Thanks for adding this!
As discussed, Iāll now remove it again
ā¦
Great, thanks.
Iāve noticed one thing that doesnāt work yet, if i use the physical switch to turn the relay on or off, the change of state is not reflected in openhab.
That should work in the most recent binding - during initialisation the binding should send a ābindā command to the device to tell it to report its status. Itās possible this didnāt work, or that the device doesnāt support this - can you grab a log of the initialisation of the binding and send it over?
Just a note on this - Iāve ordered up a switch for testing which should arrive in the next day or so, so Iāll try and look at getting something into the binding next week to provide some level of support for this (no promises though as I go on holiday for 2 weeks after that and no doubt my partner will have other ideas for my time
Thatās incredibly nice of you, thanks. And whenever you have time is fine with me, enjoy your holiday!
Iāve installed snapshot 2.2.0~20171203035709-1 but itās still not working.
I donāt know if that snapshot already contains your latest changes, so Iāve created an issue with the requested log.
Thanks. I wouldnāt expect any changes relating to this issue with the latest version. Can you tell me what node ID, or IEEE address the device is?
Hi Chris,
Thanks so much for working on this. I am super excited to add zigbee capabilities to my openhab and get rid of the smartthings hub completely. Would you please let me when the dresden zigbee usb stick is fully working? ![]()
all the best,
Emre
p.s. i wrote this same message to your another post by mistakeā¦
Ah ok, I thought the coordinator should already send a ābindā command to the relay with the latest version of the binding.
I currently have two relays in the network:
D85DEF11A1002826: ZigBee node property discovery complete: {zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, modelId=RM01, zigbee_networkaddress=45692, zigbee_powersource=MAINS, zigbee_stkversion=1, zigbee_datecode=20161209, zigbee_zclversion=1, vendor=Busch-Jaeger, zigbee_appversion=1, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS, RECHARGABLE_BATTERY, DISPOSABLE_BATTERY], hardwareVersion=0}
and
D85DEF11A1001973: ZigBee node property discovery complete: {zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, modelId=RM01, zigbee_networkaddress=31084, zigbee_powersource=MAINS, zigbee_stkversion=1, zigbee_datecode=20161209, zigbee_zclversion=1, vendor=Busch-Jaeger, zigbee_appversion=1, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS, RECHARGABLE_BATTERY, DISPOSABLE_BATTERY], hardwareVersion=0}
Yes - but that was also in the previous version⦠So, no change from the previous version, but I still would have expected it to workā¦
Thanks - Iāll take a look at the logs nowā¦
Letās continue this discussion on the GH issueā¦
@chris: I got myself a Qivicon stick now, because I got pretty frustrated with the TI dongles when experimenting with other zigbee frameworks to get my Xiaomi devices to some use. I found some instructions on flashing the Ember stack onto those devices as well. So, my question is: which stack is your preferred one for the OH binding?
After a quick test, I saw that the stick (with the DTAG Telegesis fimrware) stayed in āinitializingā state, but I could definitly see some communictaion going on in the logs. I didnāt investigate depper, but I wanted to know whatās your currently preferred stack before taking any other actions with the stick.
Is there any progress on getting the Xiaomi devices to work? A quick glance at the log output suggests that the devices donāt seem to get completetly discovered, because they seem to not respond to some queries during discovery.
Hi @chris, I have been busy these days, but I finally could dedicate some time to this. Detection of attributes is working fine (even if for RGB color vs Color Temperature the right check would probably be looking at ColorMode attribute instead).
Just one question, what is the best way to share the new code and modifications? (Color helper class for XY to Hue/Sat conversions and diffs for the ZigBeeConverterColor classes). Maybe sending you a personal message with the new ColorHerleper class and the diffs for the others ?
BTW, I noticed that when reloading the binding (by updating the jar) I see the following message in the logs:
2017-12-08 12:39:49.342 [WARN ] [ome.core.thing.internal.ThingManager] - Disposing handler for thing 'zigbee:coordinator_cc2531:461477c7' takes more than 5000ms.
And the old instances of the converters get still called after the reload (this was driving me crazy as I thought there was something wrong in my code due to some strange related behaviours).
This was not happening to me in the previous snapshot of the binding, and I have worked it around by setting āinitialised = falseā in ādisposeConverter()ā and then checking for its value in āattributeUpdated()ā, but this makes me think there is something wrong in the underlying code.
On the changes made, I am checking for color attribute compatibility early in āgetChannel()ā so that we can return ānullā for ColorTemperature channel in RGB bulbs, and also the other way round. This way a dummy, useless channel is not created for this kind of bulbs.
I also added a helper āsupportsAttribute()ā method for checking specific attribute compatibility in āZigBeeChannelConverterā, so that it can be used in all converters, but I think it would probably fit better in āZclClusterā directly.
Right now, the Telegesis stick is the most tested.
The binding can do this too ![]()
Feel free to provide a log. The DTAG firmware is the same (roughly) as the standard Telegesis firmware, and is heavily tested by me now using different versions of the DTAG firmware and they all work fine for me. IF you have an issue, please provide the log and Iāll have a look.
No - not by me anyway. Iām focusing on standard ZigBee devices at the moment.
The best approach would be to provide a PR into the repo on Githubā¦
If you prefer, then I can also look at this, but a PR would be better.
Can you tell where itās blocking? I donāt think the shutdown should do much that takes any significant time.
Maybe the shutdown code isnāt called - Iām not sure about this, but Iāll checkā¦
Ok, why canāt CT be used? Do some bulbs not support this?
We might need to have a think if this is ok or not. I also want to do some attribute checks in the getChannel method, so this needs to be done, but we need to ensure that we donāt end up with things waiting too long, or being called twice while these checks take place as it can take many (many!) seconds to perform in some cases depending on the device
Yes, this should be in the cluster class - if you want to add it, please create a PR, althernatively if you prefer I can add it as itās only a couple of lines of codeā¦
Thanks.
Cheers
Chris
I will check with the PR. Not using git too much, and I need to check how to do it, but probably the good way to go.
I see that the disposeConverter is called at least (because it does set āinitialisedā to false in my code), but there must be something after it that gets blocked. Will have a look at it, but will have to dig further into the openhab / binding code
Lights that support ColorControl cluster, in my understanding, support either Color or CT, but not both at the same time (ColorMode attribute is either 0 for Hue/Sat, 1 for XY, 2 for CT).
But anyway the check in getChannel is done both in ZigBeeConverterColorTemperature and ZigBeeConverterColorColor, so if for some reason a light supports both, both channels will be created.
The implementation I have done of the supportsAttribute method caches the result (so discoverAttributes will be called only once per channel if in ZigBeeChannelConverter, or once for all if in ZclCluster).
Agreed, also putting it in the cluster class makes the cached info available for all calls, so it will not be repeated, i.e, for each channel. Also the code is simpler there, and we can benefit of the (looks like currently unused) isImplemented() method in ZclAttribute. I will move it there then.
Yes, but⦠While they only control one mode at once, you must still provide both CT and color channels as the bulb can switch between the two modes at any time. We canāt have channels randomly changing - only if a device doesnāt support the CT command would it be safe/correct not to provide the CT channel. Likewise - only if it doesnāt support any of the color commands and only supports the CT command would it be correct not to provide the color channel.
Iām not completely sure what this means (no problem though - Iāll see later
), but my concern is that if the binding updates the node while the channel discovery is occurring, then we could end up with multiple threads running this code if it takes time. If the device is a battery device, it will take some time for this to respond.
Thatās excatly what I am doing ![]()
I understand. Will check if there may be any concurrency issues but, are there many battery powered lights that would be sleeping during discovery ? I would expect this for switches, buttons, etc, but not for lights.
Perfect ![]()
Who knows - probably not. However, as I said before, I also have this requirement for other sensors - IAS requires this as in order to find out if itās a motion sensor, water sensor etc, we need to read some attributes. This is what I was looking at yesterday (specifically, adding an IAS CIE to process the ST multisensors).
