I have seen a few questions if it is possible to open a popup/popover triggered by rule or by a state of an item. As this still seems to be tricky I just wanted to share my solution for this as a post for further reference:
In a nutshell, it is all about controling the property opened of an f7-popup/f7-popover and make its value (true or false) dependent from an item state or from a virtual item state (in case of triggering by rule).
true opens a popup
false closes your popup.
Although the container element oh-button has no function at all in my example, it is still required (set it to transparent to make it invisible though).
I also added an optional button inside the popup so that you can click anywhere inside the popup to close the popup (of course this has to be replaced if you fill the popup with control elements (like player-item, toggle item, buttons, etc).
Please note:
if you want to test it, this does not work reliably within Run mode. Open your test page from your side bar
be aware when using a proxy item and you want to close your popup by click in the backdrop or via Navbar: you need to make sure that the virtual item gets a different state than the triggering state. otherwise your popup re-opens.
This is working for me on a test widget, but has to be manually closed.
Is there a way I can have it automatically close after X seconds?
I could, possibly, do it with rules, but would prefer something within the widget itself.
Does anyone know if this is possible?
Ok, makes sense.
I have a number of different items that will initiate the popup, so might not be an option for me.
After further thought I might just have a single dummy item to control the popup and use a rule (there are quite a few items that I need to popup) to define what has generated the âalertâ and populate the widget accordingly.
I have tried your solution but some how it doesnât work for me.
I have a page with the universal toggle widget which can set my foscam motion state to ON. On the same page I have this widget. But when I toggle no popup shows up. Do I miss something?
