Server Error / 500 with openhab2
all of a sudden, I cannot connect to the root of my openhab2 web server.
I have installed by apt.
I am unsure how to troubleshoot, but here are the errors in openhab.log. Any ideas? Note - I fixed the sitemap error in the logs…
2017-01-07 14:07:21.206 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /start/index
java.lang.NullPointerException
	at java.lang.String.replace(String.java:2240)[:1.8.0_65]
	at org.openhab.ui.dashboard.internal.DashboardServlet.serveDashboard(DashboardServlet.java:74)[168:org.openhab.ui.dashboard:2.0.0.201612281318]
	at org.openhab.ui.dashboard.internal.DashboardServlet.doGet(DashboardServlet.java:63)[168:org.openhab.ui.dashboard:2.0.0.201612281318]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)[19:javax.servlet-api:3.1.0]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)[19:javax.servlet-api:3.1.0]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[79:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[79:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[170:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[77:org.eclipse.jetty.security:9.2.19.v20160908]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[170:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[79:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[170:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.Server.handle(Server.java:499)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[78:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[70:org.eclipse.jetty.io:9.2.19.v20160908]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[81:org.eclipse.jetty.util:9.2.19.v20160908]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[81:org.eclipse.jetty.util:9.2.19.v20160908]
	at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
2017-01-07 14:07:24.927 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /start/index
2017-01-07 14:07:24.929 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /start/index
2017-01-07 14:08:31.216 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `test.sitemap` does not match the name `sports` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2017-01-07 14:08:31.514 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `test.sitemap` does not match the name `sports` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2017-01-07 14:08:48.668 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /start/index
From the code it looks as if you have a UI that misses to define an overlay icon for the dashboard.
I wouldn’t know, which UI has this bug, but in any case, this code has just been improved today by Dashboard: remove html5 icon, remove z-index for overlay by vlad-ivanov-name · Pull Request #109 · openhab/openhab-core · GitHub, so that this exception should not ever happen anymore.
So I’d suggest to update your distro to the latest build and would hope that the issue is solved by it.
Thanks Kai, and as always for all the hard work.
I have installed via apt, using the snapshot release. Are there any tips to overlaying a beta install? I can probably wait for the next snapshot.
Thanks,
Jason
An apt update this evening appears to have fixed the problem!
Glad to hear!
Sorry for adopting this thread.
I have exactly the same error while opening the dashboard under :8080. It appears yesterday without any noticeable reason. Paper UI and Basic UI are working fine, the sitemap works under Basic UI.
Are there any other possible reasons?
You wrote
I did not change anything regarding the dashboard.
How can I fix it?
2017-01-10 20:03:18.077 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /start/index
        at org.openhab.ui.dashboard.internal.DashboardServlet.serveDashboard(DashboardServlet.java:74)[168:org.openhab.ui.dashboard:2.0.0.201612051711]
        at org.openhab.ui.dashboard.internal.DashboardServlet.doGet(DashboardServlet.java:63)[168:org.openhab.ui.dashboard:2.0.0.201612051711]
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)[20:javax.servlet-api:3.1.0]
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)[20:javax.servlet-api:3.1.0]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[79:org.eclipse.jetty.servlet:9.2.14.v20151106]
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[79:org.eclipse.jetty.servlet:9.2.14.v20151106]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:70)[170:org.ops4j.pax.web.pax-web-jetty:4.2.4]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[77:org.eclipse.jetty.security:9.2.14.v20151106]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:271)[170:org.ops4j.pax.web.pax-web-jetty:4.2.4]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[79:org.eclipse.jetty.servlet:9.2.14.v20151106]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[170:org.ops4j.pax.web.pax-web-jetty:4.2.4]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.server.Server.handle(Server.java:499)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[78:org.eclipse.jetty.server:9.2.14.v20151106]
        at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[70:org.eclipse.jetty.io:9.2.14.v20151106]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[81:org.eclipse.jetty.util:9.2.14.v20151106]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[81:org.eclipse.jetty.util:9.2.14.v20151106]
Your distro is from early December and it seems to have downloaded recent snapshots of UIs, which are not compatible anymore - you should update your distro, that will help.
I have the same problem.
2017-01-10 23:57:16.702 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /start/index
	at java.lang.String.replace(String.java:2240)[:1.8.0_111]
	at org.openhab.ui.dashboard.internal.DashboardServlet.serveDashboard(DashboardServlet.java:78)[169:org.openhab.ui.dashboard:2.0.0.201701032212]
	at org.openhab.ui.dashboard.internal.DashboardServlet.doGet(DashboardServlet.java:67)[169:org.openhab.ui.dashboard:2.0.0.201701032212]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[80:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[80:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[171:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[78:org.eclipse.jetty.security:9.2.19.v20160908]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[171:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[80:org.eclipse.jetty.servlet:9.2.19.v20160908]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[171:org.ops4j.pax.web.pax-web-jetty:4.3.0]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.Server.handle(Server.java:499)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[79:org.eclipse.jetty.server:9.2.19.v20160908]
	at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[71:org.eclipse.jetty.io:9.2.19.v20160908]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[82:org.eclipse.jetty.util:9.2.19.v20160908]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[82:org.eclipse.jetty.util:9.2.19.v20160908]
	at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
Upgrade as well.
Hi, I have the same issue. However, I cannot upgrade, because the apt-get repos are missing. Is there already a solution in place to retrieve the latest succesfull build via apt-get?
@RaimondB: Did you try the new repo?
Also, check out this post for upgrade:
Thanks! I missed this. And I see recently the offical docs I was using got updated :wink:
