So given that everything ultimately needs to live on a thread somewhere, what is the logic of how the timer gets around this issue? Does it just push it to one of the other pools? If so, which pool? Also, what impact does that have on whatever else was supposed to live in that other pool? The last time I checked, the other 3 pools only have 5 or 10 threads each as well so aren’t we just shifting the problem around?
I know that Timers get executed by Quartz. But I don’t know if it uses a thread from the quartz thread pool or whether it creates a new thread. I suspect it creates a new thread because the default pool is 2 for quartz. (/usr/share/openhab2/runtime/etc/quartz.properties) and I’m certain I’ve had more than two running at the same time.
The only things that live in that pool are Timers (if it does use threads from that pool) and cron triggered Rules. Sometime this weekend I’ll try to set up an experiment to verify this. I’m just assuming based on the behavior I’ve see in my system so far.
We are not just shifting the problem around, we are shifting the problem to a place where it causes less of an impact. Assuming the Timers do run in a thread from the Quartz thread pool, then if we run out of those threads then the impact is only Timers and cron triggered Rules stop running rather than ALL Rules stop running.
We are also lessening the amount of time that the Threads are tied up because unlike a Thread::sleep that uses up a thread doing nothing, a Timer doesn’t use any Thread until it is actually running. So, if you look at the complex example, the while loop uses a Rule thread non-stop from the first movement detection until morning. With the Timer implementation it is only using a Quartz thread (assuming that it does use a thread from this pool) for a handful of milliseconds every minute, freeing up that thread for use the rest of the time.
So in many cases we are decreasing the likelihood that we will run out of threads because we are not tying one up doing nothing but waiting around, and we are lessening the impact should we run out of threads.
I’d be really interested in hearing if anyone encounters problems with Timers that may be caused by running out of Threads in the Quartz pool. If that does occur then we should file an issue to address that problem.
This is an interesting approach. I’ve definitely run into this issue as I have rules that take a long time to run (mostly HTTP queries) as well as rules that try to run simultaneously (e.g. audio notifications for things like doorbells that go off in multiple rooms). It’s more noticeable to the simultaneous rules because you can hear the notification play at different times (in some cases as long as 45 seconds later) across the hosue. I dialed my rules threadpool much higher and it resolved my issues. I would be curious to know if there is a real/noticable difference between increasing the number of threads that the rules can use versus pushing it over to the Quartz pool. I’m not overly worried about hardware resources, the computer my OH runs on has plenty to spare. If so I’ll retool my rules to push those over.
There is a way to hook up a development too called a profiler to OH and it will tell you how many threads are active. Beyond that I don’t think there is. Worrying about threads isn’t usually something users have to worry about.
There might be a way to get some logs from Quartz that might be informative.
But beyond knowing these things are possible I’m not much help. I haven’t used a profiler in a decade.
I know the the first one works but then we have a lambda declaration floating in the code after a comma. Doesn’t make sense to me.
I prefer the second one, the syntax makes more sense.
Both are technically equivalent. As far as the Rules DSL is concerned they are identical.
The underlying Xtend language provides a little “syntatic sugar”. For method calls that take a lambda as it’s final argument, you can put the lambda definition outside the parens.
I don’t like this and recommend against it in the OH context because most people don’t realize they are creating a lambda Object and passing it to the createTimer method in the former case, whereas in the latter case that is made just a little more explicit since you are putting the lambda definition inside the parens of the method call.
In short, like Vincent says, the later example makes more sense to more people as it is more consistent with the rest of the Rules DSL.
Look at just the shell:threads --list. It will shw you all threads. Adding the grep “thingHandler” will show just the lines containing thingHandler. The wc -l provides a line count (number of threads). The counts change quickly… or should! In theory, the ruleTimer should be the important one for rules.
Hi Rich.
Want to ban my thread::sleeps in my rules.
If i have more than 1 sleeps, i use a timer in timer?
Situation:
Rollershutter up needs 20 seconds -> than
TTS notification for 13 seconds -> than
TTS notification for 10 seconds.
rule "My sleeping rule"
// and event
// rollershutter up
createTimer(now.plusSeconds(20), [ |
// TTS notification1
createTimer(now.plusSeconds(13), [ |
// TTS notification2
Same problem by switching 10 lights to on. To prevent an overflow at the lights hub, after every switch of a light, i use a sleep function by 25 mseconds.
And why this is okay too, without the “|”
var Timer timer = null
rule "my rule"
Member of MyGroup changes
if(timer !== null) {
timer = createTimer(now.plusSeconds(1), [ // no need of "|" ?
//Find the lowest and do what ever you do
timer = null
That is probably what I would do. There is a limited number of threads available to the Timers as well (maybe) so you don’t want to use one of them up doing nothing.
See Design Pattern: Gate Keeper and look at the second to last section above. It is not always practical to remove thread sleeps. In those cases you just have to be more careful.
Because if you don’t have any arguments to pass to the lambda, the | is optional. I always include it to be consistent. It’s the same reason I always put the lambda inside the parens.
Thanks for this. I had a lot of Thread::sleep all over multiple rule files, to include in the startups. All ranging from 2 to 60 seconds and some within while loops. I knew it was probably not a great thing, but didn’t realize how harmful it could be until stumbling across this thread. I’ve since removed all the thread::sleep instances and reworked everything as described here. And the while loops are now timer loops. The only thing I need to do still is put some kind of sanity limit on the loops otherwise a edge case could make them loop for hours.
Organization and troubleshooting. A problem in one rule file will not necessarily affect all the others. For example, all the rules and items for my Z-Wave garage door openers are in their own item and rule files. They are picky and complicated devices and the rule file is quite long, so it’s best to keep them siloed. The Weather Underground item file is huge and that’s in it’s own for the same reason.
At runtime there is no difference between the two. Once OH loads them they are all in memory and behave the same.
So the only place where it matters to OH is when it loads the file. And here the main practical difference is that System started Rules fire when a .rules file loads so if you have everything in one .rules file then all of your System started Rules will fire whereas if you have is split into multiple files only the those in that one file will fire.
Beyond that I don’t think there are any practical differences as far as OH loading of files is concerned.
So the biggest practical difference between having multiple .rules files versus one big file is that global val/vars are only global to that one .rules file. So if you have a variable that needs to be used by multiple Rules, they all need to be in the same file.
But for you the human, working with thousands of lines long files (not an unheard of size for lots of OH systems) is awkward. So it makes sense to split up the files. There are several strategies people use. I prefer and recommend splitting both your .items and your .rules files up by function (e.g. lighting, weather, hvac, etc).This provides a logical organization for the files and decreases the likelihood that you will need to deal with the scope of global variables issue mentioned previously. But ultimately, you are the human who has to deal with all this stuff. Do what makes the most sense for you.
