Hi there, I need your help.
No devices were found by Amazon Echo?
I Installed the Binding, set the Server-IP and enabled the pairing.
Here is my item file:
Switch TestSwitch1 "Kitchen Switch" ["Switchable"]
Switch TestSwitch2 "Bathroom" ["Lighting"]
Dimmer TestDimmer3 "Hallway" ["Lighting"]
Number TestNumber4 "Temperature Set Point" [ "TargetTemperature" ]
Here is the /api/discovery.xml directly from http://192.168.2.30:8080/api/discovery.xml
{"lights":{"2":{"state":{"on":false,"bri":-1,"hue":0,"sat":0,"xy":[0.0,0.0],"ct":500,"alert":"none","effect":"none","colormode":"ct","reachable":true},"type":"Dimmable Light","name":"Kitchen Switch","modelid":"LWB004","uniqueid":"2","manufacturername":"openHAB","swversion":"66009461","pointsymbol":{"1":"none","2":"none","3":"none","4":"none","5":"none","6":"none","7":"none","8":"none"}},"3":{"state":{"on":false,"bri":-1,"hue":0,"sat":0,"xy":[0.0,0.0],"ct":500,"alert":"none","effect":"none","colormode":"ct","reachable":true},"type":"Dimmable Light","name":"Bathroom","modelid":"LWB004","uniqueid":"3","manufacturername":"openHAB","swversion":"66009461","pointsymbol":{"1":"none","2":"none","3":"none","4":"none","5":"none","6":"none","7":"none","8":"none"}},"4":{"state":{"on":false,"bri":-1,"hue":0,"sat":0,"xy":[0.0,0.0],"ct":500,"alert":"none","effect":"none","colormode":"ct","reachable":true},"type":"Dimmable Light","name":"Hallway","modelid":"LWB004","uniqueid":"4","manufacturername":"openHAB","swversion":"66009461","pointsymbol":{"1":"none","2":"none","3":"none","4":"none","5":"none","6":"none","7":"none","8":"none"}}}}
And here ist the Log:
2018-02-22 19:36:11.649 [DEBUG] [ulation.internal.HueEmulationServlet] - Device pairing enabled : true
2018-02-22 19:36:11.662 [DEBUG] [org.openhab.io.hueemulation ] - ServiceEvent MODIFIED - {javax.servlet.http.HttpServlet}={service.pid=org.openhab.hueemulation, service.config.category=io, service.config.label=Hue Emulation, discoveryIp=192.168.2.30, component.name=org.openhab.hueemulation, component.id=207, pairingEnabled=true, service.config.description.uri=io:hueemulation, service.id=331, service.bundleid=222, service.scope=bundle} - org.openhab.io.hueemulation
2018-02-22 19:36:13.771 [TRACE] [tion.internal.HueEmulationUpnpServer] - Got SSDP Discovery packet from 192.168.2.114:50000
2018-02-22 19:36:13.776 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
HOST: 239.255.255.250:1900
EXT:
CACHE-CONTROL: max-age=100
SERVER: FreeRTOS/7.4.2, UPnP/1.0, IpBridge/1.15.0
hue-bridgeid: A832340ECE78
ST: upnp:rootdevice
USN: uuid:23216d9f-76cb-4cbe-b33c-a832340ece78::upnp:rootdevice
2018-02-22 19:36:13.779 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: urn:schemas-upnp-org:device:basic:1
2018-02-22 19:36:13.782 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2018-02-22 19:36:13.783 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: uuid:23216d9f-76cb-4cbe-b33c-a832340ece78
2018-02-22 19:36:13.786 [TRACE] [tion.internal.HueEmulationUpnpServer] - Got SSDP Discovery packet from 192.168.2.114:50000
2018-02-22 19:36:13.787 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.789 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2018-02-22 19:36:13.794 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.811 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.814 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.817 [TRACE] [tion.internal.HueEmulationUpnpServer] - Got SSDP Discovery packet from 192.168.2.114:50000
2018-02-22 19:36:13.821 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2018-02-22 19:36:13.825 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.829 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.832 [TRACE] [tion.internal.HueEmulationUpnpServer] - Got SSDP Discovery packet from 192.168.2.114:50000
2018-02-22 19:36:13.836 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2018-02-22 19:36:13.839 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.843 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.846 [TRACE] [tion.internal.HueEmulationUpnpServer] - Got SSDP Discovery packet from 192.168.2.114:50000
2018-02-22 19:36:13.850 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2018-02-22 19:36:13.853 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.855 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.857 [TRACE] [tion.internal.HueEmulationUpnpServer] - Got SSDP Discovery packet from 192.168.2.114:50000
2018-02-22 19:36:13.859 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2018-02-22 19:36:13.861 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:13.863 [TRACE] [tion.internal.HueEmulationUpnpServer] - Sending to 192.168.2.114 : HTTP/1.1 200 OK
EXT:
2018-02-22 19:36:14.000 [DEBUG] [ulation.internal.HueEmulationServlet] - 192.168.2.114: GET /api/description.xml
Any ideas?
Thanks!
