For my Enyaq I still have issues. It works better that before, but it is not stable. I cannot find a pattern in when it updates. The binding is set to the default 15 minutes, but sometimes no updates are received for several hours, and at other times it works fine with updates every 15 minutes. And it is not all values that are updated with the same pattern. E.g. charging_level this morning updated fine when while I was charging, but when I went to work, it did not decrease until 2,5 hours after I reached work. Odometer is not updated, and car_moving is always ON. Parking time is correct (at least now), but has probably been updated later than the timestamp reveals. Iām running on the snapshot I downloaded on Feb. 2nd.
/feldt
i am currently struggling with the refresh token. i will publish a new version as soon as refreshing it works fine
- fixed skoda-e token refresh
- carMoving probably not working; cannot test because enyaq is at the dealer for the battery recall
ā¦testingā¦
@tknaller, thanks for you awesome work! All channels of my Enyaq are working now and are updating properly (well, as proper as the skoda server works thoughā¦). If you have a paypal account Iād like to spend you at least a good coffee or something
carMoving seems to work, it seems the garage is taking it for a spin occassionally and openHAB state matches App state
@ulrichpa that is very kind of you. but i cannot take that much credit for the binding, I am only butchering the work of @markus7017
edit: just got my car back and yep carMoving works
- Skoda-E carMoving now really correct
- put WeConnect & Skoda-E Channels in Groups
still not fully working:
- CarNet Commands (@MAO)
- Multiple Vehicles under same Account
did i miss another bugreport-post?
Oh, some additional channelsā¦
Still missing the picture URLs, though (there were seven URLs for pictures of the car, shown in the Main UI Car widget - see the very first posting of this thread)
VW ID. 3 here
i tried to find the image urls - i was not succesful.
it seems that the images are embedded in the app now and the status from the API just tells the app which one to renderā¦or I am just blind in my network trace
Considering the number of vehicle options on the market I doubt that all those images were moved to app now, or rendered locally.
With reference to WeConnect-MQTT I interpret https://vehicle-images-service.apps.emea.vwapps.io/v2/vehicle-images/{self.vin.value}?resolution=2x
is used to query (here, #377), then publish binaries in mqtt topics āpictures/carā and āpictures/statusā. Forgive me if this just wrong, I crawled the scripts only with very basic understanding. Another discussion reports a change off from that domain to https://weconnect.volkswagen-we.com
in 2021 - maybe this was moved back?
ConnectedCar binding queried several images more in the past, but those published by weconnect-mqtt are the main ones.
Even with the latest snapshot_20230212 I am not able to connect to my VW wallbox. With my User/PW I always get "Initialization failed: class org.openhab.binding.connectedcar.internal.api.ApiSecurityException Forbidden POST https://identity.vwgroup.io/signin-service/v1/0fa5ae01-ebc0-4901-a2aa-4dd60572ea0e@apps_vw-dilab_com/login/phone-email/identifier (HTTP 405 Method Not Allowed) . Do I make something wrong?
Same issue here - WeCharge Account is running into the error posted from WalterP; was previously working with my wallbox.
@tknaller : Thanks for you ongoing work on the binding; if you need any assistance for ID.3 and/or VW wallbox, you can always contact me.
Sorry, I am totally new to OpenHab, just installed latest version but I cannot find this binding in the search. How do I install?
This Binding isnāt available via store, youāll have to install it manually (i.e. download the latest snapshot - see some lines above, ConnectedCar Binding myAudi, Volkswagen, VW ID, Skoda, Enyaq, Seat, Ford, WeCharge - #1018 by tknaller - then copy this file to the folder $OPENHAB_RUNTIME/../addons/
) Please pay attention to the two dots. Keep in mind that this folder is not writable without special permission, you have to use sudo
The Binding will only appear when using the āAdd thingā function (white + in a blue circle bottom right corner), not within the store.
works with Passat 2019, Some channels updated / removed
Thanks, got it installed. But is not working with Audi Q4
Initialization failed: Account has no registered vehicles, go to online port and add at least 1 vehicle
There is only 1 vehicle in this account, but maybe Q4 Etron is different than classic Audi and different than etron (Q8).
@tknaller do you have any updates for the preheater controlling?
Can i capture the correct API URL from the Android APP?
@tknaller the URL has changed for vw ā we now get a requested route (ālogin.apps.emea.vwapps.ioā) does not exist. error when using the binding for volkswagen
13:34:46.565 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'connectedcar:vwid:8f3f1c1e71' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Initialization failed: API call failed GET https://login.apps.emea.vwapps.io/authorize?nonce=MTY3NzU5NzY5NjM3MA==&redirect_uri=weconnect://authenticated (HTTP 404 Not Found), result = 404 Not Found: Requested route ('login.apps.emea.vwapps.io') does not exist.
the new domain URL is https://emea.bff.cariad.digital
so the url to use
https://emea.bff.cariad.digital/user-login/v1/authorize?redirect_uri=weconnect%3A%2F%2Fauthenticated&nonce=96473274549175525641677583231
same with Ford cars. Iām not sure why, just donāt spend too much time trying to get it to work if it doesnāt the first time.
Seems some more URLs have changed. The weconnect-mqtt is working again though
gives a hint on the changed urls
With these I got the binding working again.
@tknaller pushed my branch. you can prob cherrypick last commit to yours
