There is a widget on the marketplace but this requires way more than just a widget so following the tutorial is definitely a must.: Timeline.
As @pacive mentioned, there are several ways you can do this.
- Design Pattern: Simple State Machine (e.g. Time Of Day)
- Time Based State Machine [4.0.0.0;5.9.9.9]
- One way to implement 1 is instead of hard coding the time in the trigger, you can use the Time is Item trigger and set the time in a DateTime Item. You can use DateTime Standalone Widget and DateTime List Item to set the date times.
- The timeline picker already linked
- iCal binding: iCalendar - Bindings | openHAB
