ok, now i set logging catetory org.openhab.binding.zigbee to debug.
This is the output, when i set dimm level to 77:
2024-03-08 08:10:53.945 [INFO ] [script.ui.testDimmwertKuecheStatisch] - Küche Unterschrank per Rule auf 77 setzen.
2024-03-08 08:10:53.968 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 3C2EF5FFFEEE71BB: Command for channel zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer --> 77 [PercentType]
2024-03-08 08:10:53.971 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 3C2EF5FFFEEE71BB: Channel zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer waiting for response to 77
2024-03-08 08:10:53.950 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Zigbee_Kueche_Unterschrank_10w' received command 77
2024-03-08 08:10:54.052 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 3C2EF5FFFEEE71BB: Channel zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer received SUCCESS in response to 77
2024-03-08 08:10:54.054 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 3C2EF5FFFEEE71BB: Channel zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer updated to 77
2024-03-08 08:10:54.055 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 3C2EF5FFFEEE71BB: Updating ZigBee channel state zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer to 77
2024-03-08 08:10:54.093 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 0015BC0031020273: ZigBee command report ZoneStatusChangeNotificationCommand [IAS Zone: 18B1/35 -> 0000/1, cluster=0500, TID=C1, zoneStatus=48, extendedStatus=0, zoneId=0, delay=65535]
2024-03-08 08:10:54.095 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 0015BC0031020273: Channel zigbee:device:d541f83264:0015bc0031020273:0015BC0031020273_35_tamper updated to OFF
2024-03-08 08:10:54.096 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0015BC0031020273: Updating ZigBee channel state zigbee:device:d541f83264:0015bc0031020273:0015BC0031020273_35_tamper to OFF
2024-03-08 08:10:54.157 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - 3C2EF5FFFEEE71BB: ZigBee attribute reports ZclAttribute [cluster=Level Control, id=0, name=Current Level, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=138, lastReportTime=Fri Mar 08 08:10:54 CET 2024, implemented=true]
2024-03-08 08:10:54.159 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 3C2EF5FFFEEE71BB: Channel zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer updated to 54
2024-03-08 08:10:54.160 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 3C2EF5FFFEEE71BB: Updating ZigBee channel state zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer to 54
2024-03-08 08:10:54.059 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Zigbee_Kueche_Unterschrank_10w' changed from 52 to 77
2024-03-08 08:10:54.166 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Zigbee_Kueche_Unterschrank_10w' changed from 77 to 54
2024-03-08 08:10:55.158 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - 3C2EF5FFFEEE71BB: ZigBee attribute reports ZclAttribute [cluster=Level Control, id=0, name=Current Level, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=196, lastReportTime=Fri Mar 08 08:10:55 CET 2024, implemented=true]
2024-03-08 08:10:55.160 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 3C2EF5FFFEEE71BB: Channel zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer updated to 77
2024-03-08 08:10:55.161 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 3C2EF5FFFEEE71BB: Updating ZigBee channel state zigbee:device:d541f83264:3c2ef5fffeee71bb:3C2EF5FFFEEE71BB_1_dimmer to 77
2024-03-08 08:10:55.167 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Zigbee_Kueche_Unterschrank_10w' changed from 54 to 77
2024-03-08 08:10:58.804 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:smartHomeDevice:amazonAccount:1909d1f9-3898-40de-8977-789ac37f34c8' changed from UNKNOWN: State not found to ONLINE
2024-03-08 08:11:03.444 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 0015BC0031020305: ZigBee command report ZoneStatusChangeNotificationCommand [IAS Zone: CEEA/35 -> 0000/1, cluster=0500, TID=11, zoneStatus=48, extendedStatus=0, zoneId=0, delay=65535]
2024-03-08 08:11:03.446 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 0015BC0031020305: Channel zigbee:device:d541f83264:0015bc0031020305:0015BC0031020305_35_tamper updated to OFF
2024-03-08 08:11:03.448 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0015BC0031020305: Updating ZigBee channel state zigbee:device:d541f83264:0015bc0031020305:0015BC0031020305_35_tamper to OFF
2024-03-08 08:11:09.251 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:smartHomeDevice:amazonAccount:1909d1f9-3898-40de-8977-789ac37f34c8' changed from ONLINE to UNKNOWN: State not found
2024-03-08 08:11:18.082 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 60B647FFFE3F4937: Not polling zigbee:device:d541f83264:60b647fffe3f4937:60B647FFFE3F4937_1_dimmer - channel is not linked
2024-03-08 08:11:20.303 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 0015BC003102057B: ZigBee command report ZoneStatusChangeNotificationCommand [IAS Zone: 679E/35 -> 0000/1, cluster=0500, TID=B8, zoneStatus=48, extendedStatus=0, zoneId=0, delay=65535]
2024-03-08 08:11:20.305 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 0015BC003102057B: Channel zigbee:device:d541f83264:0015bc003102057b:0015BC003102057B_35_tamper updated to OFF
2024-03-08 08:11:20.306 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0015BC003102057B: Updating ZigBee channel state zigbee:device:d541f83264:0015bc003102057b:0015BC003102057B_35_tamper to OFF```
