Mercedes Benz integration
Hello, just tried to install the integration but fail to get the authentication Code.
After configuring the products with MB and then in the redirectURL (all ticks are green) I get an error after clicking ‘Authenticate’ saying ‘400 - Invalid redirect_uri’ while expecting to be forwarded to the MB-Connect site for login.
Any idea what I did wrong?
Christian
Great project & documentation :+1:
But first of all: Is it still “online”, i.e. functional? If so, unfortunately not for me.
Hence my questions…
Mercedes server-side setup
  • Special AppName required?
  • Where can I find the “API key”?
  • Is there a data access/error history?
openHAB server side
So forbidden access to the ./resources folder.
Of course, nothing is fetched from MB server :frowning:
What causes the access ban?
Still missing any rights on MB side?
Is my MB Project ID needed anywhere?
Any tip welcome.
I’ve come to believe that the MB Server project name must contain the openhab keyword. Will try that soon.
With the openhab keyword in the project name, I have now received the API key for the image download. So: The –get_images download works now. But with the –data query of the individual statuses, the answer is always “Access forbidden”.
Any idea?
Hi all,
thanks for your support here. :wink:
Any chance to see a Binding for that, sooner or later?
thanks again
Andrea
For those having troubles to execute the python script through the rules, here is what I did:
Changed the rules file as following:
var content = executeCommandLine(Duration.ofSeconds(45), "/usr/bin/python3", "/etc/openhab/scripts/mb-connect/mb-connect.py", "--data")
console.log("Log: ",content);
This way, I could see the output of the script running in Frontail.
I could then see that the script gave an error: "“No module named ‘openhab’”
Strangely enough, executing this script from the raspberry pi terminal through SSH worked fine, but executing it through the openhab rule gave this error.
I was not able to resolve the error itself (maybe someone else has an idea?), but I found a workaround, by executing the script through crontab.
From the terminal:
sudo crontab -u openhabian -e
and then add at the bottom
*/10 * * * * python3 /etc/openhab/scripts/mb-connect/mb-connect.py --data
It’s important not to use “sudo crontab -e” but to use “sudo crontab -u openhabian -e”. The former uses the crontab of the root user, but the script needs to be executed by the user “openhabian”, or it will not pump the data to openhab.
This way, the script executes every 10 minutes through the openhabian user, and the data is pumped into openhab
I can help on initial tests and testing. Please let me know how :slight_smile:
How fast can the data be polled by OpenHAB? An idea would be that if the car is near the garage and a light switch (or any other switch) is toggled that the garage door opens. But I guess the delay might be too large?
I just set this up today; kudos to @spawny0815 for putting it together. I do have a question, though: this defines a bunch of Items, but there isn’t a corresponding Thing (as far as I can tell) to allow me to incorporate the Items into e.g. the Model. Am I missing something here - is this intended to be used with a pre-existing Thing, or is the Item-without-Thing approach working as designed?
You can add the items, just set the checkbox to show non-semantic items.
Thanks, that allows me some control, but the items are largely read-only so I can’t e.g. rename them (without changing the feeder script). I guess I can use it as-is for now.
Got things running with this setup with my new EQA. Based on this I implemented the Mercedes Me binding. I need your expertise now!
Mercedes stopped the BYOCAR service since August 31, 2023.
All work for the trash, how does it continues with the binding, any future ideas??
Found this message in the Mercedes newsboard
#BringYourOwnCar products will be discontinued
Since June 2020, we have been offering you the opportunity to access selected data from your own Mercedes-Benz vehicle with the #BringYourOwnCar initiative.
During this time, the underlying technology has changed significantly and the BYOCAR infrastructure no longer meets our current technical requirements. Therefore, we have to shut down all BYOCAR data products by August 31, 2023. Due to technical conditions, we will start the stepwise sundown on 28.08.2023 already.
We thank all users for their commitment to BYOCAR in the past. Of course we are working on a new solution to experiment with your own Mercedes-Benz and will keep you informed via this news section and our newsletter.
Thank you for your understanding.
Yes, I was quite puzzled seeing this message on short hand notice. Published on Aug 8th that they will shutdown on August 31th - not really good style!
If you’re willing to test the new alpha version based on another API you can find the adapted version here => Mercedes Me
