I have a question. In my systems i have a “All Lights OFF”
In my Log tail it looks light that
“2018-12-27 23:12:40.420 [DEBUG] [bnet.handler.OpenWebNetBridgeHandler] - ==OWN== ownId=0 has NO THING associated, ignoring it”
So all lights are off and my openhab don’t recognize it → because of the “All Lights OFF” Switch.
Have i forgot something? or isn’t it integrated yet?
Thank you guys for your great work and affort.
bg Patrick
Sorry but I do not think I understood your problem well, if you intend to use AMB, GR and GEN (Environment, Groups and General) are not implemented.
If you have a scene module (MH200N , MH202, ecc. )then you can create a scene with CEN + activation and configure the command to OH, but you have to binding beta9-1 and follow this example.
Or publish the configuration part, .things and .items
Hello all
I have a problem with heating sitemap
Logs:
2018-12-28 09:25:27.339 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘gC_SdB_thermo’ for widget org.eclipse.smarthome.model.sitemap.Text
Hi Patrick (@k0nti),
this issue has been raised already see here: OpenWebNet: group commands [WHERE=#n ?].
Feedbacks from group WHEREs (#0) events are not supported yet in the binding.
At least someone has to file a new issue, or it will never be tracked (and solved).
this has been already reported by some users, I suggest you file a new Issue with some relevant and well formatted log when this happens, or it will not be tracked.
programs
Programs are not supported yet, and for example this Heating Program 01 message is not handled: 2018-12-28 09: 55: 36.786 [WARN] [penwebnet.message.openMessageFactory] - ## openwebnet ## unsupported WHAT 1101 from frame *4*1101*#0##
Again here a new issue should be added, or it will not be tracked.
The rest of unsupported messages: WHAT=21,22,23 are not relevant and useful here.
Hi everyone,
If we want Massimo to help us with the implementation or corrections of problems, we have to write an issue here , once certain of the problem. There are no other ways
Ok, some debug logs follow. The first is after a fresh start with beta 9.1 without attempting to discover the gateway (MHS1). As you can see upnp discovers the gateway (and the tv and the router).
2018-12-28 20:37:37.913 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.1.77
2018-12-28 20:37:38.143 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Rome'.
2018-12-28 20:37:38.155 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '44.4048,8.9444'.
2018-12-28 20:37:38.160 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'it_IT'.
2018-12-28 20:37:38.425 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-12-28 20:37:38.502 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-12-28 20:37:42.480 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.1.77
2018-12-28 20:37:49.780 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-28 20:37:52.650 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.205:8080
2018-12-28 20:37:52.653 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.205:8443
2018-12-28 20:37:53.065 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-12-28 20:37:53.838 [DEBUG] [org.openhab.binding.openwebnet ] - BundleEvent STARTING - org.openhab.binding.openwebnet
2018-12-28 20:37:53.843 [DEBUG] [org.openhab.binding.openwebnet ] - BundleEvent STARTED - org.openhab.binding.openwebnet
2018-12-28 20:37:53.865 [ERROR] [org.openhab.binding.openwebnet ] - bundle org.openhab.binding.openwebnet:2.4.0.201812262319 (222)[org.openhab.binding.openwebnet.internal.OpenWebNetHandlerFactory] : Cannot register component
org.osgi.service.component.ComponentException: The component name 'org.openhab.binding.openwebnet.internal.OpenWebNetHandlerFactory' has already been registered by Bundle 222 (org.openhab.binding.openwebnet) as Component of Class org.openhab.binding.openwebnet.internal.OpenWebNetHandlerFactory
at org.apache.felix.scr.impl.ComponentRegistry.checkComponentName(ComponentRegistry.java:235) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.loadDescriptor(BundleComponentActivator.java:443) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialize(BundleComponentActivator.java:315) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.<init>(BundleComponentActivator.java:270) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:379) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-12-28 20:37:54.009 [DEBUG] [org.openhab.binding.openwebnet ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=358, service.bundleid=222, service.scope=bundle, component.name=org.openhab.binding.openwebnet.internal.OpenWebNetHandlerFactory, component.id=216} - org.openhab.binding.openwebnet
2018-12-28 20:37:54.038 [DEBUG] [ery.OpenWebNetBridgeDiscoveryService] - #############################################################################################
2018-12-28 20:37:54.041 [DEBUG] [ery.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery== constructor()
2018-12-28 20:37:54.044 [DEBUG] [ery.OpenWebNetBridgeDiscoveryService] - #############################################################################################
2018-12-28 20:37:54.053 [DEBUG] [org.openhab.binding.openwebnet ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=359, service.bundleid=222, service.scope=bundle, component.name=org.openhab.binding.openwebnet.internal.discovery, component.id=217} - org.openhab.binding.openwebnet
2018-12-28 20:37:54.093 [DEBUG] [org.openhab.binding.openwebnet ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={service.id=360, service.bundleid=222, service.scope=bundle, component.name=org.openhab.binding.openwebnet.internal.discovery.BusGatewayDiscoveryParticipant, component.id=218} - org.openhab.binding.openwebnet
2018-12-28 20:37:55.067 [INFO ] [overy.BusGatewayDiscoveryParticipant] - ================================================
2018-12-28 20:37:55.069 [INFO ] [overy.BusGatewayDiscoveryParticipant] - ==OWN:UPnP== DISCOVERED DEVICE: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:pnp-myhomeserver1-2_2-00:03:50:A4:69:C9, Descriptor: http://192.168.1.114:49152/, Root: true
2018-12-28 20:37:55.071 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =FRIENDLY NAME: MyHomeSERVER1
2018-12-28 20:37:55.078 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =BASE URL : null
2018-12-28 20:37:55.080 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =SERIAL # : 00:03:50:A4:69:C9
2018-12-28 20:37:55.089 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =UPC :
2018-12-28 20:37:55.105 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =ID.DESC URL : http://192.168.1.114:49152/
2018-12-28 20:37:55.107 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =ID.MAX AGE : 500
2018-12-28 20:37:55.123 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =MANUFACTURER : BTicino S.p.A.
2018-12-28 20:37:55.127 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =MODEL : MyHomeServer1 | MYHOMESERVER1 | 2.2
2018-12-28 20:37:55.213 [INFO ] [overy.BusGatewayDiscoveryParticipant] - ================================================
2018-12-28 20:37:55.215 [INFO ] [overy.BusGatewayDiscoveryParticipant] - ==OWN:UPnP== DISCOVERED DEVICE: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:49b7f49e-d2fa-4f36-94e2-22e8903569ce, Descriptor: http://192.168.1.254:5000/rootDesc.xml, Root: true
2018-12-28 20:37:55.217 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =FRIENDLY NAME: MediaAccess DGA4131FWB (1811JC1DM)
2018-12-28 20:37:55.219 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =BASE URL : null
2018-12-28 20:37:55.223 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =SERIAL # : 1811JC1DM
2018-12-28 20:37:55.228 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =UPC : null
2018-12-28 20:37:55.229 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =ID.DESC URL : http://192.168.1.254:5000/rootDesc.xml
2018-12-28 20:37:55.232 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =ID.MAX AGE : 120
2018-12-28 20:37:55.233 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =MANUFACTURER : Technicolor
2018-12-28 20:37:55.235 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =MODEL : MediaAccess DG | Technicolor Internet Gateway Device | Technicolor DGA4131FWB
2018-12-28 21:44:05.975 [INFO ] [overy.BusGatewayDiscoveryParticipant] - ================================================
2018-12-28 21:44:05.978 [INFO ] [overy.BusGatewayDiscoveryParticipant] - ==OWN:UPnP== DISCOVERED DEVICE: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:00000000-0000-1010-8000-ac9b0a0e2638, Descriptor: http://192.168.1.184:52323/dmr.xml, Root: true
2018-12-28 21:44:05.980 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =FRIENDLY NAME: BRAVIA KD-49X8505B
2018-12-28 21:44:05.982 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =BASE URL : null
2018-12-28 21:44:05.983 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =SERIAL # : null
2018-12-28 21:44:05.985 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =UPC : null
2018-12-28 21:44:05.986 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =ID.DESC URL : http://192.168.1.184:52323/dmr.xml
2018-12-28 21:44:05.988 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =ID.MAX AGE : 1800
2018-12-28 21:44:05.989 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =MANUFACTURER : Sony Corporation
2018-12-28 21:44:05.992 [INFO ] [overy.BusGatewayDiscoveryParticipant] - =MODEL : KD-49X8505B | null | MINT1.7.0.1
Michele (@gozilla01) and Marco (@col_1958 ).
Automatic finding of BTicino gateway is not implemented yet, never said it is!, it’s also well written in the (in)famous README.
I am away from PC these days, I will write you in a separate thread to help me doing some tests about gateway automatic discovery.
bye!
M
this time I’am innocent! I’ve RTFM! I provided some debug listing just for the purpose of testing automatic discovery of the gateway. I can confirm that UPNP correctly finds the IP address of the server.
Just for understanding.
Where is the jar file of OWH when one installs from eclipse?
Can I open (and read) the jar file in Visual Studio Code?
Can I play with the java code and do tests on my own?
