IOS app error: URLSessionTask failed with error
Hi all,
I have a problem with the iOS app on both iPhone and iPad. I keep getting the error „URLSessionTask failed with error: Timeout“.
I can access my basic ui sitemap via the web but the app doesn‘t work anymore. I tried to play around with the settings: Change graphics PNG/SVG, clear the image cache, send credentials on every log in. And I installed the beta app on the Ipad.
I wonder if there is an error on my server side that is causing the timeout. How would I be able to find out?
I am running OpenHAB 3.3.0.M3 on a Raspberry Pi 3B+. The iOS app version is 2.4.47.
Any ideas how to fix the error? Best, Max
EDIT:
I guess this might be the corresponding log entry:
org.apache.cxf.interceptor.Fault: XML_WRITE_EXC
	at org.apache.cxf.jaxrs.interceptor.JAXRSDefaultFaultOutInterceptor.handleMessage(JAXRSDefaultFaultOutInterceptor.java:106) ~[bundleFile:3.4.5]
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
	at org.apache.cxf.interceptor.AbstractFaultChainInitiatorObserver.onMessage(AbstractFaultChainInitiatorObserver.java:112) ~[bundleFile:3.4.5]
	at org.apache.cxf.phase.PhaseInterceptorChain.wrapExceptionAsFault(PhaseInterceptorChain.java:374) ~[bundleFile:3.4.5]
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:332) ~[bundleFile:3.4.5]
	at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Caused by: com.ctc.wstx.exc.WstxIOException: Closed
	at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:262) ~[?:?]
	at org.apache.cxf.jaxrs.interceptor.JAXRSDefaultFaultOutInterceptor.handleMessage(JAXRSDefaultFaultOutInterceptor.java:104) ~[bundleFile:3.4.5]
	... 51 more
Caused by: org.eclipse.jetty.io.EofException: Closed
	at org.eclipse.jetty.server.HttpOutput.checkWritable(HttpOutput.java:769) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:793) ~[bundleFile:9.4.43.v20210629]
	at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:51) ~[bundleFile:3.4.5]
	at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:100) ~[?:?]
	at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:242) ~[?:?]
	at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:260) ~[?:?]
	... 51 more
I also see what I think is the same error message (in English) along with an interceptor fault in the log. These may be related:
Hi @BigGeorgeTx,
thank you. Yes, looks very similar to my error. Good to know I am not alone. :wink:
But I guess nobody has found a solution yet, right?
Best, Max
Same for me since the last some days.
I also use app version 2.4.47.
I also uninstalled the app and installed it fresh, did not help.
Any update by anyone?
I changed my OpenHAB hardware from Rasperry 3B to 4 and now the error has gone.
I‘ve a raspberry 4 and have also the same issue. From local url it works only via myopenhab the error occurs.
Any suggestions?
Regards
I’m in the same boat. Are there any updates on this?
I have the same error.
How do you configure your app?
For me it was the same.
App version 2.4.54
I solved it correcting the URL and remove the port and activate “Always send credentials”
URL: https://myopenhab.org (without port)
Password:
Always send credentials: activated
Hope that works for you as well.
Regards
For me this hint solved the problem:
My OpenHAB Logs show:
[WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request from Basic authentication with username/password is not allowed
Hope this helps someone.
Took me some time to find the right solution.
Best regards HJM
