This widget displays the current state of your washing machine together with the time it has been running since the start of the washing.
Configuration is pretty straightforward (see screenshot below):
- Title: Sets the card title if you want one. Leave empty for no title.
- Footer: Sets the card footer if you want one. Leave emtpy for no footer.
- Header: Sets the text above the machine icon.
- Minutes running: Sets the time inside of the machine. This should be evaluated by an expression (e.g. =items.washing_machine_runtime.state).
- State: Can be one of OFF, RUNNING or FINISHED and should be filled in via an expression as well depending on the current state of your machine.
- Dryer Mode (not in the screenshot below): Put the string “ON” in here to get a red/orange color scheme that can be used for a dryer.
Have fun ![]()
Screenshots
Dryer Mode:
Configuration:
Changelog
Version 0.4
- fixed: Replaced standard preloader component with the replacement as proposed by @Nico_R for my dishwasher widget. This way the look of the washing machine will be the same on iOS and android devices
Version 0.3
- added: dryer mode with a red/orange color scheme
Version 0.2
- fixed: Small bugfix - Minutes < 10 are shown correctly with a leading 0
Version 0.1
- initial release
Resources
uid: washing_machine_v4
tags: []
props:
parameters:
- description: Title of the card
label: Title
required: false
type: TEXT
- description: The card footer
label: Footer
required: false
type: TEXT
- description: Header text above washing machine
label: Header
required: false
type: TEXT
- description: Expression that evaluates to minutes since the begin of washing
label: Minutes running
required: true
type: TEXT
- description: Expression that evaluates to OFF, RUNNING or FINISHED
label: State
required: true
type: TEXT
- description: "Dryer mode: Set this to ON for a red dryer color scheme"
label: Dryer Mode
required: false
type: TEXT
parameterGroups: []
timestamp: Oct 2, 2021, 9:24:59 PM
component: f7-card
title: =(props.title)
slots:
default:
- component: f7-card-content
style:
height: 175px
slots:
default:
- component: f7-row
class:
- display-flex
- justify-content-center
style:
width: 100%
slots:
default:
- component: f7-col
class:
- display-flex
- flex-direction-column
- align-items-center
- justify-content-space-evenly
style:
height: 100%
width: 90px
slots:
default:
- component: f7-block-header
slots:
default:
- component: Label
text: =props.header
style:
height: 120px
width: 90px
border-radius: 2px 2px 4px 4px
background: rgba(255,255,255,1)
box-shadow: rgba(0, 0, 0, 0.25) 0px 14px 28px, rgba(0, 0, 0, 0.22) 0px 10px 10px
class:
- display-flex
slots:
default:
class:
- display-flex
- justify-content-flex-end
- flex-shrink-0
- no-margin
style:
height: 23px
width: 85px
border-bottom: 1pt solid lightgray
padding-right: 10px
slots:
default:
- component: f7-icon
f7: circle_fill
color: gray
f7: circle_fill
color: gray
f7: '=props.state == "OFF" ? "circle_fill" : "sun_min"'
style:
color: '=props.state == "OFF" ? "gray" : "red"'
class:
- display-flex
style:
height: 60px
width: 60px
border: 5pt solid lightgray
border-radius: 50%
margin-top: 7px
slots:
default:
colorTheme: '=props.dryer == "ON" ? "red" : "lightblue"'
class: custom-preloader-container-dummy
style:
display: '=props.state == "RUNNING" ? "" : "none"'
margin: 0
padding: 0
--f7-preloader-size: 50px
--f7-preloader-color: var(--f7-theme-color)
position: absolute
left: 50%
top: 50%
transform: translate(-50%, -50%)
slots:
default:
class: custom-preloader-dummy
style:
margin: 0
padding: 0
width: var(--f7-preloader-size)
height: var(--f7-preloader-size)
slots:
default:
class: custom-preloader-inner-dummy
style:
margin: 0
padding: 0
position: absolute
left: 0
top: 0
width: 100%
height: 100%
slots:
default:
class: custom-preloader-inner-circle-dummy
style:
margin: 0
padding: 0
border-radius: 50%
border: calc(var(--f7-preloader-size)/8) solid var(--f7-preloader-color)
border-top-color: transparent
box-sizing: border-box
animation: aurora-preloader-rotate 1s linear infinite
position: absolute
left: 0
top: 0
width: 100%
height: 100%
f7: '=props.state == "FINISHED" ? "circle_bottomthird_split" : "circle"'
style:
color: '=props.state == "OFF" ? "lightgray" : (props.dryer == "ON" ? "orange" : "lightblue")'
border-radius: 50%
box-shadow: 0 0 16px 8px rgba(0, 0, 0, 0.25) inset
visible: =props.state == "RUNNING"
class:
- no-margin
style:
position: absolute
slots:
default:
- component: Label
text: '=Math.floor(props.runtime / 60) + ":" + ((props.runtime % 60) < 10 ? ("0" + props.runtime % 60) : (props.runtime % 60))'
style:
color: black
- component: f7-card-footer
slots:
default:
- component: Label
text: =props.footer
