I would like to set dynamic timers to specific switches while using a generic rule.
I implemented it by adding a gSwitcheTimers group for each switch that I want to run a timer and creating a Number item with the prefix of the switch Item and a “_Timer” suffix.
In sitemap I can set a different timer for each switch and in the rule I am using createTimer that once activated I turn off the switch.
The problem starts if someone turn off the switch and then turn it on while the timer is already running (the switch will be turn off based on the first activation of the timer and not the current one).
Is there a way to stop a running timer or reset it in the example below?
Items:
Group gTimers
Group:Switch:OR(ON, OFF) gSwitchTimers
Switch Relay1_Output "Fan" <fan_ceiling> (gSwitchTimers) {channel="...."}
Number Relay1_Output_Timer "Fan - Timer [%s]" <fan_ceiling> (gTimers)
Switch Relay2_Output "Wall" <light> (gSwitchTimers) {channel="...."}
Number Relay2_Output_Timer "Wall - Timer [%s]" <light> (gTimers)
Sitemap:
Setpoint item=Relay1_Output_Timer minValue=1 maxValue=60 step=1
Setpoint item=Relay2_Output_Timer minValue=1 maxValue=60 step=1
Rule:
rule "Timers"
Member of gSwitchTimers changed to ON
val device = triggeringItem
var logger = 1
val loggerName = "Timers"
if(device !== null)
val timer=gTimers.members.findFirst[ t | t.name == device.name + "_Timer" ] as NumberItem
if (timer.state >0)
switch(vTimeOfDay.state)
case "NIGHT",
case "BED":
if (logger==1) logInfo(loggerName, "Starting " + timer.name + " timer for "+ (timer.state as Number).intValue + " mins")
createTimer(now.plusMinutes((timer.state as Number).intValue)) [ |
if(triggeringItem.state == ON)
if (logger==1) logInfo(loggerName, "Turning off "+ timer.name)
triggeringItem.sendCommand(OFF)
else
if (logger==1) logInfo(loggerName, "Timer is null")
