Hi all,
after my update to OH2.5 my Zwave controller is going offline in a cycle - on and off every minute. I tried the solutions from this post, but it didn’t help to far.
Any thoughts , @chris or anybody else? Thanks in advance…
Jan
Plattform:
- Openhap is 2.5.1-2
 - OS is Debian 4.19.67
 - Hardware MiniATX with a IntelCeleron processor; Zwave controller is an aeotec gen5 usb stick
addons.cfg is auto-generated and void including only comments
/var/lib/openhab2/config/org/openhab/addons.config look like this after I removed pushbullet and restdocs
binding="sonos,ntp,mqtt1,http1,gpio,fritzboxtr0641,fritzbox1,exec,chromecast,network,expire1,weather1,astro,zwave,serial1"
package="standard"
persistence="rrd4j,mapdb"
remote="true"
service.pid="org.openhab.addons"
transformation="javascript,jsonpath,exec,map,regex"
ui="basic,paper,habpanel,habmin"
I’m not sure if this Zwave log helps in this case, but anyhow the first seconds seems to show the re-initiatization of the controller:
2020-01-23 00:04:51.735 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-01-23 00:04:56.959 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-01-23 00:04:56.960 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-01-23 00:05:57.064 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-01-23 00:05:57.065 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-01-23 00:06:32.073 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-01-23 00:06:37.242 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-01-23 00:06:37.242 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-01-23 00:06:42.689 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
2020-01-23 00:07:31.799 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-01-23 00:07:36.908 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-01-23 00:07:36.909 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-01-23 00:08:31.471 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-01-23 00:08:36.589 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-01-23 00:08:36.589 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-01-23 00:09:28.997 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.006 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.016 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.028 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.039 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.051 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.059 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.068 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.077 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.086 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.096 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.107 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.118 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Handler disposed. Unregistering listener.
2020-01-23 00:09:29.128 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing receive thread
2020-01-23 00:09:29.128 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Receive thread dispose
2020-01-23 00:09:29.128 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing serial connection
2020-01-23 00:09:29.128 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Serial connection disposed
2020-01-23 00:09:29.129 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2020-01-23 00:09:29.131 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Deactivate zwave:serial_zstick:4bd824b3
2020-01-23 00:09:31.496 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Creating ZWave discovery service for zwave:serial_zstick:4bd824b3 wi$
2020-01-23 00:09:31.497 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Active zwave:serial_zstick:4bd824b3
2020-01-23 00:09:31.498 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-01-23 00:09:31.559 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2020-01-23 00:09:31.560 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:4bd824b3.
2020-01-23 00:09:31.611 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node7.
2020-01-23 00:09:31.612 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node13.
2020-01-23 00:09:31.621 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node6.
2020-01-23 00:09:31.648 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:switch_binary linked - p$
2020-01-23 00:09:31.649 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:meter_watts linked - pol$
2020-01-23 00:09:31.651 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:config_decimal_param42 l$
2020-01-23 00:09:31.652 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:alarm_power linked - pol$
2020-01-23 00:09:31.652 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_binary linked -$
2020-01-23 00:09:31.650 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:config_decimal_param41 l$
2020-01-23 00:09:31.650 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:meter_reset linked - pol$
2020-01-23 00:09:31.649 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:meter_kwh linked - polli$
2020-01-23 00:09:31.656 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_co linked - pol$
2020-01-23 00:09:31.656 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_temperature lin$
2020-01-23 00:09:31.656 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_heat linked - po$
2020-01-23 00:09:31.656 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE ...
