Xiaomi Mi IO Binding missing
Okay, so I have installed the Xiaomi Mi Smart Home binding and it works well. Now, I wanted to install the Mi IO Binding so I can control the Xiaomi Bedside lamp.
I’m configuring everything on my new raspberry pi with raspbian. Previously I had everything in my Windows PC.
To install the Mi IO Binding I had to install the Eclipse IoT and after that enable ALFA bindings. After doing that I was able to install the binding from Paper UI. I’m trying this from linux and I can’t find any Mi IO binding in Paper UI.
Any idea? Maybe Paper UI’s config is not working?
Look for errors in the logs. The IoT Marketplace might be having a certificate problem. If so see [SOLVED] Failed downloading Marketplace entries: Received fatal alert: handshake_failure - #5 by CDriver
Thank you very much, this solved the problem! Only needed to copy thar jar files to the zulu’s security folder.
