All,
Here is my collection with a persistence group, zwave lights, sensors and siren,
Custom Scenes:
On Way Home - On way home from work, opens garage,turns on TV, etc
Movie Night - Dims lights to 20%, Turns on 70" LivingRoom TV, sets HDMI input to Kodi.
Kodi is booted from a PXE Server for whole house Kodi and profiles on multiple TV’s and devices.
Bed Time - Turns everything off.
In Use:
OpenHab 1.8.2 - Rock Solid
Zwave binding 1.9 - Flawless!
Extra bindings: exec, persist, http, orvibo, REST API
Aeon Labs, Door/window, Siren, LED Lights. Zstick2 latest FW
My Total Control HoneyWell WIFI Thermostat status and Management scripts.
Aquos 70" Sharp TV binding
WakeOnLan to turn on hosts (kodi)
Password-less SSH to shutdown hosts (kodi)
Banana PI 3 for garage control and status back to OH.
Banana PI 3 for Kodi
OwnTracks for presence detection with mqt.
New Hardware: Gigabyte GB-BXBT-2807 Gigabyte GB-BXBT-2807 - Google Suche
This is a little bad ass micro PC with sound, Wifi, Bluetooth, 64bit, you can easily install any OS from a thumb drive like you do on a PC. I threw a 250GB SSD and 8GB of ram in mine. This all sits inside a secure Honeywell alarm panel with battery backup. This allows for a total self sufficient alarm system if someone cuts the power or communications the alarm system portion will still run perfectly with no point of failure!
New New Hardware ![]()
New controller I’m using. Dell Netbook 10. 8+ hour battery, added a 250gb SSD so there is no moving parts.
cool little thing…Installed debian 7 on it. Paid 40 bucks for it on
craigslist.
1 Aeon Labs Door/Window Sensors (PRO: Has a protruding tamper sensor CON: Uses AA batteries)
3 EcoLink Door Window Sensors (PRO: Lithium battery, Multiple color housings come with it, very nice CON: Tamper is only internal to case not if you pull it off the wall)
2 Z-Wave Smoke/Carbon detectors (PRO: Cheap, Zwave, First Alert, Look nice, Carbon and Smoke, CON: AA Batteries)
2 EcoLink PIR (PRO: Lithium battery, Great range, work extremely well! I’ve tried sneaking up to it from every angle to disable it and it just don’t work lol CON: NONE)
6 Go-Control Dimmable LED’s (PRO: Work very well CON: NONE)
1 Zipato RGBW (PRO: Works very well overall CON: No RGBW in zwave binding 1.9)
1 Aeon Labs Gen2 Siren (PRO: LOUD, BRIGHT, Self charging battery operated, Multi-Tone CON: NONE)
1 Aeon Labs Gen5 Siren (PRO: LOUD, BRIGHT, Self charging battery operated, Multi-tone CON: NONE)
1 Aeon Labs Z-Stick2 (PRO: Cheap, Works great. No issues, works great in SUC mode and mesh redundancy. CON: None.
Groups and Rules for:
Alarm: Disarm, Arm Away and Arm Stay
FYI: I am changing code on a daily basis so if something don’t work correctly for you lmk so i can check against running code. ![]()
/etc/default/openhab
# Execution account and group. The user account should be member of group
# "openhab" if it's different than "root" and "openhab".
# Note that some bindings may require "root" access to the system.
# Default value if isn't specified - "root:root".
#USER_AND_GROUP=root:root # changed the openhab user and group in /etc/passwd to 0:0 for root permissions.
# Web server's listening ports (plain and SSL). Note that if execution account
# is different than "root" the port numbers should be greater than 1024.
# Default value if isn't specified - none, must be specified.
HTTP_PORT=80
HTTPS_PORT=443
# Console's listening port, same restriction as this for web server's ports.
TELNET_PORT=5555
# Extra arguments passed to Java
JAVA_ARGS=
# Extra arguments passed to openHAB
OPENHAB_ARGS=
# Use non-default Java VM.
# Default value if isn't specified - system default Java VM.
#OPENHAB_JAVA=/usr/bin/java
# To enable debugging set to "yes" (case insensitive).
# Default value if isn't specified - debugging is disabled.
DEBUG=yes
Rules:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.DateTime
import org.openhab.core.items.*
import org.eclipse.xtext.xbase.lib.*
import org.openhab.model.script.actions.Timer
var Timer Node2_tAlive = null
var Timer Node3_tAlive = null
var Timer Node4_tAlive = null
var Timer Node5_tAlive = null
var Timer Node6_tAlive = null
var Timer Node7_tAlive = null
var Timer Node8_tAlive = null
var Timer Node9_tAlive = null
var Timer Node10_tAlive = null
var Timer Node11_tAlive = null
var Timer Node12_tAlive = null
var Timer Node13_tAlive = null
var Timer Node14_tAlive = null
var Timer Node15_tAlive = null
var Timer Node16_tAlive = null
var Timer Node17_tAlive = null
var Timer Node18_tAlive = null
var Timer timer = null
val Functions$Function2 alert = [GroupItem g, String type |
val latest = g.members.sortBy[lastUpdate].last
val name = latest.name.split("_")
Notification_Proxy.postUpdate(name.get(1) + " " + name.get(2) + " " + name.get(3) + " " + type + " Alert!. " + latest.state.toString)
rule "Dispatch Notification"
Item Notification_Proxy received update
logWarn("Notification", Notification_Proxy.state.toString)
sendMail("alerts@cidcomm.com", "Security System Alert!", Notification_Proxy.state.toString)
rule "Process door intrusion updates"
Item gDoorSensors changed from CLOSED to OPEN
val aState = AlarmSysStatus.state as DecimalType
if(aState == 2 || aState == 3) {
alert.apply(gDoorSensors, "- Intrusion")
rule "DoorBell"
executeCommandLine("mplayer /usr/share/openhab/sounds/doorbell.mp3")
rule "Process motion intrusion updates"
Item gMotionSensors changed from CLOSED to OPEN
if((AlarmSysStatus.state as DecimalType) == 2) {
alert.apply(gMotionSensors, "- Intrusion")
rule "Process smoke detector updates"
Item gSmoke changed from CLOSED to OPEN
alert.apply(gSmoke, "- CO/Smoke")
rule "Process Tamper updates"
Item gTamper changed from CLOSED to OPEN
alert.apply(gTamper, "- Tamper")
rule "Process Window updates"
Item gWindows changed from CLOSED to OPEN
alert.apply(gWindows, "- Intrusion")
rule "Process Battery Level Updates"
Item gBattery received update
gBattery.members.forEach[ battery |
if((battery.state as DecimalType) < 20) {
val name = battery.name.split("_")
switch(name.get(1)){
case "Kitchen": Notification_Proxy.postUpdate("Replace the " + name.get(1) + " " + name.get(2) + " " + name.get(3) + " " + "Battery, " + battery.state.toString + "% left!")
case "LivingRoom": Notification_Proxy.postUpdate("Replace the " + name.get(1) + " " + name.get(2) + " " + name.get(3) + " " + "Battery, " + battery.state.toString + "% left!")
case "BedRoom": Notification_Proxy.postUpdate("Replace the " + name.get(1) + " " + name.get(2) + " " + name.get(3) + " " + "Battery, " + battery.state.toString + "% left!")
case "Hall": Notification_Proxy.postUpdate("Replace the " + name.get(1) + " " + name.get(2) + " " + name.get(3) + " " + "Battery, " + battery.state.toString + "% left!")
// Send selected temperature to MyTotalConnectComfort Portal
rule "IndHeatSet"
Item IndHeatSet received command
if(timer == null) {
timer =createTimer(now.plusSeconds(20), [|
logInfo("Security", "TIMER: Heat Timer triggered")
SendTemp.sendCommand(IndHeatSet.state as DecimalType)
timer = null
logInfo("Security", "TIMER: Heat Timer Set")
} else {
timer.reschedule(now.plusSeconds(20))
logInfo("Security","TIMER: Rescheduling Heat Timer")
// Set Heat Setpoint
rule "Send SetPoint to MyTotalConnectComfort Portal"
Item SendTemp received command
executeCommandLine("/etc/therm.py -h " + receivedCommand)
logInfo("Security", "RULE: Sending update to MyTotalConnectComfort Portal!")
// Sync Setpoint with the set temp app
rule "Update Temp App"
Item IndHeat received command
postUpdate(IndHeatSet, receivedCommand)
logInfo("Security", "CRON: Syncing SetPoint data!")
// Run MyTotalControl Script
rule "Update values from MyTotalControl Thermostat"
Time cron "0 0/5 * * * ?" // Every 5 minutes
executeCommandLine("/etc/tstat")
logInfo("Security", "CRON: Querying MyTotalConnectComfort Portal for data!")
// Check if we are on AC or Battery and send email if on battery
rule "CheckHostPower"
Time cron "0 0/2 * * * ?" // Every 5 minutes
executeCommandLine("/etc/checkac")
logInfo("Security", "CRON: Querying AC Power status!")
// Check if livingroom tv is on
rule "CheckLivingRoomTV"
executeCommandLine("/etc/checktv")
logInfo("Security", "CRON: Querying LivingRoom TV status!")
// Check if kodi is on in the livingroom
rule "CheckLivingRoomKodi"
executeCommandLine("/etc/checkkodi")
logInfo("Security", "CRON: Querying LivingRoom Kodi status!")
// Check if battery is below 25% and send email if so
rule "CheckBatteryPercentage"
executeCommandLine("/etc/checkbattery")
logInfo("Security", "CRON: Querying Battery Percentage!")
// Turn evening lights on
rule "Turn on tv Light"
//Time cron "0 0 19 * * ?" // 7pm every day
Item Sunset_Time_Task received update ON
Lower_LivingRoom_TV_Light.sendCommand(50)
Lower_LivingRoom_DoorWay_Light.sendCommand(50)
Lower_Kitchen_Patio_Light.sendCommand(ON)
logInfo("Security", "SCHEDULE: Turning on evening lights!")
// Turn evening lights off
rule "Turn off tv Light"
Time cron "0 30 23 * * ?" // 19:00:00, every day, every month, every weekday, don't care about year
gAllLights.sendCommand(OFF)
logInfo("Security", "SCHEDULE: Turning off evening lights!")
// SCENE: On way home
rule "OnWayHome"
Item OnWayHomeScene received command
if (receivedCommand == 1) {
SharpTVPower.sendCommand(ON)
relay1.sendCommand(ON)
Thread::sleep(8000)
SharpTVInput.sendCommand(0)
logInfo("Security", "SCENE: OnWayHome Activated!")
// SCENE: All off
rule "AllOff"
Item AllOffScene received command
SharpTVPower.sendCommand(OFF)
LRKodiPC.sendCommand(0)
logInfo("Security", "SCENE: AllOff Activated!")
// SCENE: All Lights off
rule "rAllLightsOff"
Item sAllLightsOff received command
logInfo("Security", "SCENE: All Lights Off Activated!")
// SCENE: All Lights on
rule "rAllLightsOn"
Item sAllLightsOn received command
gAllLights.sendCommand(ON)
logInfo("Security", "SCENE: All Lights On Activated!")
// SCENE: Movie Time
rule "MovieTime"
Item MovieTimeScene received command
Lower_LivingRoom_TV_Light.sendCommand(20)
Lower_LivingRoom_DoorWay_Light.sendCommand(20)
LRKodiPC.sendCommand(1)
Thread::sleep(8000)
SharpTVInput.sendCommand(4)
// Alarm Arm and Disarm
rule "rArmState"
Item AlarmArmDisarm received command
if (receivedCommand == 3)
logInfo("Security", "SECURITY: Armed Stay!")
postUpdate(AlarmSysStatus, 3)
sendMail("jay@cidcomm.com", "Security System Alert!", "System Armed Stay!")
executeCommandLine("aplay /usr/share/openhab/sounds/armedstay.wav")
if (receivedCommand == 2)
logInfo("Security", "SECURITY: Armed Away!")
postUpdate(AlarmSysStatus, 2)
sendMail("jay@cidcomm.com", "Security System Alert!", "System Armed Away!")
executeCommandLine("aplay /usr/share/openhab/sounds/armedaway.wav")
logInfo("Security", "SECURITY: Disarmed")
postUpdate(AlarmSysStatus, 1)
gAllSirensSwitch.sendCommand(OFF)
sendMail("jay@cidcomm.com", "Security System Alert!", "System Disarmed!")
executeCommandLine("aplay /usr/share/openhab/sounds/disarmed.wav")
if (receivedCommand == 0)
logInfo("Security", "SECURITY: No Update")
// Alarm System Active Action
rule "rAlarmActivated"
Item gMotionSensors changed from CLOSED to OPEN or
if (AlarmSysStatus.state == 2 && gMotionSensors.state == OPEN)
logInfo("Security", "SECURITY: ARMED-AWAY Motion Intrusion Detected!")
Thread::sleep(3000)
gAllSirensSet.sendCommand(259)
Thread::sleep(1200000)
if (AlarmSysStatus.state == 2 && gDoorSensors.state == OPEN)
logInfo("Security", "SECURITY: ARMED-AWAY Door Intrusion Detected!")
Thread::sleep(3000)
if (AlarmSysStatus.state == 3 && gDoorSensors.state == OPEN)
logInfo("Security", "SECURITY: ARMED-STAY Door Intrusion Detected!")
Thread::sleep(3000)
// Garage Door Timer Lights
rule "rGarageDoorLights"
Item relay1 received command
if (receivedCommand == ON) {
gGarageLights.sendCommand(ON)
logInfo("Security", "Garage Lights On!")
Thread::sleep(300000)
gGarageLights.sendCommand(OFF)
logInfo("Security", "EXT-TIMER: Garage Lights Off!")
// Garage Interior Door Timer Lights
rule "rGarageInteriorDoorLights"
Item Lower_Kitchen_MainDoor_Sensor changed from CLOSED to OPEN
logInfo("Security", "INT-TIMER: Garage Lights Off!")
// Node Health checks
rule "Node2Status"
Item Node2 changed
logInfo("Status", "NODE CHECK: Checking Node2 Status.")
Node2_tAlive?.cancel()
Node2_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N2", "Node2 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node2 Appears dead. Please Investigate.")
rule "Node3Status"
Item Node3 changed
logInfo("Status", "NODE CHECK: Checking Node3 Status.")
Node3_tAlive?.cancel()
Node3_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N3", "Node3 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node3 Appears dead. Please Investigate.")
rule "Node4Status"
Item Node4 changed
logInfo("Status", "NODE CHECK: Checking Node4 Status.")
Node4_tAlive?.cancel()
Node4_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N4", "Node4 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node4 Appears dead. Please Investigate.")
rule "Node5Status"
Item Node5 changed
logInfo("Status", "NODE CHECK: Checking Node5 Status.")
Node5_tAlive?.cancel()
Node5_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N5", "Node5 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node5 Appears dead. Please Investigate.")
rule "Node6Status"
Item Node6 changed
logInfo("Status", "NODE CHECK: Checking Node6 Status.")
Node6_tAlive?.cancel()
Node6_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N6", "Node6 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node6 Appears dead. Please Investigate.")
rule "Node7Status"
Item Node7 changed
logInfo("Status", "NODE CHECK: Checking Node7 Status.")
Node7_tAlive?.cancel()
Node7_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N7", "Node7 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node7 Appears dead. Please Investigate.")
rule "Node8Status"
Item Node8 changed
logInfo("Status", "NODE CHECK: Checking Node8 Status.")
Node8_tAlive?.cancel()
Node8_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N8", "Node8 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node8 Appears dead. Please Investigate.")
rule "Node9Status"
Item Node9 changed
logInfo("Status", "NODE CHECK: Checking Node9 Status.")
Node9_tAlive?.cancel()
Node9_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N9", "Node9 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node9 Appears dead. Please Investigate.")
rule "Node10Status"
Item Node10 changed
logInfo("Status", "NODE CHECK: Checking Node10 Status.")
Node10_tAlive?.cancel()
Node10_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N10", "Node10 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node10 Appears dead. Please Investigate.")
rule "Node11Status"
Item Node11 changed
logInfo("Status", "NODE CHECK: Checking Node11 Status.")
Node11_tAlive?.cancel()
Node11_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N11", "Node11 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node11 Appears dead. Please Investigate.")
rule "Node12Status"
Item Node12 changed
logInfo("Status", "NODE CHECK: Checking Node12 Status.")
Node12_tAlive?.cancel()
Node12_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N12", "Node12 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node12 Appears dead. Please Investigate.")
rule "Node13Status"
Item Node13 changed
logInfo("Status", "NODE CHECK: Checking Node13 Status.")
Node13_tAlive?.cancel()
Node13_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N13", "Node13 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node13 Appears dead. Please Investigate.")
rule "Node14Status"
Item Node14 changed
logInfo("Status", "NODE CHECK: Checking Node14 Status.")
Node14_tAlive?.cancel()
Node14_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N14", "Node14 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node14 Appears dead. Please Investigate.")
rule "Node15Status"
Item Node15 changed
logInfo("Status", "NODE CHECK: Checking Node15 Status.")
Node15_tAlive?.cancel()
Node15_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N15", "Node15 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node15 Appears dead. Please Investigate.")
rule "Node16Status"
Item Node16 changed
logInfo("Status", "NODE CHECK: Checking Node16 Status.")
Node16_tAlive?.cancel()
Node16_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N16", "Node16 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node16 Appears dead. Please Investigate.")
rule "Node17Status"
Item Node17 changed
logInfo("Status", "NODE CHECK: Checking Node17 Status.")
Node17_tAlive?.cancel()
Node17_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N17", "Node17 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node17 Appears dead. Please Investigate.")
rule "Node18Status"
Item Node18 changed
logInfo("Status", "NODE CHECK: Checking Node18 Status.")
Node18_tAlive?.cancel()
Node18_tAlive = createTimer(now.plusHours(8)) [|
logWarn("N18", "Node18 appears to be dead")
sendMail("jay@cidcomm.com", "Security System Alert!", "Node18 Appears dead. Please Investigate.")
rrd4j.persist:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
// if no strategy is specified for an item entry below, the default list will be used
default = everyMinute
Items {
// Persist ALL items in the persist GROUP
persist* : strategy = everyMinute, everyChange, restoreOnStartup
Proximity Detection Demo:
Kind of a hodge podge but slowly cleaning it up as I add more… ![]()
