Hi all,
As announced by Kai, OH 3.1 is out and it includes support for Thermo (WHO=4) on the official openwebnet binding. A big thanks to @aconte80 for the effort spent on the Thermo part!
Note that compared to the old testing version, Thermo things and channels have been renamed:
bus_thermostat → bus_thermo_zone
bus_temp_sensor → bus_thermo_sensor
Refer to the official binding README for details on the new Thermo channels names.
For now, only standalone mode (aka residential mode) has been tested thoughtfully with a real plant: for those who have 4-zone or 99-zone Central Units, try it and tell us what you are missing in this thread.
Next step for the binding will be support for CEN and CEN+: will open a dedicated thread for this shortly.
Hello everybody, is there any news about the plan to include CEN/CEN+ support in the OH3 binding?
In the meanwhile, if this can help someone, I am using this code to enable double press detection. This way you have 3 options:
Long press
Single (short) press
Double (short) press
This works reliably if your double press is not too quick (e.g. more or less half a second between the first and the second press). If you double press too quickly, OH interprets it as a single press.
In my specific case:
Long press = All rollershutters UP
Single (short) press = All rollershutters STOP
Double (short) press = Activate a scenario (defined in a separate rule)
Here’s the code:
var Timer buttonTimerUp = null
rule "Traccia pulsante dummy generale Tapp SU (pressione prolungata) e dai il comando a gTapparelle"
Item iDummy_CEN_Gen_Tapp_SU_rem changed to "RELEASED_EXT"
gTapparelle.sendCommand(UP)
rule "Traccia pulsante dummy generale Tapp SU (pressione breve) e dai il comando a gTapparelle o accendi modalità estate (giorno)"
Item iDummy_CEN_Gen_Tapp_SU_rem changed to "RELEASED"
logInfo("bticino.rules", "button UP pressed")
if (buttonTimerUp === null) {
gTapparelle.sendCommand(STOP)
// start the timer
logWarn("bticino.rules", "Timer Up started")
buttonTimerUp = createTimer(now.plusSeconds(2)) [ |
// if the timer expires
logWarn("bticino.rules", "Timer Up expired")
logInfo("bticino.rules", "--> Button UP SINGLE pressed")
// reset the timer
else {
// within the timer window
logInfo("bticino.rules", "--> Button UP DOUBLE pressed")
Chiudi_Tapparelle_Modalita_Estate_Giorno.sendCommand(ON)
// reset the timer
buttonTimerUp.cancel
rule "Chiudi tapparelle modalità estate (giorno)"
Item Chiudi_Tapparelle_Modalita_Estate_Giorno received command ON
iCucina_tapp1.sendCommand(0)
iCucina_tapp2.sendCommand(80)
Hallo. Thanks all for this beautiful binding. I have a question. How can I create an item with command 610*4000## to open the lock of an external gate? Thanks
Hi, from same week, i don’t can use the binding, becouse have this error: 'openwebnet:bus_gateway:mybridg' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR)
I have installed version 2.5.0.M2-2, and i have tied to unistall and reinstall, but it give me the same error. How i can solve?
Hello @massi,
first of all I’d like to thank you and all the contributors for the great work. I have been using your binding for the last couple years, with great satisfaction.
I just wanted to ask you if there is any update about CEN/CEN+ and if you can point me to the dedicated thread (once it will be opened). Of course if you find it useful I can test and report back, since I use CEN+ in my setup. Thank you!
Since a few days I’m experiencing issues with the Openwebnet binding.
At some point, I start getting the “CMD is not connected” error.
Even if I cannot send commands, status messages keep working and I can see Items update whenever I turn on/off a light or move a shutter using pushbuttons.
I’ve been able to fix this behavior with a reboot (restarting openhab.service didn’t fix it), but this is the second time in 3 days that this happens, so I’m afraid it will happen again in a few days.
This is the “CMD is not connected” error I was getting before reboot
2021-07-25 15:02:58.372 [DEBUG] [.handler.OpenWebNetAutomationHandler] - Exception while sending request for command DOWN: CMD is not connected
org.openwebnet4j.communication.OWNException: CMD is not connected
at org.openwebnet4j.communication.OpenConnector.sendCommandSynch(OpenConnector.java:115) ~[bundleFile:?]
at org.openwebnet4j.OpenGateway.sendInternal(OpenGateway.java:175) ~[bundleFile:?]
at org.openwebnet4j.OpenGateway.send(OpenGateway.java:155) ~[bundleFile:?]
at org.openhab.binding.openwebnet.handler.OpenWebNetThingHandler.send(OpenWebNetThingHandler.java:173) ~[bundleFile:?]
at org.openhab.binding.openwebnet.handler.OpenWebNetAutomationHandler.handleShutterCommand(OpenWebNetAutomationHandler.java:214) [bundleFile:?]
at org.openhab.binding.openwebnet.handler.OpenWebNetAutomationHandler.handleChannelCommand(OpenWebNetAutomationHandler.java:183) [bundleFile:?]
at org.openhab.binding.openwebnet.handler.OpenWebNetThingHandler.handleCommand(OpenWebNetThingHandler.java:136) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor64.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy936.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor63.invoke(Unknown Source) ~[?:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Before reboot, while checking systemctl status openhab.service, I was getting this warn, which was still there even after rebooting and was fixed by running systemctl daemon-reload:
The unit file, source configuration file or drop-ins of openhab.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Even after reboot, I keep getting a lot of these exceptions:
Jul 25 15:49:20 openhabian karaf[735]: Exception in thread "Thread-1191" java.lang.NullPointerException
Jul 25 15:49:20 openhabian karaf[735]: at org.openhab.binding.openwebnet.handler.OpenWebNetEnergyHandler.handleMessage(OpenWebNetEnergyHandler.java:184)
Jul 25 15:49:20 openhabian karaf[735]: at org.openhab.binding.openwebnet.handler.OpenWebNetBridgeHandler.onEventMessage(OpenWebNetBridgeHandler.java:437)
Jul 25 15:49:20 openhabian karaf[735]: at org.openwebnet4j.OpenGateway.lambda$onMessage$4(OpenGateway.java:188)
Jul 25 15:49:20 openhabian karaf[735]: at java.base/java.util.ArrayList.forEach(ArrayList.java:1541)
Jul 25 15:49:20 openhabian karaf[735]: at org.openwebnet4j.OpenGateway$1.run(OpenGateway.java:274)
Jul 25 15:49:20 openhabian karaf[735]: at java.base/java.lang.Thread.run(Thread.java:834)
I am running 3.1.0 on Openhabian (RPI4).
Please let me know if you need any other info to help debugging this error.
today it happened again.
This time I just stopped and started the openhab service, without rebooting the PI.
Since it seemed that the issue was somehow related to the energy handler, I have removed the Energy Meter related Things and it seems that I am not getting any more errors right now.
I’ll keep you posted.
@Rob-VF the flooding bug should be included in OH 3.2M1 which should be published in these days, after it’s published you can update directly from the official distribution/openhabian
@Gieffe70 welcome to the community!
For this command to be sent, a generic “send message” command should be added to the binding. Not started to work on it yet.
@AEM I did some progress on the CEN/CEN+ support (completed the library part under the hood) but the summer holiday period does not give too much spare time to spend on the binding. Surely I will post here some news as soon as I have a version that can be tested by users like you.
This looks like a bug!
If you get this after reboot, you should post some more logs before this exception is launched, at least starting from the point the last openwebnet message is received (they are all logged when they are received from the BTicino gateway). And if the problem is related to the Energy Meter, then you should re-enable it for the problem to appear again.
