.857 [INFO ] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://accounts.spotify.com/api/token success
As you can see just 200ms after these errors, there is the INFO about the token refresh.
This issue is just only a warning but causes my log to get full of these warnings. I just assume that this binding could cause this, but I’m unable to track it back until it’s origin.
Not that I know of.
I also think the “Weak cipher” messages are from the Spotify binding. Perhaps it’s related to the platform where openHAB is running.
I have exactly the same behaviour as @rkrisi.
My environment:
CentOS Linux release 7.7.1908 (Core)
openjdk version “1.8.0_222”
openHAB 2.5.0.M4
I’m on openHabian on a Raspberry, so totally different platforms. But I also assume this. I’ll try to remove the binding and see if these warnings are gone.
@hilbrand
Now I’m sure that spotify binding causes these chiper warnings. Fresh install, right after authenticating spotify I get these warnings. None of them before
Maybe it’s a combination of the java environment and updated library jetty version in core? Did this all happen after an update of openHAB? I haven’t seen the error on my systems, soI don’t know directly why this is triggered or how to fix this. The binding itself doesn’t do anything special with https. It just uses methods from core.
Yes, @J-N-K mentioned in another thread that the jetty got updated in 2.5M2 if I remember it right.
Hello there!
I have some serious issues with this binding.
I cannot tell you anything further by now but i will be happy to help investigating.
After two month of investigating what is the cause for my huge cpu load after 1-2 days I finally broke it down to the Spotify Binding. My issue is written down here: Huge CPU Load - Zulu8 on Mac OS X - sporadically
I had the issue 4 days ago for the last time. then I uninstalled the Spotify binding, deleted the .things-file and the cache and now it is running like charm for 4 days. Before i had to reboot daily to get rid of the cpu load issue.
I still don’t know why i am having this issue. maybe it’s a mac os x thing. I tried installing OH 2.4 and setting up OH 2.5M3/4 on my Macbook as well and still got the issue.
Could you tell me what i should do to help you debug? For example the name for log:set “???” debug to investigate this issue?
Here is my .things and .items file.
Do i have to many things maybe?
Regards Jonas
Bridge spotify:player:Jonas "Spotify Jonas" [clientId="nope", clientSecret="nope"] {
Things:
device WoZi_Thing_Echo_Spotify "Spotify Echo Wohnzimmer" @ "Wohnzimmer" [deviceName="Wohnzimmer"]
device Keller_Thing_Echo_Spotify "Spotify Echo Keller" @ "Keller" [deviceName="Keller"]
device Bad_Thing_Echo_Spotify "Spotify Echo Bad" @ "Bad" [deviceName="Bad"]
device SchlaZi_Thing_Echo_Spotify "Spotify Echo Schlafzimmer" @ "Schlafzimmer" [deviceName="Schlafzimmer"]
device Kueche_Thing_Echo_Spotify "Spotify Echo Küche" @ "Küche" [deviceName="Küche"]
device KiZi_Thing_Echo_Spotify "Spotify Echo Kinderzimmer" @ "Kinderzimmer" [deviceName="Kinderzimmer"]
device WoKue_Thing_Echo_Spotify "Spotify Echo Wohnküche" @ "Küche" [deviceName="Wohnküche"]
device Wohnung_Thing_Echo_Spotify "Spotify Echo Wohnung" @ "Wohnung" [deviceName="Wohnung"]
//device Mobil_Thing_iPhone_Jonas_Spotify "Spotify iPhone Jonas" @ "Mobil" [deviceName="Jonass iPhone"]
Player Haus_Spotify_Player "Spotify Player" {channel="spotify:player:Jonas:trackPlayer"}
String Haus_Spotify_Geraete "Geräte: [%s]" {channel="spotify:player:Jonas:devices"}
String Haus_Spotify_Akt_Geraet "Aktuelles Gerät: [%s]" {channel="spotify:player:Jonas:deviceName"}
Dimmer Haus_Spotify_Volume "Spotify Lautsärke Global" {channel="spotify:player:Jonas:deviceVolume"}
Switch Haus_Spotify_Shuffle "Shuffle" {channel="spotify:player:Jonas:deviceShuffle"}
String Haus_Spotify_Wiederholungsmodus "Wiederholungsmodus: [%s]" {channel="spotify:player:Jonas:trackRepeat"}
String Haus_Spotify_Fortschritt "Fortschritt: [%s]" {channel="spotify:player:Jonas:trackProgress"}
Number Haus_Spotify_Fortschritt_Millis "Fortschritt: [%s]" {channel="spotify:player:Jonas:trackProgressMs"}
String Haus_Spotify_Laenge "Länge: [%s]" {channel="spotify:player:Jonas:tackDuration"}
Number Haus_Spotify_Laenge_Millis "Länge in ms: [%s]" {channel="spotify:player:Jonas:trackDurationMs"}
String Haus_Spotify_Titel "Titel: [%s]" {channel="spotify:player:Jonas:trackName"}
String Haus_Spotify_Album "Album: [%s]" {channel="spotify:player:Jonas:albumName"}
String Haus_Spotify_Interpret "Interpret: [%s]" {channel="spotify:player:Jonas:artistName"}
Image Haus_Spotify_Cover "Cover" {channel="spotify:player:Jonas:albumImage"}
String Haus_Spotify_Playlists "Playlists [%s]" {channel="spotify:player:Jonas:playlists"}
String Haus_Spotify_Playlist_Name "Playlist [%s]" {channel="spotify:player:Jonas:playlistName"}
String WoZi_Spotify_Name "Spotify Name Wohnzimmer" {channel="spotify:device:Jonas:WoZi_Thing_Echo_Spotify:deviceName"}
Player WoZi_Spotify_Player "Spotify Player Wohnzimmer" {channel="spotify:device:Jonas:WoZi_Thing_Echo_Spotify:devicePlayer"}
Dimmer WoZi_Spotify_Volume "Spotify Lautsärke Wohnzimmer" {channel="spotify:device:Jonas:WoZi_Thing_Echo_Spotify:deviceVolume"}
Switch WoZi_Spotify_Shuffle "Spotify Shuffle Wohnzimmer" {channel="spotify:device:Jonas:WoZi_Thing_Echo_Spotify:deviceShuffle"}
String Keller_Spotify_Name "Spotify Name Keller" {channel="spotify:device:Jonas:Keller_Thing_Echo_Spotify:deviceName"}
Player Keller_Spotify_Player "Spotify Player Keller" {channel="spotify:device:Jonas:Keller_Thing_Echo_Spotify:devicePlayer"}
Dimmer Keller_Spotify_Volume "Spotify Lautsärke Keller" {channel="spotify:device:Jonas:Keller_Thing_Echo_Spotify:deviceVolume"}
Switch Keller_Spotify_Shuffle "Spotify Shuffle Keller" {channel="spotify:device:Jonas:Keller_Thing_Echo_Spotify:deviceShuffle"}
String Bad_Spotify_Name "Spotify Name Bad" {channel="spotify:device:Jonas:Bad_Thing_Echo_Spotify:deviceName"}
Player Bad_Spotify_Player "Spotify Player Bad" {channel="spotify:device:Jonas:Bad_Thing_Echo_Spotify:devicePlayer"}
Dimmer Bad_Spotify_Volume "Spotify Lautsärke Bad" {channel="spotify:device:Jonas:Bad_Thing_Echo_Spotify:deviceVolume"}
Switch Bad_Spotify_Shuffle "Spotify Shuffle Bad" {channel="spotify:device:Jonas:Bad_Thing_Echo_Spotify:deviceShuffle"}
String SchlaZi_Spotify_Name "Spotify Name Schlafzimmer" {channel="spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify:deviceName"}
Player SchlaZi_Spotify_Player "Spotify Player Schlafzimmer" {channel="spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify:devicePlayer"}
Dimmer SchlaZi_Spotify_Volume "Spotify Lautsärke Schlafzimmer" {channel="spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify:deviceVolume"}
Switch SchlaZi_Spotify_Shuffle "Spotify Shuffle Schlafzimmer" {channel="spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify:deviceShuffle"}
String Kueche_Spotify_Name "Spotify Name Küche" {channel="spotify:device:Jonas:Kueche_Thing_Echo_Spotify:deviceName"}
Player Kueche_Spotify_Player "Spotify Player Küche" {channel="spotify:device:Jonas:Kueche_Thing_Echo_Spotify:devicePlayer"}
Dimmer Kueche_Spotify_Volume "Spotify Lautsärke Küche" {channel="spotify:device:Jonas:Kueche_Thing_Echo_Spotify:deviceVolume"}
Switch Kueche_Spotify_Shuffle "Spotify Shuffle Küche" {channel="spotify:device:Jonas:Kueche_Thing_Echo_Spotify:deviceShuffle"}
String KiZi_Spotify_Name "Spotify Name Kinderzimmer" {channel="spotify:device:Jonas:KiZi_Thing_Echo_Spotify:deviceName"}
Player KiZi_Spotify_Player "Spotify Player Kinderzimmer" {channel="spotify:device:Jonas:KiZi_Thing_Echo_Spotify:devicePlayer"}
Dimmer KiZi_Spotify_Volume "Spotify Lautsärke Kinderzimmer" {channel="spotify:device:Jonas:KiZi_Thing_Echo_Spotify:deviceVolume"}
Switch KiZi_Spotify_Shuffle "Spotify Shuffle Kinderzimmer" {channel="spotify:device:Jonas:KiZi_Thing_Echo_Spotify:deviceShuffle"}
String WoKue_Spotify_Name "Spotify Name Wohnküche" {channel="spotify:device:Jonas:WoKue_Thing_Echo_Spotify:deviceName"}
Player WoKue_Spotify_Player "Spotify Player Wohnküche" {channel="spotify:device:Jonas:WoKue_Thing_Echo_Spotify:devicePlayer"}
Dimmer WoKue_Spotify_Volume "Spotify Lautsärke Wohnküche" {channel="spotify:device:Jonas:WoKue_Thing_Echo_Spotify:deviceVolume"}
Switch WoKue_Spotify_Shuffle "Spotify Shuffle Wohnküche" {channel="spotify:device:Jonas:WoKue_Thing_Echo_Spotify:deviceShuffle"}
String Wohnung_Spotify_Name "Spotify Name Wohnung" {channel="spotify:device:Jonas:Wohnung_Thing_Echo_Spotify:deviceName"}
Player Wohnung_Spotify_Player "Spotify Player Wohnung" {channel="spotify:device:Jonas:Wohnung_Thing_Echo_Spotify:devicePlayer"}
Dimmer Wohnung_Spotify_Volume "Spotify Lautsärke Wohnung" {channel="spotify:device:Jonas:Wohnung_Thing_Echo_Spotify:deviceVolume"}
Switch Wohnung_Spotify_Shuffle "Spotify Shuffle Wohnung" {channel="spotify:device:Jonas:Wohnung_Thing_Echo_Spotify:deviceShuffle"}
String Jonas_iPhone_Spotify_Name "Spotify Name iPhone Jonas" {channel="spotify:device:Jonas:Mobil_Thing_iPhone_Jonas_Spotify:deviceName"}
Player Jonas_iPhone_Spotify_Player "Spotify Player iPhone Jonas" {channel="spotify:device:Jonas:Mobil_Thing_iPhone_Jonas_Spotify:devicePlayer"}
Dimmer Jonas_iPhone_Spotify_Volume "Spotify Lautsärke iPhone Jonas" {channel="spotify:device:Jonas:Mobil_Thing_iPhone_Jonas_Spotify:deviceVolume"}
Switch Jonas_iPhone_Spotify_Shuffle "Spotify Shuffle iPhone Jonas" {channel="spotify:device:Jonas:Mobil_Thing_iPhone_Jonas_Spotify:deviceShuffle"}
You can set debug or trace (trace will give a lot of data) with:
log:set DEBUG org.openhab.binding.spotify
What can be of impact is:
play status
, playlists
and devices
each time. So if refresh rate is 5 seconds. It will make 3 calls every 5 seconds and update the channels.trackProgress
or trackProgressMs
channels it will update these channels by computing the progress every second. (But the actual status is only updated during the refresh of the previous point).Thank you I will check that out, set the log level as described and report back once the problem occurs. Thank you for your support.
Few weeks ago I think(?) I might have had the same problem. Basically I was messing with my internet connection so my openhab box was cut off for 15-30 minutes. After some period of time the cpu just spiked and could only be resolved by restarting openhab. So is your mac always on?
Hello
I installed it yesterday in the afternoon and tomorrow i had the same problem.
The problem started at around 09:37. I attached the log between 09:36 and 09:39.
I hope you can take any conclusions out of it.
2019-11-06 09:36:12.390 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:36:12.436 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:12.437 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:36:12.484 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:36:12.485 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:36:12.577 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:12.578 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:36:12.578 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:36:12.579 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:36:12.579 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:36:12.580 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:36:12.580 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:36:12.580 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:36:18.532 [DEBUG] [covery.SpotifyDeviceDiscoveryService] - Starting Spotify Device discovery for bridge spotify:player:Jonas
2019-11-06 09:36:18.533 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:36:18.577 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:22.615 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:36:22.659 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:22.660 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:36:22.705 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:36:22.706 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:36:22.805 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:22.806 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:36:22.807 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:36:22.808 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:36:22.808 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:36:22.809 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:36:22.809 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:36:22.809 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:36:32.956 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:36:33.005 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:33.006 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:36:33.046 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:36:33.046 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:36:33.163 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:33.164 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:36:33.165 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:36:33.165 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:36:33.166 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:36:33.166 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:36:33.167 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:36:33.167 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:36:41.321 [WARN ] [calimero.link.192.168.178.40:3671 ] - negative confirmation of 1/0/1: 2e00bde0110e0801090080770b060924292400
2019-11-06 09:36:43.315 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:36:43.366 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:43.367 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:36:43.437 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:36:43.438 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:36:43.521 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:43.522 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:36:43.523 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:36:43.523 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:36:43.524 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:36:43.524 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:36:43.525 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:36:43.525 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:36:53.674 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:36:53.720 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:53.721 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:36:53.764 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:36:53.764 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:36:53.866 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:36:53.867 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:36:53.868 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:36:53.868 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:36:53.869 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:36:53.869 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:36:53.870 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:36:53.870 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:37:03.949 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:37:03.998 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:03.999 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:37:04.048 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:37:04.048 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:37:04.127 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:04.128 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:37:04.129 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:37:04.129 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:37:04.130 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:37:04.130 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:37:04.131 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:37:04.131 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:37:14.282 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:37:14.326 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:14.327 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:37:14.370 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:37:14.370 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:37:14.457 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:14.458 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:37:14.459 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:37:14.459 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:37:14.459 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:37:14.460 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:37:14.479 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:37:14.480 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:37:18.717 [DEBUG] [covery.SpotifyDeviceDiscoveryService] - Starting Spotify Device discovery for bridge spotify:player:Jonas
2019-11-06 09:37:18.718 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:37:18.763 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:24.625 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:37:24.670 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:24.671 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:37:24.713 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:37:24.714 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:37:24.793 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:24.794 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:37:24.794 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:37:24.795 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:37:24.795 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:37:24.796 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:37:24.796 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:37:24.797 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:37:34.928 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:37:34.981 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:34.982 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:37:35.020 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:37:35.020 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:37:35.102 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:35.103 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:37:35.104 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:37:35.104 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:37:35.104 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:37:35.105 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:37:35.105 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:37:35.105 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:37:41.332 [WARN ] [calimero.link.192.168.178.40:3671 ] - negative confirmation of 1/0/1: 2e00bde0110e0801090080770b060925292400
2019-11-06 09:37:45.244 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:37:45.288 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:45.288 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:37:45.332 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:37:45.332 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:37:45.423 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:45.424 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:37:45.425 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:37:45.425 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:37:45.426 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:37:45.426 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:37:45.427 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:37:45.427 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:37:55.562 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:37:55.604 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:55.604 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:37:55.642 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:37:55.642 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:37:55.730 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:37:55.732 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:37:55.732 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:37:55.733 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:37:55.733 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:37:55.734 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:37:55.734 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:37:55.734 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:38:05.878 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:38:05.923 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:05.924 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:38:05.966 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:38:05.966 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:38:06.049 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:06.050 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:38:06.051 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:38:06.051 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:38:06.052 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:38:06.052 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:38:06.053 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:38:06.053 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:38:16.200 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:38:16.244 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:16.244 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:38:16.290 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:38:16.291 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:38:16.374 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:16.375 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:38:16.375 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:38:16.376 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:38:16.376 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:38:16.376 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:38:16.377 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:38:16.377 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:38:18.889 [DEBUG] [covery.SpotifyDeviceDiscoveryService] - Starting Spotify Device discovery for bridge spotify:player:Jonas
2019-11-06 09:38:18.889 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:38:18.930 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:26.513 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:38:26.564 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:26.564 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:38:26.604 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:38:26.604 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:38:26.706 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:26.707 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:38:26.708 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:38:26.708 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:38:26.709 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:38:26.709 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:38:26.709 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:38:26.710 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:38:36.821 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:38:36.863 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:36.863 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:38:36.912 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:38:36.912 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:38:36.991 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:36.992 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:38:36.992 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:38:36.993 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:38:36.993 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:38:36.993 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:38:36.994 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:38:36.994 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:38:41.470 [WARN ] [calimero.link.192.168.178.40:3671 ] - negative confirmation of 1/0/1: 2e00bde0110e0801090080770b060926292400
2019-11-06 09:38:47.133 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:38:47.173 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:47.174 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:38:47.217 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:38:47.218 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:38:47.299 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:47.300 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:38:47.300 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:38:47.301 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:38:47.301 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:38:47.301 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:38:47.302 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:38:47.302 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
2019-11-06 09:38:57.404 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player/devices -
2019-11-06 09:38:57.446 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:57.446 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/player -
2019-11-06 09:38:57.492 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 204
2019-11-06 09:38:57.492 [DEBUG] [ding.spotify.internal.api.SpotifyApi] - Request: (GET) https://api.spotify.com/v1/me/playlists -
2019-11-06 09:38:57.574 [DEBUG] [potify.internal.api.SpotifyConnector] - Response Code: 200
2019-11-06 09:38:57.575 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoZi_Thing_Echo_Spotify Device [ dea05b28e3648a1335a518496c0e8d5fb3c9c19d Wohnzimmer, Speaker ]
2019-11-06 09:38:57.575 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Keller_Thing_Echo_Spotify Device [ 8e5968efe20e988dde0e32b540bb207b673dfe9d Keller, Speaker ]
2019-11-06 09:38:57.576 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Bad_Thing_Echo_Spotify Device [ 647968f76570544d8e18bfe1675c2845ebbdf738 Bad, Speaker ]
2019-11-06 09:38:57.576 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:SchlaZi_Thing_Echo_Spotify Device [ 7ec0db1aa9ffd8d33abde0ca90eea4c6b7684604 Schlafzimmer, Speaker ]
2019-11-06 09:38:57.576 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Kueche_Thing_Echo_Spotify Device [ c3896c5ce3c3097e5cc8ce12b8ff2ed9c921b5f3 Küche, Speaker ]
2019-11-06 09:38:57.577 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:WoKue_Thing_Echo_Spotify Device [ 0605cc957cd5cde7631ed8acf3adf41d0b7f6ec2 Wohnküche, Speaker ]
2019-11-06 09:38:57.577 [DEBUG] [nternal.handler.SpotifyDeviceHandler] - Updating status of Thing: spotify:device:Jonas:Wohnung_Thing_Echo_Spotify Device [ 16c5126be33e766a3326cc5e85e61782bed61783 Wohnung, Speaker ]
The log doesn’t look very strange. But I noticed it give 204, meaning no data is returned. I’ve updated the binding to not update the state when a 204 is given. Also I reduced updating playlist to once per hour (or when explicit refresh command is send to channel). This update is available via the Eclipse IoT Marketplace, accessible when enabled in PaperUI.
I will check it out, thank you!
EDIT: My things won’t come online …
The account is online but my devices show a “unkown” status.
I’ll look into it. A check question. If you start playing on your device or click play in openHAB doe they then come online?
