I just installed a couple of new thermostats from Thermofloor “HeatIt Z-TRM2fx”. These show up as the (older) Z-TRM2, as they share manufacturer “019B” and type/id “0003:0202”. The FW version on mine is 3.4.
Specifically I wanted the display to show “measured temp” instead of “setpoint”. I then had to set parameter 14 to 1 although the current database shows parameter 14 as something completely else.
Anyone else tried these new devices or have more info on this?
Thanks sihui for the reply.
I should have mentioned that I already opened an issue on cd-jackson.com, but @chris wanted me to move it to the community, probably to avoid breaking the database for those using the original Z-TRM2.
I assume that @OMR may have some input on what FW version, etc. the original is using.
The device is working just fine, but the config-database needs an update, and I believe one of the temperature channels (sensor_temperature4) is not in use. (Maybe more?)
I remember they briefly had a v2.9 that were withdrawn, and there was a 2.11 mentioned here.
Note that the Z-TRM2 has OTA FW update only. (The USB cable used on earlier devices cannot be used.)
If the new Z-TRM2fx is using the same Type/ID with a totally different parameter set, is that an error on their part, or is it OK to differentiate on the FW version only? (my experience is lacking here)
All I know is that a database update must not break compatibility with the Z-TRM2 with FW 2.6, 2.9 & 2.11.
How they will handle the replacement Z-TRM2 due in Q1-2 2019 remains to be seen, but if their re-use of Type/ID was wrong, we should contact them so they don’t make the same mistake twice. (trice)
So based on this, @toffyrn your device is being detected correctly. If there is now a newer version than 2.6, then we need a new database entry (I’m assuming that the current entry for 2.6 is correct for 2.6, so please check this first, but I guess that 3.4 is new).
Question time…
Is 3.4 new? (I guess so)
If so, when did the parameters change? (I guess at 3.4, and I assume there is no eg. 2.8 or 3.2).
If so, we need to set the maximum version for this entry to 3.3, and create a new version for 3.4, copy over the current parameters as a starting point, and change the ones that are different
I agree with all your guessing @chris.
What is your thought about them (rush) releasing a floor-sensor only version (fx) with a different parameter set?
Had it been cleaner with a new ID?
And what about the ‘real’ Z-TRM2 replacement due in Q1-2/19? If they don’t change the ID we end up in an even messier situation.
It doesn’t matter too much if they keep the same IDs. The database uses IDs and firmware versions to differentiate different devices. Personally, I’m happy if they keep the same IDs and just change the versions (I think this is what Aeotec do as well). It is cleaner (IMHO) as if you have a device with ID 1234:5678, and you update the firmware, then the ID should stay the same.
Now if the devices are physically different models, then yes, they should have different IDs in my opinion.
So long as there is no overlap if IDs and firmware versions though, it’s ok. We see with the list above that the TRM2 has a different set of IDs, so it seems that is what they are doing.
The Z-TRM2fx running 3.4 is fairly new, was launched early December if I recall correctly; doubt they have multiple fw-versions for that already… I therefore second your opinion on just setting the max. version to 3.3 and create a new for >=3.4. Let me know if you like med to attempt editing the db.
Thinking about it, it looks like Thermofloor is using FW 1.* for the first model (TF016), 2.* for the second model (Z-TRM2), and 3.* for the newest (Z-TRM2fx). It probably does not matter though as long as no device with FW 3.3 is released…
I have started on updating the device tonight, but will have to continue tomorrow.
One strange thing @chris: When I uploaded manual and images to the new device (980), somehow they got uploaded to the old device copied from (854). On the second try they were uploaded to the correct device. Unsure if this is only my view, or if these attachments actually ended up to 854. I had both devices open in separate tabs, may be a bug?
Anyways, thanks for the effort put into making device database simple to edit.
Nice to hear @wasperen. The simplest solution for me, in order to show measured temp on display, was to set Param 14 to 1 although it is (incorrectly) displayed as “room sensor calibration”. Otherwise mine are working great.
I was hoping to contribute to the device database, but got confused regarding multichannel. Awaiting answer from @chris in order to get that correct. Hopefully I learn something along the way
