No problem. Shall I just edit the DB so it is like it was before this whole discussion?
Sure - Iām not really sure why it all got changed in the first place.
The previous and correct database definition did not work because of an openHAB 3 UI bug.
I started the discussion by asking if it should be all options should accepted even outside of the min/max range (which is yes they should), but @Bruce_Osborne immediately changed the database. He wanted to help out which I highly appreciate, but we should have first finished the discussion, before making any changes.
Can you check if I am doing something wrong?
If I set limit to options for one parameter it is changed for all parameters.
So they need to be all true or all false.
I thought you could set this per parameter.
For now I am setting it to false.
Edit:this might also explain why they are all changed, because @Bruce_Osborne said he did not touch those valuesā¦
Is it correct the export function only exports the accepted changes?
When setting min 5 max 30 for display timeout, these values are not in the XML when choosing export to openHAB xml.
Also I am not able to clear a min or max setting (so it is undefined again).
Just did a fresh install of the provided docker container (openHAB 2.5.11 Release Build, binding-zwave - 2.5.11) and it was not able to find the Eurotronic Spirits in the included database. Is the a way to sideload a fixed DB?
I want to stay on stable for the time being.
Not easily. The easiest would be to manually install a snapshot version of the zwave binding containing the new database. This script makes it pretty easy. @5iver has this been tested with Docker?
I am not aware of anyone who has tried. OTTOMH, I canāt think of any reason why it wouldnāt work. Why donāt you give it a shot and let us know
I was not sure how the scri[pt uninstalls the old binding. The REST API would be available but Karaf would not.
Why wouldnāt Karaf be available?
Karaf is running in a Docker container without that port exposed, normally,
Thatās odd that the port wouldnāt be available. Is it disabled by default?! The script will not work properly without the console.
I just tried the most recent docker openhab/openhab:snapshot which resolves to a version 3 OH installation. That recognizes the Spirits instantaneously.
Starting OH using docker openhab/openhab:2.5.12-snapshot-alpine caused me some headache. I coundnāt even install my bridge⦠The container goes down on a fatal error. Will file another bug report for that.
Will now try 5ivers scriptsā¦
OpenHAB recommends the Debian containers because Zulu Java is not available for Alpine. Zulu is also the only one that uses hardware float calculations on arm processors like the Pi uses.
Hi Bruce,
thanks for the fast reply⦠I didnt know about this recommendation - sorry. Just tried docker openhab/openhab:2.5.12-snapshot-debian which doesnt fault, great. The serial bridge could easily be added and used.
However, I can now confirm that the Spirit thermostat is not in the database of binding-zwave - 2.5.12.SNAPSHOT, grrr.
@5iver: I am struggling getting your zzManualInstaller.sh to work inside the container. Would this make sense anyway, as the binding-zwave - 2.5.12.SNAPSHOT doesnt contain the device?
My current status:
docker exec myname su openhab -c "cd /openhab/addons; ./zzManualInstaller.sh --ACTION zwave"
results in
It has taken more than two minutes to uninstall the Z-Wave binding, so exiting
/openhab/addons contains your script only. Tried both the debian and alpine containerā¦
If it was found in OH3 but not in the latest OH2 then the device is likely not fully discovered. The databases should be almost identical.
I waited now for some hours to no avail. The device was identified as
Z-Wave Node 004 (0148:0003:0001:0.16)
16 properties are populated, so I am pretty confident the discovery was successful.
If I look at PaperUI/Configuration/Binding/Z-Wave Binding I get a list of all supported things. The Eurotronics is not in the list. even though Chris wrote on Nov 7th that it has been updated for 2.5.
@chris: Could this be recurrence of the previous issue?
What is in the openhab.log file? Try running the script from the menu instead of passing arguments.
I think this got dropped from the binding for some reason. Please try the latest version to see if that works (eg todays nightly snapshot).
I also discoverd the Unknown Device problem with the Eurotronics Spirit running openHAB 2.5.11-1 (Release Build).
I just tried Snapshot 2.5.12.202012160333 of the Z-Wave Binding and the the Eurotronics Spirit are working as expected.
Thanx for your work.
