lfs_alp5
(Alpoy)
December 28, 2023, 1:54pm
1
After upgrading from 4 to 4.1 my UI doesn’t know which addons/bindings are installed. The console shows all running but the UI says I can install them (and trying to install them changes nothing, they just spin forever and after refreshing gives the option to install again)
I’ve restarted and cleared cache a couple of times but didn’t change anything… ?
(Also tried 2 different browsers, clear browser cache etc)
AndrewFG
(Andrew Fiddian-Green)
December 28, 2023, 2:42pm
2
Are you looking in Add-ons Store? Assuming ‘yes’ then you should see top tab labelled Binding Suggestions which shows new suggested bindings, and if you scroll further down you should see a tab openHab Distribution which shows those that are already installed (and also others that are not).
lfs_alp5
(Alpoy)
December 28, 2023, 3:18pm
3
Yes, all bindings are marked with the option to “install”.
Installed bindings (z-wave binding is just an example):
GUI:
sascha777
(Sascha)
December 28, 2023, 7:10pm
5
I have the same issue. If I try to set up a new thing via GUI I don’t see any of my installed bindings.
Mherwege
(Mark Herwege)
December 28, 2023, 9:30pm
6
I don’t know what is causing this. It works for me. What is even more bizar is that no installed bindings are visible when wanting to create a thing. That has nothing to do with the add-on store.
In my case a restart (of the whole system) had helped. It took a while after the restart, but now the bindings are shown as installed again.
wborn
(Wouter Born)
December 29, 2023, 12:04pm
8
If you run into this issue check using the Developer tools (F12) what happens.
It would be interesting to know if the respective add-ons show as installed in the response of the /rest/addons?serviceId=karaf
request in the “Network” panel.
Also check the “Console” panel if it shows any errors.
Wikibear
(Swen)
December 30, 2023, 9:13am
9
Oh man, that’s good that i’m not the only one with this issue…
Rest give this:
"0": {
"uid": "binding-avmfritz",
"id": "avmfritz",
"label": "AVM FRITZ!Box Binding",
"version": "4.1.0",
"compatible": true,
"contentType": "application/vnd.openhab.feature;type=karaf",
"link": "https://www.openhab.org/addons/bindings/avmfritz/",
"author": "openHAB",
"verifiedAuthor": true,
"installed": false,
"type": "binding",
"configDescriptionURI": "",
"keywords": "",
"countries": [],
"connection": "local",
"properties": {},
"loggerPackages": [
"org.openhab.binding.avmfritz"
Everything is working at the moment. But i can’t add new devices and i can’t add new bindings.
Karaf itself show this:
START LEVEL 100 , List Threshold: 50
ID │ State │ Lvl │ Version │ Name
30 │ Active │ 80 │ 2.15.2 │ Jackson-annotations
31 │ Active │ 80 │ 2.15.2 │ Jackson-core
32 │ Active │ 80 │ 2.15.2 │ jackson-databind
33 │ Active │ 80 │ 2.15.2 │ Jackson-dataformat-YAML
34 │ Active │ 80 │ 2.15.2 │ Jackson datatype: JSR310
35 │ Active │ 80 │ 6.5.1 │ Woodstox
36 │ Active │ 80 │ 2.10.1.v20230109-0753 │ Gson
37 │ Active │ 80 │ 32.1.2.jre │ Guava: Google Core Libraries for Java
38 │ Active │ 80 │ 1.0.1 │ Guava InternalFutureFailureAccess and InternalFutures
39 │ Active │ 80 │ 7.0.0 │ guice
40 │ Active │ 80 │ 5.13.0 │ jna
42 │ Active │ 80 │ 4.8.149.v20220915-0556 │ ClassGraph
43 │ Active │ 80 │ 0.18.0 │ Directory-Watcher
44 │ Active │ 80 │ 2.2.15 │ swagger-annotations
45 │ Active │ 80 │ 2.2.15 │ swagger-core
46 │ Active │ 80 │ 2.2.15 │ swagger-integration
47 │ Active │ 80 │ 2.2.15 │ swagger-jaxrs2
48 │ Active │ 80 │ 2.2.15 │ swagger-models
49 │ Active │ 80 │ 1.0.5 │ Jakarta Dependency Injection
50 │ Active │ 80 │ 2.0.1 │ Jakarta Dependency Injection
52 │ Active │ 80 │ 2.0.2 │ Jakarta Bean Validation API
54 │ Active │ 80 │ 2.3.3 │ Jakarta XML Web Services API
55 │ Active │ 80 │ 1.2 │ javax.annotation API
56 │ Active │ 80 │ 3.5.8 │ JmDNS
57 │ Active │ 80 │ 2.2.0 │ Units of Measurement API
59 │ Active │ 80 │ 0.5.10 │ Jollyday
60 │ Active │ 80 │ 3.2.0.v201101311130 │ ANTLR Runtime
61 │ Active │ 80 │ 1.0.0.v201105210816 │ Aopalliance Plug-in
62 │ Active │ 80 │ 1.2.2 │ org.apache.aries.component-dsl.component-dsl
63 │ Active │ 80 │ 1.0.4 │ Apache Aries JAX-RS Specification API
64 │ Active │ 80 │ 2.0.0 │ Apache Aries JAX-RS Whiteboard
65 │ Active │ 80 │ 1.3.6 │ Apache Aries SPI Fly Dynamic Weaving Bundle
66 │ Active │ 80 │ 3.12.0 │ Apache Commons Lang
67 │ Active │ 80 │ 3.6.2 │ Apache CXF Core
68 │ Active │ 80 │ 3.6.2 │ Apache CXF Runtime JAX-RS Frontend
69 │ Active │ 80 │ 3.6.2 │ Apache CXF JAX-RS Client
70 │ Active │ 80 │ 3.6.2 │ Apache CXF JAX-RS Server-Side Events Support
71 │ Active │ 80 │ 3.6.2 │ Apache CXF Runtime Security functionality
72 │ Active │ 80 │ 3.6.2 │ Apache CXF Runtime HTTP Transport
78 │ Active │ 80 │ 4.4.4 │ Apache Karaf :: OSGi Services :: Event
94 │ Active │ 80 │ 2.3.1 │ XmlSchema Core
95 │ Active │ 80 │ 1.1.2 │ apiguardian-api
96 │ Active │ 80 │ 0.9.3 │ jose4j
97 │ Active │ 80 │ 2.24.0.v20220123-0838 │ EMF Common
98 │ Active │ 80 │ 2.26.0.v20220123-0838 │ EMF Ecore
99 │ Active │ 80 │ 2.14.0.v20190528-0725 │ EMF Change Model
100 │ Active │ 80 │ 2.16.0.v20190528-0725 │ EMF XML/XMI Persistence
101 │ Active │ 80 │ 3.18.0.v20230523-2142 │ Common Eclipse Runtime
135 │ Active │ 80 │ 0.21.0.v20230517-2120 │ org.eclipse.lsp4j
136 │ Active │ 80 │ 0.21.0.v20230517-2120 │ org.eclipse.lsp4j.jsonrpc
137 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xtend Runtime Library
138 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xtend Macro Interfaces
139 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xtext
140 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xtext Common Types
141 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xtext IDE Core
142 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xtext Utility
143 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xbase Model
144 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xbase Generic IDE Services
145 │ Active │ 80 │ 2.32.0.v20230827-1315 │ Xbase Runtime Library
153 │ Active │ 80 │ 1.0.0 │ Fixes for the java.base module
154 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Core
155 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Add-on XML
156 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Marketplace Add-on Services
157 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Community Marketplace Add-on Service :: Karaf
158 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Audio
159 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: JAAS Authentication
160 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Automation
161 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Automation Media Modules
162 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Automation Script Modules
163 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Automation Script RuleSupport
164 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Automation REST API
165 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Configuration Core
166 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Configuration Discovery
167 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Add-on Suggestion Service
168 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Process-based Suggested Add-on Finder
169 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Configuration mDNS Discovery
170 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Configuration Dispatcher
171 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Ephemeris
172 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: ID
173 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Console
174 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Console for OSGi runtime Karaf
175 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: HTTP Interface
176 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: HTTP Interface Authentication
178 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Monitor
179 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Network I/O
180 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: REST Interface
181 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Audio REST Interface
182 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Authentication Support for the REST Interface
183 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: REST Interface :: Core
184 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: REST mDNS Announcer
185 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Sitemap REST Interface
186 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: SSE Interface
187 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: REST Interface :: Swagger 1
188 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Transformation REST Interface
189 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: UI REST Interface
190 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Voice REST Interface
191 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: mDNS Service
192 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: WebSocket
193 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Karaf Integration
194 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Core
195 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Items
196 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Item IDE
197 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Items Runtime
198 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Language Server
199 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Persistence
200 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Persistence IDE
201 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Persistence Runtime
202 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Rules
203 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Rule IDE
204 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Rules Runtime
205 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Script
206 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Script IDE
207 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Script Runtime
208 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Sitemap
209 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Sitemap IDE
210 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Sitemap Runtime
211 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Thing
212 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Thing IDE
213 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model Thing Runtime
214 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Model YAML
215 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Persistence
216 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Semantics
217 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: JSON Storage
218 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Thing
219 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Transformation Service
220 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: UI
221 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: UI Icon Support
222 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Voice
223 │ Active │ 80 │ 4.1.0 │ openHAB UI :: Bundles :: Main UI
224 │ Active │ 80 │ 4.1.0 │ openHAB UI :: Bundles :: Icon Set :: Classic
234 │ Active │ 80 │ 1.0.1.202109301733 │ org.osgi:org.osgi.service.jaxrs
235 │ Active │ 80 │ 1.5.0 │ ThreeTen-Extra
236 │ Active │ 80 │ 2.1.0 │ SnakeYAML
237 │ Active │ 80 │ 2.1 │ SI Units
238 │ Active │ 80 │ 2.1.0 │ SI Quantities
239 │ Active │ 80 │ 4.2.1 │ Stax2 API
240 │ Active │ 80 │ 2.2.0 │ Units of Measurement Reference Implementation
241 │ Active │ 80 │ 2.2.0 │ Units of Measurement Common Library for Java
242 │ Active │ 80 │ 1.4.20 │ XStream Core
245 │ Active │ 80 │ 2.27 │ Dagger
246 │ Active │ 80 │ 1.3.3 │ hivemq-mqtt-client
247 │ Active │ 80 │ 5.13.0 │ jna-platform
248 │ Active │ 80 │ 4.1.99.Final │ Netty/Buffer
249 │ Active │ 80 │ 4.1.99.Final │ Netty/Codec
250 │ Active │ 80 │ 4.1.99.Final │ Netty/Codec/HTTP
251 │ Active │ 80 │ 4.1.99.Final │ Netty/Codec/Socks
252 │ Active │ 80 │ 4.1.99.Final │ Netty/Common
253 │ Active │ 80 │ 4.1.99.Final │ Netty/Handler
254 │ Active │ 80 │ 4.1.99.Final │ Netty/Handler/Proxy
255 │ Active │ 80 │ 4.1.99.Final │ Netty/Resolver
256 │ Active │ 80 │ 2.0.61.Final │ Netty/TomcatNative [OpenSSL - Classes]
257 │ Active │ 80 │ 4.1.99.Final │ Netty/Transport
258 │ Active │ 80 │ 4.1.99.Final │ Netty/Transport/Classes/Epoll
259 │ Active │ 80 │ 4.1.99.Final │ Netty/Transport/Native/Unix/Common
260 │ Active │ 80 │ 2.2.21 │ rxjava
261 │ Active │ 80 │ 1.0.1 │ IO.Socket Engine Client
262 │ Active │ 80 │ 1.0.1 │ IO.Socket Socket Client
263 │ Active │ 80 │ 3.29.2.GA │ Javassist
264 │ Active │ 80 │ 20231013.0.0 │ JSON in Java
265 │ Active │ 80 │ 3.9.0 │ Apache Commons Net
266 │ Active │ 80 │ 3.8.1.1 │ Apache ServiceMix :: Bundles :: okhttp
267 │ Active │ 80 │ 1.13.0.1 │ Apache ServiceMix :: Bundles :: okio
268 │ Active │ 80 │ 2.1.2 │ Java Concurrency Tools Core Library
269 │ Active │ 80 │ 1.15.3 │ jsoup Java HTML Parser
270 │ Active │ 80 │ 2.7.1.OH1 │ JUPnP Library
271 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Automation :: JavaScript Scripting
272 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Astro Binding
273 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: AVM FRITZ! Binding
274 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Denon / Marantz Binding
275 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: DWD Pollenflug Binding
276 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: DWD Unwetter Binding
277 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Exec Binding
278 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: HarmonyHub Binding
279 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: HTTP Binding
280 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: iCalendar Binding
281 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: IpCamera Binding
282 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Xiaomi Wifi devices (Mi IO) Binding
283 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: MQTT Broker Binding
284 │ Active │ 81 │ 4.1.0 │ openHAB Add-ons :: Bundles :: MQTT EspMilightHub
285 │ Active │ 81 │ 4.1.0 │ openHAB Add-ons :: Bundles :: MQTT Things and Channels
286 │ Active │ 82 │ 4.1.0 │ openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
287 │ Active │ 82 │ 4.1.0 │ openHAB Add-ons :: Bundles :: MQTT Homie Convention
288 │ Active │ 82 │ 4.1.0 │ openHAB Add-ons :: Bundles :: MQTT Ruuvi Gateway
289 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Netatmo Binding
290 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Network Binding
291 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: NTP Binding
292 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: OpenWeatherMap Binding
293 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: pixometer Binding
294 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Systeminfo Binding
295 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Tankerkoenig Binding
296 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Telegram Binding
297 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: TR-064 Binding
298 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: WLed Binding
299 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: OAuth2Client
300 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: Configuration UPnP Discovery
301 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: MQTT Transport
302 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: UPnP Transport
303 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: IO :: openHAB Cloud Connector
304 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Persistence Service :: InfluxDB
305 │ Active │ 75 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: Exec
306 │ Active │ 75 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: Jinja
307 │ Active │ 75 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: JSonPath
308 │ Active │ 75 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: Map
309 │ Active │ 75 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: RegEx
310 │ Active │ 80 │ 4.1.0 │ openHAB UI :: Bundles :: Basic UI
311 │ Active │ 80 │ 4.1.0 │ openHAB Add-ons :: Bundles :: Voice :: Pico Text-to-Speech
312 │ Active │ 80 │ 1.0.4 │ reactive-streams-jvm
313 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: IP-based Suggested Add-on Finder
314 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: mDNS Suggested Add-on Finder
315 │ Active │ 80 │ 4.1.0 │ openHAB Core :: Bundles :: uPnP Suggested Add-on Finder
316 │ Active │ 80 │ 4.0.0 │ SmartHome/J Add-ons :: Bundles :: Amazon Echo Control Binding
317 │ Active │ 80 │ 4.0.0 │ SmartHome/J Add-ons :: Bundles :: Common Components
Maybe there is an issue with REST API?
wborn
(Wouter Born)
December 30, 2023, 11:00am
10
Wikibear:
"installed": false,
Thanks for the info!
Yes the API response is wrong so the UI cannot be blamed for showing it as not installed.
AndrewFG
December 30, 2023, 1:29pm
11
@Mherwege could this be due to the AddonInfo merge function?
It also seems not to be possible to install new bindings. Just tried it again, after I had fully rebooted my machine to fix that already installed Bindings are shown as not installed, it won’t install a new binding .. or at least doesn’t show it as installed.
Wikibear
(Swen)
December 30, 2023, 7:12pm
13
Mherwege
(Mark Herwege)
December 31, 2023, 6:48am
14
The installed field is not part of AddonInfo, so cannot be the reason.
Roland62
(Roland Hartmann)
January 2, 2024, 10:07am
15
Have checked how it is working in my environment. All add-ons, which I had installed via the store are shown correctly. One exception - I have installed my eBus addon via placing the kar-file in the openhab-addons folder. The eBus addon is shown in the store as not installed.
Could it be, that the add-ons which are named here are even not installed via the store?
Wikibear
(Swen)
January 2, 2024, 12:56pm
16
Exactly the other way on my side… All installed from the marked will not shown. And installed via jar file are be shown as installed in the market. And one more this one they are installed from SmarthomeJ, are shown as installed either.
wborn
(Wouter Born)
January 2, 2024, 7:44pm
17
It uses a version range that states it doesn’t work with OH 4:
[ebus]
With this binding, heating and ventilation systems that have an eBUS can be addressed. The corresponding hardware is required. Connections are possible via serial, TCP and ebusd.
Requirements
openHAB 3.x
eBUS Hardware Interface (Serial, Ethernet, ebusd)
eBUS protocol compatible Heating System
Documentation
Binding Readme
Download
Release 3.4.16
Release 4.0.18
or just check GitHub Releases for the latest or older versions.
Changelogs
Roland62
(Roland Hartmann)
January 2, 2024, 8:15pm
19
That is the reason, why I am not using the version of the store. Currently I have running eBus 4.0.19. It is perfectly running with OH 4.1.0.
For me it makes sense, that it is not listed as installed in the overview of the store. Cause I have running another version.
Wikibear
(Swen)
January 2, 2024, 8:20pm
20
SmartHomeJ/ Alexa Binding is installed and show as installed.
Following are installed and shown as not installed:
MQTT , iCalender, AVM, tankekönig, denonmaranz, network, wled, networking… and so on. Transformations like Regex or JSONPath and other things like InfluxDB… all of them show install button. If i go via things to try to add new things nothing of them will show.
I’cant install new devices at the moment, but I have new one to add… That isn’t pretty cool.
BTW: Blink and ConnectedCar were installed before I remove them, cause for new updates and they were present in add-ons as installed.
For me everything is missing…
