Velbus - Using NodeRed to access special / extra features
Hi all
With great thanks to everyone that has inspired / guided / assisted me in my development, I have built a couple of NodeRed flows that can be used with Velbus hardware.
(and are adaptable to other hardware)
Please note that I haven’t or can’t test these function nodes with all the Velbus modules, as I simply don’t have them all.
I’ll happily help you if you want to develop these function nodes further, but keep in mind that I am not a programmer, so any help is offered on a “best guess” basis.
The best thing to do is take a look at the protocol document for the Velbus module you want to work with and identify the correct packet contents that you are trying to send.
IE
  • What is the command code?
  • How many bytes should the packet have
  • What are the parameters that you are trying to send?
VelbusLink has a great tool in the Logging window that helps you create packets and the checksum
Where I’ve already posted these concepts, I’ll simply add links.
Filtering a Velbus button event
Looping / Increasing / Decreasing a Volume with a Pressed or Long_Pressed event
        "id": "f5370db.29be5f",
        "type": "tab",
        "label": "Media Control",
        "disabled": false,
        "info": ""
        "id": "bfe462be.f71a5",
        "type": "function",
        "z": "f5370db.29be5f",
        "name": "Dining Room Btn 3",
        "func": "var event = msg.payload.event;\nvar channel = msg.payload.channel;\nvar newMsg = { payload: msg.payload.event };\nvar button = \"velbus:vmbgp2:c5053467:24:input#CH3\"\n\nif  (channel === button )  {\n\tif (event === \"PRESSED\") {\n\t\treturn [msg, newMsg, null, null];\n\t}\n\tif (event === \"LONG_PRESSED\") {\n\t\treturn [msg, null, newMsg, null];\n\t}\n\tif (event === \"RELEASED\") {\n\t\treturn [msg, null, null, newMsg];\n\t}\n}\nreturn null;",
        "outputs": 4,
        "noerr": 0,
        "x": 310,
        "y": 140,
        "wires": [
                "6ba85279.a48a9c"
                "82c396c8.6ef1d8"
                "f7ff8751.3c9c78"
        "outputLabels": [
            "Whole Msg",
            "PRESSED",
            "LONG_PRESSED",
            "RELEASED"
        "id": "6ba85279.a48a9c",
        "type": "openhab2-get",
        "name": "",
        "controller": "deaa963.282a968",
        "itemname": "LoungeZone_Volume",
        "x": 1080,
        "y": 180,
        "wires": [
                "b93a65be.3a6588",
                "804f9b5d.8649e8"
        "id": "804f9b5d.8649e8",
        "type": "function",
        "name": "Increase Volume value by 5",
        "func": "var volume = Number(msg.payload.state);\n\nvar newVolume = 0;\n\n//  newVolume = volume + 5;\nmsg.payload = volume;\n\n //       global.set(\"LoungeDir\", 1);\n\nif  (volume <= 90 )  {\n        newVolume = volume + 5;\n        msg.payload = newVolume;\n        return [msg];\n\t}\n\n\n\nreturn [msg];",
        "outputs": 1,
        "noerr": 0,
        "x": 1060,
        "y": 300,
        "wires": [
                "c1079ec5.2dc68"
        "id": "c1079ec5.2dc68",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "x": 1330,
        "y": 280,
        "wires": []
        "id": "4954678d.cca448",
        "type": "openhab2-out",
        "name": "Lounge Volume",
        "topic": "ItemCommand",
        "payload": "",
        "x": 1600,
        "y": 380,
        "wires": [
        "id": "82c396c8.6ef1d8",
        "type": "looptimer",
        "duration": "1",
        "units": "Second",
        "maxloops": "15",
        "maxtimeout": "1",
        "maxtimeoutunits": "Minute",
        "name": "",
        "x": 1040,
        "y": 80,
        "wires": [
                "6ba85279.a48a9c"
        "id": "f7ff8751.3c9c78",
        "type": "change",
        "name": "Stop Loop",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "STOP",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 830,
        "y": 40,
        "wires": [
                "82c396c8.6ef1d8"
        "id": "876a61dd.69f63",
        "type": "function",
        "name": "Dining Room Btn 4",
        "func": "var event = msg.payload.event;\nvar channel = msg.payload.channel;\nvar newMsg = { payload: msg.payload.event };\nvar button = \"velbus:vmbgp2:c5053467:24:input#CH4\"\n\nif  (channel === button )  {\n\tif (event === \"PRESSED\") {\n\t\treturn [msg, newMsg, null, null];\n\t}\n\tif (event === \"LONG_PRESSED\") {\n\t\treturn [msg, null, newMsg, null];\n\t}\n\tif (event === \"RELEASED\") {\n\t\treturn [msg, null, null, newMsg];\n\t}\n}\nreturn null;",
        "outputs": 4,
        "noerr": 0,
        "x": 310,
        "y": 700,
        "wires": [
                "63273679.d5d1d8"
                "e09c3db1.c1954"
                "bf2758a3.db14c8"
        "outputLabels": [
            "Whole Msg",
            "Pressed",
            "Long_Pressed",
        "id": "bf2758a3.db14c8",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "STOP",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 850,
        "y": 680,
        "wires": [
                "e09c3db1.c1954"
        "id": "e09c3db1.c1954",
        "duration": "1",
        "units": "Second",
        "maxloops": "15",
        "maxtimeout": "1",
        "name": "",
        "x": 1060,
        "y": 600,
        "wires": [
                "63273679.d5d1d8"
        "id": "63273679.d5d1d8",
        "name": "",
        "x": 1080,
        "y": 500,
        "wires": [
                "789bcbf6.c86824"
        "id": "789bcbf6.c86824",
        "type": "function",
        "name": "Decrease Volume value by 5",
        "func": "var volume = Number(msg.payload.state);\n\nvar newVolume = 0;\n\n//  newVolume = volume + 5;\nmsg.payload = volume;\n\n        global.set(\"LoungeDir\", -1);\n\nif  (volume >= 10 )  {\n        newVolume = volume - 5;\n        msg.payload = newVolume;\n        return [msg];\n\t}\n\n\n\nreturn [msg];",
        "outputs": 1,
        "noerr": 0,
        "x": 1060,
        "y": 380,
        "wires": [
                "dd34678d.33fb18",
                "4954678d.cca448"
        "id": "dd34678d.33fb18",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 1590,
        "y": 500,
        "wires": []
        "id": "f873928f.82611",
        "type": "link in",
        "name": "openHAB2 Events - Media Control",
        "links": [
            "86e41aa6.fc0848"
        "x": 95,
        "y": 140,
        "wires": [
                "bfe462be.f71a5",
                "876a61dd.69f63"
        "id": "b93a65be.3a6588",
        "type": "function",
        "name": "Change Volume value by 5",
        "func": "// Information from https://nodered.org/docs/user-guide/writing-functions\n\nvar volume = Number(msg.payload.state);\nvar button = String(msg.payload_in);\nvar newMsg = { payload:button};\nvar Dir = global.get(\"LoungeDir\");\n\n\nvar newVolume = 0;\n\n//  newVolume = volume + 5;\nmsg.payload = volume;\n\nif (isNaN(Dir)) {\n     global.set(\"LoungeDir\", 1);\n     Dir = global.get(\"LoungeDir\");\n\n}\n\nif  (volume <= 6 ) { if (Dir == -1)  {\n        newVolume = volume + 5;\n        msg.payload = newVolume;\n        global.set(\"LoungeDir\", 1);\n        return [msg,newMsg];\n\t}}\n\t\nif  (volume <= 90 ) { if (Dir == 1)  {\n        newVolume = volume + 5;\n        msg.payload = newVolume;\n//        global.set(\"LoungeDir\", 1);\n        return [msg,newMsg];\n\t}}\n\t\nif  (volume >= 90 ) { if (Dir == 1)  {\n        newVolume = volume - 5;\n        msg.payload = newVolume;\n        global.set(\"LoungeDir\", -1);\n        return [msg,newMsg];\n\t}}\n\t\nif  (volume <= 90 ) { if (Dir == -1)  {\n        newVolume = volume - 5;\n        msg.payload = newVolume;\n//        global.set(\"LoungeDir\", 1);\n        return [msg,newMsg];\n\t}}\t\n\n\n\nreturn [msg,newMsg];",
        "outputs": 2,
        "noerr": 0,
        "x": 1360,
        "y": 120,
        "wires": [
                "deb42c17.7b645",
                "4954678d.cca448"
                "43fac0f6.8305b"
        "id": "ec5643f1.2da01",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "PRESSED",
        "payloadType": "str",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 340,
        "y": 200,
        "wires": [
                "6ba85279.a48a9c",
                "bf2758a3.db14c8",
                "f7ff8751.3c9c78"
        "id": "deb42c17.7b645",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 1590,
        "y": 220,
        "wires": []
        "id": "43fac0f6.8305b",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 1590,
        "y": 280,
        "wires": []
        "id": "569a9540.f364ec",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "LONG_PRESSED",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 310,
        "y": 240,
        "wires": [
                "82c396c8.6ef1d8",
                "bf2758a3.db14c8"
        "id": "a2023990.27a8e8",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "10",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1370,
        "y": 400,
        "wires": [
                "4954678d.cca448"
        "id": "63c707ec.0969b8",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "RELEASED",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 330,
        "y": 280,
        "wires": [
                "f7ff8751.3c9c78"
        "id": "262ccd.b19f7334",
        "type": "inject",
        "name": "",
        "topic": "",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 336,
        "y": 520,
        "wires": [
                "63273679.d5d1d8",
                "f7ff8751.3c9c78",
                "bf2758a3.db14c8"
        "id": "1a38080c.e48678",
        "type": "inject",
        "name": "",
        "topic": "",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 306,
        "y": 560,
        "wires": [
                "e09c3db1.c1954",
                "f7ff8751.3c9c78"
        "id": "6c6226ed.8bbc18",
        "type": "inject",
        "name": "",
        "topic": "",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 326,
        "y": 600,
        "wires": [
                "bf2758a3.db14c8"
        "id": "aec65e02.e71f2",
        "type": "comment",
        "name": "Oscillating Volume control",
        "info": "This function will oscillate the volume from 05 to 95 and back again",
        "x": 1350,
        "y": 60,
        "wires": []
Set a Timer on a Relay
This uses a TCP node to directly inject values into VelServ
You’ll need to edit the Function node and just enter the base address and required relay channel
        "id": "19e87fb3.6b71e",
        "type": "tcp out",
        "z": "1233381f.cbcdb8",
        "host": "127.0.0.1",
        "port": "6000",
        "beserver": "client",
        "base64": false,
        "end": true,
        "name": "Velserv OUT",
        "x": 2650,
        "y": 180,
        "wires": []
        "id": "29389d4b.a45f02",
        "type": "function",
        "name": "Set channel of Velbus Relay",
        "func": "var address = \"74\"; // Hex address of Relay\nvar channel = \"04\"; // Hex value of Channel No 3 of relay, derived from a bit array = 00100 (as in =bin2hex(00100) in a spreadsheet )\n\n\n\n\n\n// 01 = OFF, 02 = ON, 03 = Timer start\nvar eop = \"04\";\n\nvar a = '0f', b = 'f8', c = address, d = '02', e = '02', f = channel, g = '00', h =\"00\", i = \"00\", y = 'ff';\nvar ndigits = 2, x, carry = 0, z, checksum = \"\";\n\n\nvar incoming = String(msg.payload);\nvar buffer = \"\"\n\n\nvar newMsg =  { payload:incoming };\n\n\nif  (incoming == \"ON\" )  {\n    \n    command = \"02\"; // ON\n    c = address;\n    e = command;\n    f = channel;\n    \nfor (x = ndigits - 1; x >= 0; x--) {\n  z = parseInt(a[x], 16) + parseInt(b[x], 16)+ parseInt(c[x], 16)+ parseInt(d[x], 16)+ parseInt(e[x], 16)+ parseInt(f[x], 16) + carry;\n  carry = z >> 4;\n  checksum = (z & 15).toString(16) + checksum;\n}\n checksum = ((parseInt(y, 16) - parseInt(checksum, 16))+1).toString(16)\n   \n    \n\nnewMsg.payload = checksum;\n\n    \n    \n    \n    \n    \n// Format Pressed event\n// buffer = Buffer.from( [0x0F,0xF8,0x74,0x05,0x03,0x04,0x00,0x00,0x05,0x74,0x04] );\n\nbuffer = Buffer.from([\"0x\"+a.toString(16),\"0x\"+b.toString(16),\"0x\"+c.toString(16),\"0x\"+d.toString(16),\"0x\"+e.toString(16),\"0x\"+f.toString(16),\"0x\"+checksum,0x04])\nreturn [{payload:buffer},newMsg];\n\n\n\t}\n\n\nif  (incoming == \"OFF\" )  {\n    \n command = \"01\"; // OFF\n    c = address;\n    d = size;\n    e = command;\n    f = channel;\n    \n\nfor (x = ndigits - 1; x >= 0; x--) {\n  z = parseInt(a[x], 16) + parseInt(b[x], 16)+ parseInt(c[x], 16)+ parseInt(d[x], 16)+ parseInt(e[x], 16)+ parseInt(f[x], 16) + carry;\n  carry = z >> 4;\n  checksum = (z & 15).toString(16) + checksum;\n}\n checksum = ((parseInt(y, 16) - parseInt(checksum, 16))+1).toString(16)\n   \n    \n\n newMsg.payload = checksum;\n\n\n\nbuffer = Buffer.from([\"0x\"+a.toString(16),\"0x\"+b.toString(16),\"0x\"+c.toString(16),\"0x\"+d.toString(16),\"0x\"+e.toString(16),\"0x\"+f.toString(16),\"0x\"+checksum,0x04])\nreturn [{payload:buffer},newMsg];\n\n\n\t}\n\t\n\t\n\t// Timer value less than 255 seconds\nif  (incoming >= 0 )   { if (incoming <=255) {\n    \n command = \"03\"; // Start Timer\n    c = address;\n    d = \"05\"; // Size\n    e = command;\n    f = channel;\n    i = incoming.toString(16) // Duration of timer in seconds\n    \n\n\n    checksum = parseInt(a, 16) + parseInt(b, 16)+ parseInt(c, 16)+ parseInt(d, 16)+ parseInt(e, 16)+ parseInt(f, 16)+ parseInt(g, 16)+ parseInt(h, 16)+ parseInt(i, 16);\n    checksum = checksum.toString(16);\n    checksum = (parseInt(\"FFFF\",16) - parseInt(checksum,16));\n    checksum = (parseInt(checksum,10)) + 257;\n    checksum = checksum.toString(16);\n    checksum = checksum.slice(-2);\n\n\n newMsg.payload = checksum;\n\n\n\nbuffer = Buffer.from([\"0x\"+a.toString(16),\"0x\"+b.toString(16),\"0x\"+c.toString(16),\"0x\"+d.toString(16),\"0x\"+e.toString(16),\"0x\"+f.toString(16),\"0x\"+g.toString(16),\"0x\"+h.toString(16),\"0x\"+i.toString(16),\"0x\"+checksum,0x04])\nreturn [{payload:buffer},newMsg];\n\n\n\t}}\n\t\n\t\t// Timer value more than 255 seconds and less than 63535 seconds\nif  (incoming >= 255 )   { if (incoming <=63535) {\n    \n command = \"03\"; // Start Timer\n    c = address;\n    d = \"05\"; // Size\n    e = command;\n    f = channel;\n    h = incoming - 255\n    i = (incoming - h).toString(16) // Duration of timer in seconds\n    \n\n\n    checksum = parseInt(a, 16) + parseInt(b, 16)+ parseInt(c, 16)+ parseInt(d, 16)+ parseInt(e, 16)+ parseInt(f, 16)+ parseInt(g, 16)+ parseInt(h, 16)+ parseInt(i, 16);\n    checksum = checksum.toString(16);\n    checksum = (parseInt(\"FFFF\",16) - parseInt(checksum,16));\n    checksum = (parseInt(checksum,10)) + 257;\n    checksum = checksum.toString(16);\n    checksum = checksum.slice(-2);\n\n\n newMsg.payload = checksum;\n\n\n\nbuffer = Buffer.from([\"0x\"+a.toString(16),\"0x\"+b.toString(16),\"0x\"+c.toString(16),\"0x\"+d.toString(16),\"0x\"+e.toString(16),\"0x\"+f.toString(16),\"0x\"+g.toString(16),\"0x\"+h.toString(16),\"0x\"+i.toString(16),\"0x\"+checksum,0x04])\nreturn [{payload:buffer},newMsg];\n\n\n\t}}\n\t\n\tif  (incoming >= 63535 )   {\n\t    newMsg.payload =\"\";\n\t    msg.payload =\"\";\n\t    return;\n\t}\n\t\nreturn [msg,newMsg];",
        "outputs": 2,
        "noerr": 0,
        "x": 2140,
        "y": 180,
        "wires": [
                "1a157d79.4959a3",
                "19e87fb3.6b71e"
                "760977c6.8a7fd8"
        "outputLabels": [
            "Payload, Buffer value to TCP port",
            "Checksum in HEX"
        "id": "1a157d79.4959a3",
        "type": "debug",
        "name": "Full TCP Buffer content",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 2410,
        "y": 120,
        "wires": []
        "id": "760977c6.8a7fd8",
        "type": "debug",
        "name": "Velbus packet Checksum",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 2410,
        "y": 260,
        "wires": []
        "id": "8f1c0497.da7398",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "ON",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1810,
        "y": 140,
        "wires": [
                "29389d4b.a45f02"
        "id": "66c78a16.50a5e4",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "OFF",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1810,
        "y": 180,
        "wires": [
                "29389d4b.a45f02"
        "id": "c11edda3.df313",
        "type": "inject",
        "name": "Timer value in seconds",
        "topic": "",
        "payload": "32",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1840,
        "y": 220,
        "wires": [
                "29389d4b.a45f02"
Set a Dim level and a Fade time, per channel
The Velbus binding in openHAB2 allows for a global dim time to be set per module, so this is only for use where you want to have different dim times for each operation, or when using a VMB4DC and you want a different dim time per channel
        "id": "ba1c35ab.79e078",
        "type": "tcp out",
        "host": "192.168.178.42",
        "port": "6000",
        "base64": false,
        "end": true,
        "name": "Velserv HOUSE OUT",
        "x": 2600,
        "y": 620,
        "wires": []
        "id": "9525a773.a53f38",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 2330,
        "y": 560,
        "wires": []
        "id": "9b9482a.e03158",
        "type": "debug",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 2330,
        "y": 700,
        "wires": []
        "id": "a4d097f4.ee6ac8",
        "type": "function",
        "name": "Set channel of Velbus Dimmer",
        "func": "var address = \"03\"; // Hex address of Relay\nvar channel = \"01\"; // Hex value of Channel No 3 of relay, derived from a bit array = 00100 (as in =bin2hex(00100) in a spreadsheet )\nvar    h = \"00\"; // High byte of dim speed\nvar    i = \"05\"; // Low btye of dim speed\n\n\n\n\nvar eop = \"04\";\n\nvar a = '0f', b = 'f8', c = address, d = '02', e = '02', f = channel, g = '00', y = 'ff';\nvar checksum = \"\";\n\n\nvar incoming = String(msg.payload);\nvar buffer = \"\"\n\n\nvar newMsg =  { payload:incoming };\n\n\nif  (incoming == \"ON\" )  {\n    \n    incoming = 100; // Set Dim value to 100\n\t}\n\n\nif  (incoming == \"OFF\" )   {\n    \n    incoming = 0; // Set Dim value to 0\n\t}\n\t\n\t\n\tif  (incoming >= 0 )   { if (incoming <=101) {\n    \n command = \"07\"; // Set Dim value\n    d = \"05\"; // Size\n    e = command;\n    f = channel;\n    g = incoming.toString(16); // Dim Value\n\n\n\n    checksum = parseInt(a, 16) + parseInt(b, 16)+ parseInt(c, 16)+ parseInt(d, 16)+ parseInt(e, 16)+ parseInt(f, 16)+ parseInt(g, 16)+ parseInt(h, 16)+ parseInt(i, 16);\n    checksum = checksum.toString(16);\n    checksum = (parseInt(\"FFFF\",16) - parseInt(checksum,16));\n    checksum = (parseInt(checksum,10)) + 257;\n    checksum = checksum.toString(16);\n    checksum = checksum.slice(-2);\n\n\n newMsg.payload = checksum;\n\n\n\nbuffer = Buffer.from([\"0x\"+a.toString(16),\"0x\"+b.toString(16),\"0x\"+c.toString(16),\"0x\"+d.toString(16),\"0x\"+e.toString(16),\"0x\"+f.toString(16),\"0x\"+g.toString(16),\"0x\"+h.toString(16),\"0x\"+i.toString(16),\"0x\"+checksum,0x04])\nreturn [{payload:buffer},newMsg];\n\n\n\t}}\n\t\n\n\t\n\tif  (incoming >= 100 )   {\n\t    newMsg.payload =\"\";\n\t    msg.payload =\"\";\n\t    return;\n\t}\n\t\nreturn [msg,newMsg];",
        "outputs": 2,
        "noerr": 0,
        "x": 2070,
        "y": 620,
        "wires": [
                "9525a773.a53f38",
                "ba1c35ab.79e078"
                "9b9482a.e03158"
        "outputLabels": [
            "Checksum in HEX"
        "id": "d8808a88.5fd6a8",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "ON",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1730,
        "y": 580,
        "wires": [
                "a4d097f4.ee6ac8"
        "id": "7daca759.ac6df8",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "OFF",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1730,
        "y": 620,
        "wires": [
                "a4d097f4.ee6ac8"
        "id": "12295b6e.f81f05",
        "type": "inject",
        "name": "Dim Value",
        "topic": "",
        "payload": "75",
        "payloadType": "num",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1720,
        "y": 660,
        "wires": [
                "a4d097f4.ee6ac8"
Change the active Program Group for an Input module
Where Velbus input modules can have 3 different timed events, changing the active group is fairly straightforward.
Inject a Number from 0 to 3
  • 0 = None Active
  • 1 = Group 1 (previously referred to as Winter)
  • 2 = Group 2 (previously referred to as Summer)
  • 3 = Group 3 (previously referred to as Holiday)
Just edit the function node and change the Base of the input module you want to address.
        "type": "function",
        "outputs": 2,
        "noerr": 0,
        "x": 2140,
        "y": 180,
        "wires": [
                "1a157d79.4959a3",
                "19e87fb3.6b71e"
                "760977c6.8a7fd8"
        "outputLabels": [
            "Checksum in HEX"
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 2410,
        "y": 120,
        "wires": []
        "type": "tcp out",
        "port": "6000",
        "base64": false,
        "end": true,
        "x": 2650,
        "y": 180,
        "wires": []
        "type": "debug",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 2410,
        "y": 260,
        "wires": []
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "ON",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1810,
        "y": 140,
        "wires": [
                "29389d4b.a45f02"
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "OFF",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1810,
        "y": 180,
        "wires": [
                "29389d4b.a45f02"
        "type": "inject",
        "topic": "",
        "payload": "32",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 1840,
        "y": 220,
        "wires": [
                "29389d4b.a45f02"
Lock and Unlock input module channels
Velbus Input modules can have their channels disabled for a period of time or permanently.
This flow demonstrates how channels can be disabled for 10 seconds.
You’ll notice that groups of channels can be disabled / enabled in a single packet.
        "id": "81eaba1c.e3e6e8",
        "type": "function",
        "name": "Lock Channel for 10 seconds",
        "func": "var address = \"A0\"; // Hex address of Input Module\nvar channel = \"01\"; // Hex value of Channel No 3 of module, derived from a bit array = 00100 (as in =bin2hex(00100) in a spreadsheet )\n\n\n\n// a is the Start of Packet - 0F\n// b is the priority - Low FB, Hight F8\n// c is the base address of the module\n// d is the amount of bytes in the packet, for program group this is 02\n// e is the command - in this case 12 - Forced OFF, with Timeout, 13 Cancel force OFF\n// f is the channel number, as set by 'channel' above\n// g is high byte of time\n// h is middle byte of time\n// i is low byte of time\n// eop is End of Packet - always 04\n\n\nvar a = '0f', b = 'F8', c = address, d = '05', e = '12', f = '00', g = '00', h = '00', i = '00', y = 'ff';\nvar checksum = \"\";\nvar eop = \"04\";\n\nvar incoming = String(msg.payload);\nvar buffer = \"\"\n\n\nvar newMsg =  { payload:incoming };\n\n\n// if  (incoming === 'LOCK' )  {  // Uncomment if filtering\n// Lock channel   \n    c = address;\n//    f = channel; // uncomment to use channel value as set in header\n    f = incoming.toString(16); // Comment out to use channel value as set in header\n    g = '00';  // High byte of timeout\n    h = '00'; // middle byte of timeout\n    i = '0a'; // low byte of timeout, in seconds (For example '0A' is 10 seconds)\n    \n\n\n    checksum = parseInt(a, 16) + parseInt(b, 16)+ parseInt(c, 16)+ parseInt(d, 16)+ parseInt(e, 16)+ parseInt(f, 16)+ parseInt(g, 16)+ parseInt(h, 16)+ parseInt(i, 16);\n    checksum = checksum.toString(16);\n    checksum = (parseInt(\"FFFF\",16) - parseInt(checksum,16));\n    checksum = (parseInt(checksum,10)) + 257;\n    checksum = checksum.toString(16);\n    checksum = checksum.slice(-2);\n\n\n newMsg.payload = checksum;\n\n\nbuffer = Buffer.from([\"0x\"+a.toString(16),\"0x\"+b.toString(16),\"0x\"+c.toString(16),\"0x\"+d.toString(16),\"0x\"+e.toString(16),\"0x\"+f.toString(16),\"0x\"+g.toString(16),\"0x\"+h.toString(16),\"0x\"+i.toString(16),\"0x\"+checksum,0x04])\nreturn [{payload:buffer},newMsg];\n\n\n//\t} // Uncomment if filtering\n\n\t\n// return [msg,newMsg]; // uncomment if using IF statement",
        "outputs": 2,
        "noerr": 0,
        "x": 580,
        "y": 1360,
        "wires": [
                "710aad6a.7e9ba4",
                "e297be30.26819"
                "697d4733.d0d308"
        "outputLabels": [
            "Checksum in HEX"
        "id": "710aad6a.7e9ba4",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 1150,
        "y": 1260,
        "wires": []
        "id": "697d4733.d0d308",
        "type": "debug",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 1210,
        "y": 1460,
        "wires": []
        "id": "b8f1b813.31b8b8",
        "type": "inject",
        "name": "Lock All",
        "topic": "",
        "payload": "FF",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 230,
        "y": 1360,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "e297be30.26819",
        "type": "tcp out",
        "port": "6000",
        "base64": false,
        "end": true,
        "x": 1150,
        "y": 1360,
        "wires": []
        "id": "d9558ad7.3776e8",
        "type": "inject",
        "name": "Lock Channel 1",
        "topic": "",
        "payload": "1",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1400,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "34f78464.63ee1c",
        "type": "inject",
        "name": "Lock Channel 2",
        "topic": "",
        "payload": "2",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1440,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "a5bae3ef.181a9",
        "type": "inject",
        "name": "Lock Channel 3",
        "topic": "",
        "payload": "4",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1480,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "12032eb6.d12341",
        "type": "inject",
        "name": "Lock Channel 4",
        "topic": "",
        "payload": "8",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1520,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "58089764.3aafe8",
        "type": "inject",
        "name": "Lock Channel 5",
        "topic": "",
        "payload": "10",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1560,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "88ca3d61.5b729",
        "type": "inject",
        "name": "Lock Channel 6",
        "topic": "",
        "payload": "20",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1600,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "de753314.c7307",
        "type": "inject",
        "name": "Lock Channel 7",
        "topic": "",
        "payload": "40",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1640,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "168c9f60.b57dd1",
        "type": "inject",
        "name": "Lock Channel 8",
        "topic": "",
        "payload": "80",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 260,
        "y": 1680,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "a41a3968.6539d8",
        "type": "inject",
        "name": "Lock Even Channels",
        "topic": "",
        "payload": "AA",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 250,
        "y": 1720,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "a242c8fe.b54628",
        "type": "inject",
        "name": "Lock ODD Channels",
        "topic": "",
        "payload": "55",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 250,
        "y": 1760,
        "wires": [
                "81eaba1c.e3e6e8"
        "id": "ec3291b5.089b",
        "type": "function",
        "name": "Unlock Channel",
        "func": "var address = \"A0\"; // Hex address of Input Module\nvar channel = \"01\"; // Hex value of Channel No 3 of module, derived from a bit array = 00100 (as in =bin2hex(00100) in a spreadsheet )\n\n\n\n// a is the Start of Packet - 0F\n// b is the priority - Low FB, Hight F8\n// c is the base address of the module\n// d is the amount of bytes in the packet, for program group this is 02\n// e is the command - in this case 13 Cancel force OFF\n// f is the channel number, as set by 'channel' above\n// g is high byte of time\n// h is middle byte of time\n// i is low byte of time\n// eop is End of Packet - always 04\n\n\nvar a = '0f', b = 'F8', c = address, d = '02', e = '13', f = '00', g = '00', h = '00', i = '00', y = 'ff';\nvar checksum = \"\";\nvar eop = \"04\";\n\nvar incoming = String(msg.payload);\nvar buffer = \"\"\n\n\nvar newMsg =  { payload:incoming };\n\n\n// if  (incoming === 'UNLOCK' )  {  // Uncomment if filtering\n// Unlock channel   \n    c = address;\n    d = '02';\n//    f = channel; // uncomment to use channel value as set in header\n    f = incoming.toString(16); // Comment out to use channel value as set in header\n//    g = '00';  // High byte of timeout\n//    h = '00'; // middle byte of timeout\n//    i = '0a'; // low byte of timeout, in seconds (For example '0A' is 10 seconds)\n    \n\n\n    checksum = parseInt(a, 16) + parseInt(b, 16)+ parseInt(c, 16)+ parseInt(d, 16)+ parseInt(e, 16)+ parseInt(f, 16);\n    checksum = checksum.toString(16);\n    checksum = (parseInt(\"FFFF\",16) - parseInt(checksum,16));\n    checksum = (parseInt(checksum,10)) + 257;\n    checksum = checksum.toString(16);\n    checksum = checksum.slice(-2);\n\n\n newMsg.payload = checksum;\n\n\nbuffer = Buffer.from([\"0x\"+a.toString(16),\"0x\"+b.toString(16),\"0x\"+c.toString(16),\"0x\"+d.toString(16),\"0x\"+e.toString(16),\"0x\"+f.toString(16),\"0x\"+checksum,0x04])\nreturn [{payload:buffer},newMsg];\n\n\n//\t} // Uncomment if filtering\n\n\t\n// return [msg,newMsg]; // uncomment if using IF statement",
        "outputs": 2,
        "noerr": 0,
        "x": 840,
        "y": 1520,
        "wires": [
                "e297be30.26819",
                "710aad6a.7e9ba4"
                "697d4733.d0d308"
        "outputLabels": [
            "Checksum in HEX"
        "id": "592d71f0.7eb81",
        "type": "inject",
        "name": "UnLock All",
        "topic": "",
        "payload": "FF",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 540,
        "y": 1520,
        "wires": [
                "ec3291b5.089b"
        "id": "9af0f060.43a44",
        "type": "inject",
        "name": "UnLock Channel 1",
        "topic": "",
        "payload": "1",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1560,
        "wires": [
                "ec3291b5.089b"
        "id": "dc8a583e.d2e628",
        "type": "inject",
        "name": "UnLock Channel 2",
        "topic": "",
        "payload": "2",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1600,
        "wires": [
                "ec3291b5.089b"
        "id": "7f032873.744308",
        "type": "inject",
        "name": "UnLock Channel 3",
        "topic": "",
        "payload": "4",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1640,
        "wires": [
                "ec3291b5.089b"
        "id": "a1213a05.af15e8",
        "type": "inject",
        "name": "UnLock Channel 4",
        "topic": "",
        "payload": "8",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1680,
        "wires": [
                "ec3291b5.089b"
        "id": "46727131.59a68",
        "type": "inject",
        "name": "UnLock Channel 5",
        "topic": "",
        "payload": "10",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1720,
        "wires": [
                "ec3291b5.089b"
        "id": "faab023b.f5ca6",
        "type": "inject",
        "name": "UnLock Channel 6",
        "topic": "",
        "payload": "20",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1760,
        "wires": [
                "ec3291b5.089b"
        "id": "7a6aad8d.ec96f4",
        "type": "inject",
        "name": "UnLock Channel 7",
        "topic": "",
        "payload": "40",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1800,
        "wires": [
                "ec3291b5.089b"
        "id": "92283226.4193a",
        "type": "inject",
        "name": "UnLock Channel 8",
        "topic": "",
        "payload": "80",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 570,
        "y": 1840,
        "wires": [
                "ec3291b5.089b"
        "id": "d0431189.daa83",
        "type": "inject",
        "name": "UnLock Even Channels",
        "topic": "",
        "payload": "AA",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 580,
        "y": 1880,
        "wires": [
                "ec3291b5.089b"
        "id": "4d060314.57bcdc",
        "type": "inject",
        "name": "UnLock ODD Channels",
        "topic": "",
        "payload": "55",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 580,
        "y": 1920,
        "wires": [
                "ec3291b5.089b"
@gertst
Has created a fabulous set of NodeRed nodes to give us access to the more advanced features of velbus
Take a look at his nodes here
node-red-contrib-velbus (node) - Node-RED
