I created a custom color scheme for the linux tool multitail to make the openhab logs more readable.
You can find all information here:
And here is a screenshot about how it looks.
Feel free to give any kind of feedback.
Great, maybe a thing that should be intergrated into openhabian. The daker blue is for me hardly to read.
Thomas
I already posted in the openhabian thread. ![]()
Yes, blue is hard to read, but there are only so many colors and I think the prefixes of the Threads are not that importand.
But I just improved this by making the Threads in event.log cyan, too.
Very cool!
Thanks for sharing!
Given that multitail can tail logs on a remote host (which is worth installing it for that alone) I wrote a quick Ansible Role that will install multitail and your color scheme so I can install it on several of my hosts.
Here it is for those who like Ansible.
I’m using the standard Ansible folder layout (i.e. roles/rolename/tasks/main.yml and role/rolename/vars/main.yml)
roles/multitail/vars/main.yml
multitail_url: https://vanheusden.com/multitail/multitail-6.4.2.tgz
multitail_file: /tmp/multitail.tgz
multitail_home: /opt/multitail
multitail_conf_file: /opt/local/etc/multitail.conf
openhab_color_url: https://github.com/CWempe/multitail-scheme-openhab.git
openhab_logs_dir: /opt/openhab2/userdata/logs/
roles/multitail/tasks/main.yml
- name: Install prerequisites
apt:
name: "{{ item }}"
update_cache: no
become: yes
with_items:
- libncurses5
- libncurses5-dev
- libncursesw5
- libncursesw5-dev
- name: Create multitail folder
file:
path: "{{ multitail_home }}"
state: directory
mode: a+rwx
become: yes
- name: Clone multitail
git:
repo: https://github.com/flok99/multitail.git
force: yes
dest: "{{ multitail_home }}"
- name: Build and install multitail
make:
chdir: "{{ multitail_home }}"
target: install
become: yes
- name: Add multitail to the path
lineinfile:
path: /home/rich/.config/fish/config.fish
line: set -gx PATH /opt/local/bin $PATH
- name: Copy the default multitail.conf
copy:
src: /opt/local/etc/multitail.conf.new
dest: "{{ multitail_conf_file }}"
remote_src: yes
become: yes
- name: Add check_mail:0
lineinfile:
path: "{{ multitail_conf_file }}"
line: "check_mail:0"
become: yes
- name: Clone the openHAB color scheme
git:
repo: "{{ openhab_color_url }}"
dest: /tmp/multitail-scheme-openhab
- name: Copy color scheme into multitail.conf
shell: cat /tmp/multitail-scheme-openhab/multitail-scheme-openhab.conf >> {{ multitail_conf_file }}
become: yes
- name: Remove line with path to openhab logs
lineinfile:
line: scheme:openhab:/var/log/openhab2/
state: absent
become: yes
- name: Add path to openhab logs
lineinfile:
line: scheme:openhab:{{ openhab_logs_dir }}
become: yes
NOTES:
For the curious, to tail a log on a remote machine (assuming you have ssh key based logins set up)
multitail -l "ssh username@host tail -f file"
I’m probably being dense, but I followed the instructions from github, added the github raw text to the multitail conf file, and it’s still in black and white. Have I missed something?
Dan
I had problems, too, but then I placed the raw text right after “Oracle GoldenGate definition” and before PowerDNS definition (chosen randomly), I had the feeling, that the very last lines in /etc/multitail.conf are meant for other things…
debian 64-bit “stretch”
openhab@openhab2:~$ multitail -V
--*- multitail 6.4.2 (C) 2003-2014 by folkert@vanheusden.com -*--
well that was easy - thank you!
For anyone that hase problems reading the dark blue on black background with Putty:
In Putty Configuration set Window | Colours | Indicate bolded text by changing to Both.
Finally! This is now a default component of openHABian, starting today. Thanks @christoph_wempe!
On existing installations it can be installed by executing “Manual/Fresh Setup” → “Bash&Vim Settings”.
Just stumbled upon this. Great work! Two thumbs up ![]()
