Dear all, after update openhab 4.0.0 to openhab 4.1.1
cat /var/lib/openhab/etc/version.properties 4.0
openHAB Distribution Version Information
build-no : Release Build
online-repo : JFrog
Repository Version
openhab-distro : 4.0.0
openhab-core : 4.0.0
openhab-addons : 4.0.0
karaf : 4.4.3
cat /var/lib/openhab/etc/version.properties 4.1
online-repo : JFrog
Repository Version
openhab-distro : 4.1.1
openhab-core : 4.1.1
openhab-addons : 4.1.1
karaf : 4.4.4
My system doesn´t have a UI and many more ERRORS:
for Example:
024-02-01 20:45:45.530 [ERROR] [Events.Framework ] - FrameworkEvent ERROR org.osgi.framework.BundleException: Could not resolve module: org.connectorio.addons.ui.iconify [245] Unresolved requirement: Import-Package: org.openhab.core.i18n; version=â[3.0.0,4.0.0)â
2024-02-01 20:51:23.806 [ERROR] [unication.SonoffCommunicationManager] - Cannot send command uiActive, all connections are offline for deviceid 1000bcd8fd
2024-01-15 17:02:54.290 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed to refresh bundles after processing config update
java.lang.IllegalStateException: Resource has no uri
at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1631) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:904) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
2024-01-15 16:39:41.765 [ERROR] [unication.SonoffCommunicationManager] - Cannot send command uiActive, all connections are offline for deviceid 1000bcd8fd
2024-01-15 16:41:04.510 [WARN ] [rd.internal.AriesJaxrsServiceRuntime] - Application CachingServiceReference {
cachedProperties={osgi.jaxrs.application.select=null (cached), osgi.jaxrs.application.base=/api, service.id=1565, application.ready.service.filter=null (cached), objectClass=[javax.ws.rs.core.Application], service.scope=singleton, osgi.jaxrs.name=null (cached), osgi.jaxrs.extension.select=null (cached), osgi.http.whiteboard.context.select=null (cached), osgi.jaxrs.whiteboard.target=null (cached), service.bundleid=325}
serviceReference={javax.ws.rs.core.Application}={osgi.jaxrs.application.base=/api, service.id=1565, service.bundleid=325, service.scope=singleton}
} is registered with error
2024-01-15 16:41:04.519 [INFO ] [ulation.internal.HueEmulationService] - Hue Emulation service available under /api
2024-01-15 16:41:04.542 [WARN ] [rd.internal.AriesJaxrsServiceRuntime] - Errored application CachingServiceReference {
} is gone
and so on and onâŚ
All âoldâ sugesstions for restart an upgrade are done:
sudo rm -rf /var/lib/openhab/tmp/*
.sudo rm -rf /var/lib/openhab/cache/*
Restart and and (I´m using Openhab since 1.7!!)
Nothing help!
It´s aopenhabian installtion based on 3.3 with an upgrade to 4.0 (BTW in this migration the heating systme loos all Values!)
What can I do to bring my system back to work. in case of the given limitation that Fallback is still not available (nightmare!)
Please give my some instructions to fix
Many thanks to veryone
Hardwaresystem:
on Rapsian âbullseyeâ:
PRETTY_NAME=âRaspbian GNU/Linux 11 (bullseye)â
NAME=âRaspbian GNU/Linuxâ
VERSION_ID=â11â
VERSION=â11 (bullseye)â
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL=âhttp://www.raspbian.org/â
SUPPORT_URL=âRaspbianForums - Raspbianâ
BUG_REPORT_URL=âRaspbianBugs - Raspbianâ
on aRaspberry pi 3B
System is runing on a SSD
Thank you for any hint an tip
Cheers
Stefan
