Hi Thom,
are you planning to make a new openhabian image for the Raspberry Pi 4?
kind regards
Michael
Hi Thom,
kind regards
Michael
We will as time permits. But there’s a number of issues we need to work on first so this will take some months probably.
According to their site, the CPU architecture is backwards compatible.
IOW, current image should work.
Unlikely. Raspberry foundation says RPi 4 needs a new Raspbian base image and advises not to upgrade. So we need to create a new image, and that’ll take time.
Hmm, but installing a Debian distro on the new RPi 4 and maually installing openHabian afterwards couldn’t solve this temporarly?
Possibly. Try for yourself. But the question was on an openHABian image.
Would it make any sense to do the 2.4 image compatible with Rpi 4 ?
It would make more sense to use the Raspbian version provided by Raspberry Pi and then install whatever version of OpenHABian you desire.
The work required for the image would be OS related, not OpenHABian related.
Many people are running 2.5M Milestone release. I am currently running a snapshot.
2.5 will not be released this month due to all the work required.
+1 for that!
RPi 4 (that needs Raspbian Buster) with the 4GB memory would be perfect if you want to include multiple video streams that are CPU/MEM heavy!
Debian Buster has a release date of July 6. Will Raspbian be ready on the same date?
The Raspbian image for RPi 4 is already built from Buster.
We have a new version featuring RPi 4 support and based on Rasbian Buster.
Have a look and enjoy Release openHABian v1.5 based on Debian Buster supports RPi4 · openhab/openhabian · GitHub ![]()
Cheers,
maintainers
It´s currently not possible to install zram beta from the openhabian-config.
The log says that the repository from @mstormi can´t be found.
2019-09-12_12:44:00_CEST [openHABian] Checking for changes in origin... OK
Username for 'https://github.com': ***
Password for 'https://***@github.com':
remote: Repository not found.
fatal: repository 'https://github.com/mstormi/zram-config/' not found
/bin/sh: 0: Can't open ./install.sh
Failed to start zram-config.service: Unit zram-config.service not found.
Checking the website in my browser gives the same result: 404
kind regards
Michael
It’s been moved:
Maybe not moved but is available at the link in that post
I’m waiting for that repo to be transferred to me which is why I had to delete mine first.
Thanks for the hint!
I solved the issue by editing the zram.bash in opt/openhabian/functions
Changed the following lines:
local ZRAMGIT=https://github.com/StuartIanNaylor/zram-config
local TAG=master
@elias_gabrielsson
Hi, I wanted to know if this last image is supported by RPi3. Or does it only work with RPi4?
It’ll work on any RPi 2/3/4, see new README.
