ON the latest 2.5 snapshot binding. Added the aeotec z stick and 3 z wave contact sensors and range extender 6 . All shown to be online with no errors in Paper UI or Habadmin. Is it normal to have no updates on any of the readings after 2 days?
No. Check your association groups.
Should the first association group be the nearest node or the controller/repeater?
You need to look that up in your manual: mostly it is Group 1 or Lifeline which needs to be set to the controller.
I tried putting the controller as the Group 1 lifeline but no readings came even after 24 hours, so I switch it to the repeater. Is there a way to “force” a z wave update? these are all coolcam contact sensors, NAS DS01Z to be exact.
Since you are using 2.5, the binding should do this anyway - no matter what you set.
Have you looked in the logs to see what is being received (if anything)? What channels are you using?
Are you referring to the openhab.log? Where do I find z wave errors?
What do you mean by channels? something like these?
zwave:device:bff1230f:node2:sensor_door
zwave:device:bff1230f:node2:alarm_tamper
zwave:device:bff1230f:node2:sensor_binary
zwave:device:bff1230f:node2:battery-level
these are the 4 channels which I link to an new item each on paper UI
Just restarted my openhab and these are the errors:
2019-01-13 21:16:09.076 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'channel' of item 'Sonoffps3_Temperature' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: UID segment 'DS18B20.temperature' contains invalid characters. The last segment of the channel UID must match the pattern '[\w-]*|[\w-]*#[\w-]*'.
at org.eclipse.smarthome.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:83) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:73) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:397) [129:org.eclipse.smarthome.model.item:0.11.0.201901111358]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:350) [129:org.eclipse.smarthome.model.item:0.11.0.201901111358]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.addBindingConfigReader(GenericItemProvider.java:164) [129:org.eclipse.smarthome.model.item:0.11.0.201901111358]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1813) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:436) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [39:org.apache.felix.scr:2.1.14]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.14]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.14]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
more messages from openhab.log but they dont seem to be errors
2019-01-13 21:16:09.957 [.ItemChannelLinkAddedEvent] - Link 'Sonoff_Action-mqtt:topic:mosB:version' has been added.
2019-01-13 21:16:09.959 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps1_RSSI-mqtt:topic:sonoffps1:rssi' has been added.
2019-01-13 21:16:09.960 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_Power-mqtt:topic:ups04:power' has been added.
2019-01-13 21:16:09.961 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_Voltage-mqtt:topic:ups05:voltage' has been added.
2019-01-13 21:16:09.962 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps2_FW-mqtt:topic:sonoffps2:version' has been added.
2019-01-13 21:16:09.963 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_Load-mqtt:topic:ups05:powerload' has been added.
2019-01-13 21:16:09.964 [.ItemChannelLinkAddedEvent] - Link 'Rackfan_RSSI-mqtt:topic:rackfan:rssi' has been added.
2019-01-13 21:16:09.964 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_Energy-mqtt:topic:ups04:total' has been added.
2019-01-13 21:16:09.965 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Button_4-mqtt:topic:bridge1:button4' has been added.
2019-01-13 21:16:09.966 [.ItemChannelLinkAddedEvent] - Link 'Rackfan_Reachable-mqtt:topic:rackfan:reachable' has been added.
2019-01-13 21:16:09.967 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Right_Window-mqtt:topic:bridge1:rightwindow' has been added.
2019-01-13 21:16:09.968 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_Voltage-mqtt:topic:ups04:voltage' has been added.
2019-01-13 21:16:09.969 [.ItemChannelLinkAddedEvent] - Link 'Rackfan_Power-mqtt:topic:rackfan:power' has been added.
2019-01-13 21:16:09.971 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps3_Power-mqtt:topic:sonoffps3:power' has been added.
2019-01-13 21:16:09.972 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_Energy-mqtt:topic:ups05:total' has been added.
2019-01-13 21:16:09.973 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_FW-mqtt:topic:bridge1:version' has been added.
2019-01-13 21:16:09.974 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps2_Power-mqtt:topic:sonoffps2:power' has been added.
2019-01-13 21:16:09.979 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_RSSI-mqtt:topic:ups04:rssi' has been added.
2019-01-13 21:16:09.979 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Received_RfKey-mqtt:topic:bridge1:receivedrfkey' has been added.
2019-01-13 21:16:09.980 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps3_RSSI-mqtt:topic:sonoffps3:rssi' has been added.
2019-01-13 21:16:09.981 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Received_Low-mqtt:topic:bridge1:receivedlow' has been added.
2019-01-13 21:16:09.982 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Button_3-mqtt:topic:bridge1:button3' has been added.
2019-01-13 21:16:09.983 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_RSSI-mqtt:topic:bridge1:rssi' has been added.
2019-01-13 21:16:09.984 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Received_Sync-mqtt:topic:bridge1:receivedsync' has been added.
2019-01-13 21:16:09.985 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps1_Reachable-mqtt:topic:sonoffps1:reachable' has been added.
2019-01-13 21:16:09.986 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Reachable-mqtt:topic:bridge1:reachable' has been added.
2019-01-13 21:16:09.987 [.ItemChannelLinkAddedEvent] - Link 'Date-ntp:ntp:local:dateTime' has been added.
2019-01-13 21:16:09.988 [.ItemChannelLinkAddedEvent] - Link 'Time-ntp:ntp:local:dateTime' has been added.
2019-01-13 21:16:09.990 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Left_Window-mqtt:topic:bridge1:leftwindow' has been added.
2019-01-13 21:16:09.994 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_FW-mqtt:topic:ups05:version' has been added.
2019-01-13 21:16:10.001 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps2_Reachable-mqtt:topic:sonoffps2:reachable' has been added.
2019-01-13 21:16:10.003 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_Reachable-mqtt:topic:ups04:reachable' has been added.
2019-01-13 21:16:10.004 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_Reachable-mqtt:topic:ups05:reachable' has been added.
2019-01-13 21:16:10.004 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps1_Power-mqtt:topic:sonoffps1:power' has been added.
2019-01-13 21:16:10.005 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Button_2-mqtt:topic:bridge1:button2' has been added.
2019-01-13 21:16:10.005 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_FW-mqtt:topic:ups04:version' has been added.
2019-01-13 21:16:10.005 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_Current-mqtt:topic:ups04:current' has been added.
2019-01-13 21:16:10.006 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Centre_Window-mqtt:topic:bridge1:centrewindow' has been added.
2019-01-13 21:16:10.006 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_Power-mqtt:topic:ups05:power' has been added.
2019-01-13 21:16:10.010 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps1_FW-mqtt:topic:sonoffps1:version' has been added.
2019-01-13 21:16:10.011 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps3_FW-mqtt:topic:sonoffps3:version' has been added.
2019-01-13 21:16:10.011 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_Current-mqtt:topic:ups05:current' has been added.
2019-01-13 21:16:10.012 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps2_RSSI-mqtt:topic:sonoffps2:rssi' has been added.
2019-01-13 21:16:10.012 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups04_Load-mqtt:topic:ups04:powerload' has been added.
2019-01-13 21:16:10.012 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Received_High-mqtt:topic:bridge1:receivedhigh' has been added.
2019-01-13 21:16:10.013 [.ItemChannelLinkAddedEvent] - Link 'Rackfan_FW-mqtt:topic:rackfan:version' has been added.
2019-01-13 21:16:10.013 [.ItemChannelLinkAddedEvent] - Link 'Sonoffps3_Reachable-mqtt:topic:sonoffps3:reachable' has been added.
2019-01-13 21:16:10.014 [.ItemChannelLinkAddedEvent] - Link 'Sonoffups05_RSSI-mqtt:topic:ups05:rssi' has been added.
2019-01-13 21:16:10.018 [.ItemChannelLinkAddedEvent] - Link 'Bridge1_Button_1-mqtt:topic:bridge1:button1' has been added.
2019-01-13 21:16:10.054 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216804_LineCurrent-mqtt:topic:sonoffups04:current' has been added.
2019-01-13 21:16:10.055 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorFrontdoor_TamperAlarm-zwave:device:bff1230f:node3:alarm_tamper' has been added.
2019-01-13 21:16:10.055 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216805_WiFiSignalStrength-mqtt:topic:sonoffups05:rssi' has been added.
2019-01-13 21:16:10.056 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoShowLivingRoom_AccessPoint-unifi:wirelessClient:home:ECHOSHOW:ap' has been added.
2019-01-13 21:16:10.056 [.ItemChannelLinkAddedEvent] - Link 'XPS13Pink_AccessPoint-unifi:wirelessClient:home:XPS13_9360:ap' has been added.
2019-01-13 21:16:10.057 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216804_LineVoltage-mqtt:topic:sonoffups04:voltage' has been added.
2019-01-13 21:16:10.057 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorFrontdoor_DoorSensor-zwave:device:bff1230f:node3:sensor_door' has been added.
2019-01-13 21:16:10.059 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216805_LineVoltage-mqtt:topic:sonoffups05:voltage' has been added.
2019-01-13 21:16:10.059 [.ItemChannelLinkAddedEvent] - Link 'BroadlinkRMProPlusLivingRoom_AccessPoint-unifi:wirelessClient:home:RMPROPLUS:ap' has been added.
2019-01-13 21:16:10.060 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_ReceivedChecksumErrors-zwave:serial_zstick:bff1230f:serial_cse' has been added.
2019-01-13 21:16:10.060 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_StartFrames-zwave:serial_zstick:bff1230f:serial_sof' has been added.
2019-01-13 21:16:10.060 [.ItemChannelLinkAddedEvent] - Link 'XPS13Pink_Online-unifi:wirelessClient:home:XPS13_9360:online' has been added.
2019-01-13 21:16:10.062 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_LastSeen-unifi:wirelessClient:home:GALAXYS3:lastSeen' has been added.
2019-01-13 21:16:10.063 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_ReceivedSignalStrengthIndicator-unifi:wirelessClient:home:ECHO:rssi' has been added.
2019-01-13 21:16:10.063 [.ItemChannelLinkAddedEvent] - Link 'BroadlinkRMProPlusLivingRoom_Online-unifi:wirelessClient:home:RMPROPLUS:online' has been added.
2019-01-13 21:16:10.064 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_WirelessNetwork-unifi:wirelessClient:home:GALAXYS3:essid' has been added.
2019-01-13 21:16:10.065 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_Online-unifi:wirelessClient:home:GALAXYS3:online' has been added.
2019-01-13 21:16:10.065 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216805_TotalEnergyToday-mqtt:topic:sonoffups05:total' has been added.
2019-01-13 21:16:10.065 [.ItemChannelLinkAddedEvent] - Link 'LocalTime_Date-ntp:ntp:local:dateTime' has been added.
2019-01-13 21:16:10.066 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoShowLivingRoom_Online-unifi:wirelessClient:home:ECHOSHOW:online' has been added.
2019-01-13 21:16:10.071 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoShowLivingRoom_SiteName-unifi:wirelessClient:home:ECHOSHOW:site' has been added.
2019-01-13 21:16:10.071 [.ItemChannelLinkAddedEvent] - Link 'JonSOnePlus5_MACAddress-unifi:wirelessClient:home:OP5:macAddress' has been added.
2019-01-13 21:16:10.074 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorDiningRoomSideDoor_TamperAlarm-zwave:device:bff1230f:node4:alarm_tamper' has been added.
2019-01-13 21:16:10.074 [.ItemChannelLinkAddedEvent] - Link 'LocalTime_Date-ntp:ntp:local:string' has been added.
2019-01-13 21:16:10.075 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_AccessPoint-unifi:wirelessClient:home:ECHO:ap' has been added.
2019-01-13 21:16:10.076 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_Uptime-unifi:wirelessClient:home:ECHO:uptime' has been added.
2019-01-13 21:16:10.083 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216805_Power-mqtt:topic:sonoffups05:power' has been added.
2019-01-13 21:16:10.083 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216804_TotalEnergyToday-mqtt:topic:sonoffups04:total' has been added.
2019-01-13 21:16:10.086 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_SiteName-unifi:wirelessClient:home:IPHONE7:site' has been added.
2019-01-13 21:16:10.086 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoShowLivingRoom_LastSeen-unifi:wirelessClient:home:ECHOSHOW:lastSeen' has been added.
2019-01-13 21:16:10.086 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_OOFBytesReceived-zwave:serial_zstick:bff1230f:serial_oof' has been added.
2019-01-13 21:16:10.087 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorFrontdoor_BinarySensor-zwave:device:bff1230f:node3:sensor_binary' has been added.
2019-01-13 21:16:10.087 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_Online-unifi:wirelessClient:home:IPHONE7:online' has been added.
2019-01-13 21:16:10.089 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesRejected-zwave:serial_zstick:bff1230f:serial_nak' has been added.
2019-01-13 21:16:10.108 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_MACAddress-unifi:wirelessClient:home:ECHODOT:macAddress' has been added.
2019-01-13 21:16:10.108 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode005ZW117RangeExtender6_ColorTemperature-zwave:device:bff1230f:node5:color_temperature' has been added.
2019-01-13 21:16:10.109 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_IPAddress-unifi:wirelessClient:home:ECHODOT:ipAddress' has been added.
2019-01-13 21:16:10.109 [.ItemChannelLinkAddedEvent] - Link 'XPS13Pink_LastSeen-unifi:wirelessClient:home:XPS13_9360:lastSeen' has been added.
2019-01-13 21:16:10.109 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216804_Reachable-mqtt:topic:sonoffups04:reachable' has been added.
2019-01-13 21:16:10.110 [.ItemChannelLinkAddedEvent] - Link 'XPS13Pink_WirelessNetwork-unifi:wirelessClient:home:XPS13_9360:essid' has been added.
2019-01-13 21:16:10.110 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_Uptime-unifi:wirelessClient:home:GALAXYS3:uptime' has been added.
2019-01-13 21:16:10.110 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_WirelessNetwork-unifi:wirelessClient:home:IPHONE7:essid' has been added.
2019-01-13 21:16:10.111 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_SiteName-unifi:wirelessClient:home:ECHO:site' has been added.
2019-01-13 21:16:10.111 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_IPAddress-unifi:wirelessClient:home:IPHONE7:ipAddress' has been added.
2019-01-13 21:16:10.111 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorPlayroomWindow_DoorSensor-zwave:device:bff1230f:node2:sensor_door' has been added.
2019-01-13 21:16:10.112 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_LastSeen-unifi:wirelessClient:home:ECHO:lastSeen' has been added.
2019-01-13 21:16:10.114 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_Uptime-unifi:wirelessClient:home:ECHODOT:uptime' has been added.
2019-01-13 21:16:10.115 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_IPAddress-unifi:wirelessClient:home:GALAXYS3:ipAddress' has been added.
2019-01-13 21:16:10.115 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesAcknowledged-zwave:serial_zstick:bff1230f:serial_ack' has been added.
2019-01-13 21:16:10.115 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_MACAddress-unifi:wirelessClient:home:ECHO:macAddress' has been added.
2019-01-13 21:16:10.116 [.ItemChannelLinkAddedEvent] - Link 'BroadlinkRMProPlusLivingRoom_IPAddress-unifi:wirelessClient:home:RMPROPLUS:ipAddress' has been added.
2019-01-13 21:16:10.121 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_LastSeen-unifi:wirelessClient:home:ECHODOT:lastSeen' has been added.
2019-01-13 21:16:10.122 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_MACAddress-unifi:wirelessClient:home:GALAXYS3:macAddress' has been added.
2019-01-13 21:16:10.124 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorDiningRoomSideDoor_DoorSensor-zwave:device:bff1230f:node4:sensor_door' has been added.
2019-01-13 21:16:10.131 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_ReceivedSignalStrengthIndicator-unifi:wirelessClient:home:ECHODOT:rssi' has been added.
2019-01-13 21:16:10.138 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorPlayroomWindow_BinarySensor-zwave:device:bff1230f:node2:sensor_binary' has been added.
2019-01-13 21:16:10.139 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoShowLivingRoom_ReceivedSignalStrengthIndicator-unifi:wirelessClient:home:ECHOSHOW:rssi' has been added.
2019-01-13 21:16:10.144 [.ItemChannelLinkAddedEvent] - Link 'PS3Powerstrip22URack_Temperature-mqtt:topic:sonoffps3:temperature' has been added.
2019-01-13 21:16:10.145 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_Online-unifi:wirelessClient:home:ECHODOT:online' has been added.
2019-01-13 21:16:10.147 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_AccessPoint-unifi:wirelessClient:home:IPHONE7:ap' has been added.
2019-01-13 21:16:10.147 [.ItemChannelLinkAddedEvent] - Link 'XPS13Pink_SiteName-unifi:wirelessClient:home:XPS13_9360:site' has been added.
2019-01-13 21:16:10.149 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesCancelled-zwave:serial_zstick:bff1230f:serial_can' has been added.
2019-01-13 21:16:10.150 [.ItemChannelLinkAddedEvent] - Link 'XPS13Pink_MACAddress-unifi:wirelessClient:home:XPS13_9360:macAddress' has been added.
2019-01-13 21:16:10.150 [.ItemChannelLinkAddedEvent] - Link 'BroadlinkRMProPlusLivingRoom_ReceivedSignalStrengthIndicator-unifi:wirelessClient:home:RMPROPLUS:rssi' has been added.
2019-01-13 21:16:10.151 [.ItemChannelLinkAddedEvent] - Link 'JonSOnePlus5_IPAddress-unifi:wirelessClient:home:OP5:ipAddress' has been added.
2019-01-13 21:16:10.243 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode005ZW117RangeExtender6_ColorControl-zwave:device:bff1230f:node5:color_color' has been added.
2019-01-13 21:16:10.245 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216805_PowerLoad-mqtt:topic:sonoffups05:powerload' has been added.
2019-01-13 21:16:10.245 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoShowLivingRoom_Uptime-unifi:wirelessClient:home:ECHOSHOW:uptime' has been added.
2019-01-13 21:16:10.246 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216804_Power-mqtt:topic:sonoffups04:power' has been added.
2019-01-13 21:16:10.249 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode005ZW117RangeExtender6_Dimmer-zwave:device:bff1230f:node5:switch_dimmer' has been added.
2019-01-13 21:16:10.250 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_WirelessNetwork-unifi:wirelessClient:home:ECHO:essid' has been added.
2019-01-13 21:16:10.250 [.ItemChannelLinkAddedEvent] - Link 'JonSOnePlus5_LastSeen-unifi:wirelessClient:home:OP5:lastSeen' has been added.
2019-01-13 21:16:10.250 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorDiningRoomSideDoor_BinarySensor-zwave:device:bff1230f:node4:sensor_binary' has been added.
2019-01-13 21:16:10.251 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_AccessPoint-unifi:wirelessClient:home:GALAXYS3:ap' has been added.
2019-01-13 21:16:10.251 [.ItemChannelLinkAddedEvent] - Link 'GalaxyS3ForRMProPlusLivingRoom_SiteName-unifi:wirelessClient:home:GALAXYS3:site' has been added.
2019-01-13 21:16:10.252 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_Uptime-unifi:wirelessClient:home:IPHONE7:uptime' has been added.
2019-01-13 21:16:10.252 [.ItemChannelLinkAddedEvent] - Link 'JonSOnePlus5_Online-unifi:wirelessClient:home:OP5:online' has been added.
2019-01-13 21:16:10.253 [.ItemChannelLinkAddedEvent] - Link 'BroadlinkRMProPlusLivingRoom_WirelessNetwork-unifi:wirelessClient:home:RMPROPLUS:essid' has been added.
2019-01-13 21:16:10.253 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216804_PowerLoad-mqtt:topic:sonoffups04:powerload' has been added.
2019-01-13 21:16:10.254 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_ReceivedSignalStrengthIndicator-unifi:wirelessClient:home:IPHONE7:rssi' has been added.
2019-01-13 21:16:10.254 [.ItemChannelLinkAddedEvent] - Link 'UPSFor19216805_Reachable-mqtt:topic:sonoffups05:reachable' has been added.
2019-01-13 21:16:10.255 [.ItemChannelLinkAddedEvent] - Link 'KellySIphone7_MACAddress-unifi:wirelessClient:home:IPHONE7:macAddress' has been added.
2019-01-13 21:16:10.255 [.ItemChannelLinkAddedEvent] - Link 'BroadlinkRMProPlusLivingRoom_LastSeen-unifi:wirelessClient:home:RMPROPLUS:lastSeen' has been added.
2019-01-13 21:16:10.258 [.ItemChannelLinkAddedEvent] - Link 'ContactSensorDiningRoomSideDoor_BatteryLevel-zwave:device:bff1230f:node4:battery-level' has been added.
2019-01-13 21:16:10.259 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoKidsBedroom_Online-unifi:wirelessClient:home:ECHO:online' has been added.
2019-01-13 21:16:10.262 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_WirelessNetwork-unifi:wirelessClient:home:ECHODOT:essid' has been added.
2019-01-13 21:16:10.263 [.ItemChannelLinkAddedEvent] - Link 'AmazonEchoDotMasterBedroom_SiteName-unifi:wirelessClient:home:ECHODOT:site' has been added.
More logs again
2019-01-13 21:16:19.767 [vent.ItemStateChangedEvent] - Sonoffps3_RSSI changed from NULL to 100
2019-01-13 21:16:19.780 [vent.ItemStateChangedEvent] - PS3Powerstrip22URack_Temperature changed from NULL to 35.2
2019-01-13 21:16:19.789 [vent.ItemStateChangedEvent] - Sonoff_FW_Available changed from NULL to v6.4.1
2019-01-13 21:16:21.501 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:bff1230f' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-01-13 21:16:21.517 [hingStatusInfoChangedEvent] - 'zwave:device:bff1230f:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-01-13 21:16:21.528 [hingStatusInfoChangedEvent] - 'zwave:device:bff1230f:node4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-01-13 21:16:21.529 [hingStatusInfoChangedEvent] - 'zwave:device:bff1230f:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-01-13 21:16:21.529 [hingStatusInfoChangedEvent] - 'zwave:device:bff1230f:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-01-13 21:16:21.535 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:bff1230f' has been updated.
2019-01-13 21:16:21.829 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 11 to 12
2019-01-13 21:16:21.832 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 11 to 12
2019-01-13 21:16:21.840 [hingStatusInfoChangedEvent] - 'zwave:device:bff1230f:node5' changed from ONLINE to ONLINE: Node initialising: PING
2019-01-13 21:16:21.846 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 12 to 13
2019-01-13 21:16:21.851 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 12 to 13
2019-01-13 21:16:21.867 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 13 to 14
2019-01-13 21:16:21.880 [hingStatusInfoChangedEvent] - 'zwave:device:bff1230f:node5' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2019-01-13 21:16:21.885 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 13 to 14
2019-01-13 21:16:21.893 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 14 to 15
2019-01-13 21:16:21.921 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 15 to 16
2019-01-13 21:16:21.949 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 14 to 15
2019-01-13 21:16:21.955 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 16 to 17
2019-01-13 21:16:21.972 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 17 to 18
2019-01-13 21:16:21.982 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 18 to 19
2019-01-13 21:16:21.998 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 15 to 16
2019-01-13 21:16:22.002 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 19 to 20
2019-01-13 21:16:22.024 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 20 to 21
2019-01-13 21:16:22.029 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 21 to 22
2019-01-13 21:16:22.037 [vent.ItemStateChangedEvent] - ZWaveNode005ZW117RangeExtender6_Dimmer changed from NULL to 100
2019-01-13 21:16:22.038 [vent.ItemStateChangedEvent] - ZWaveNode005ZW117RangeExtender6_ColorControl changed from NULL to 0,0,100
2019-01-13 21:16:22.080 [hingStatusInfoChangedEvent] - 'zwave:device:bff1230f:node5' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
January 13
Yes - this is normally the log.
In the openhab log file, but you need to enable debug logging with the log:set DEBUG org.openhab.binding.zwave command
Hmmm - maybe you need to read the docs if you don’t know what channels are
Channels are the data streams that you link your items to. These are what the binding updates when it receives data from the divide.
Sorry - it’s not really very useful. This is the binding startup, but very little else. Can you provide a longer binding (maybe 1 hour) as an log and not as an image.
Do you mean to upload the entire openhab.log file?
Ok, will do so when I get back home. Thanks
Yes - thanks.
here it is
[https://drive.google.com/open?id=1BS7Yp9_hx-R867rx03_mlpbZiy9gdWo8]
much thanks
Thanks.
I assume from your earlier comments where you listed the items (eg zwave:device:bff1230f:node2:sensor_door
) that we are looking at node 2? If so, there is no communication with this device in the log. We only see the node identity frame which comes from the controller, not the device.
It looks like the device has not been initialised - or maybe I’m looking at the wrong device? If it’s not initialised, then you will need to wake the device up manually so that the binding is able to communicate with it to configure things like the wakeup period.
Hi @chris,
thank you very much!! Sorry for the late reaction.
Before the last update of the ZWave binding the Danfoss thermostats sometimes changed the temperature setpoint to the new value, sometimes they didn’t. In contrast to the Comet thermostat, which accepted the setpoint immediately at the time of its wakeup. See: [SOLVED] Rule doesn't work
The new situation after updating the ZWave binding is as I wrote: the Danfoss thermostats only accept or change the setpoint when I manually wake them up twice. After the first wakeup there’s no change, during the second wakeup I can observe the change of the temperature setpoint with a delay of about 1 to 2 seconds. The Comet thermostat reliably keeps on doing its job.
Do you have any further ideas or recommendations?
Cheers
Christoph
Actually , none of my z wave devices (node 2, 3 and 4. Node 5 is the repeater) is giving any readings.
I will look at the others tonight, but for now node 2 needs initialising as I said earlier. If you are saying the logs for the other devices are the same, then it’s likely I will come up with the same statement for them as well
I just woke up all the 3 nodes. If it does not work, would I need to reset the controller and all the nodes again?
Not really - as I said, from the logfile this is not what I see. The data is transferred to the device on the first wakeup and I can’t really see anything wrong.
Node 2, 3 and 4 all look the same - they have not been woken up during the duration of the log at least. Node 5 seems to be working fine.
