This topic can be used to discuss problems/experiences/questions on the openHAB 3.1 release as announced in openHAB 3.1 is here!.
Smooth upgrade except my JavaScript email stopped working.
Removed the binding and re-installed and all good.
Everything else is still functioning.
Thanks.
In general I agree, but I since the upgrade the unifi-binding is not starting anymore and in the UI I see HANDLER_CONFIGURATION_PENDING but at the same time I do not see any errors in the startup-logs. If anybody finds a solution before me having time to dig let me know ![]()
I tried to downgrade to 3.0.2 as a quickfix but openhab did not start (docker container did not come up and stayed in the starting state for ~6 minutes before restarting).
Another thing I see (even though I am not sure it was not there with 3.0.2) is that I see the following logs at startup:
2021-06-28 09:26:16.298 [WARN ] [ty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@188195f[provider=null,keyStore=null,trustStore=null]
2021-06-28 09:26:16.300 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@188195f[provider=null,keyStore=null,trustStore=null]
Update: When I look at the unifi-binding description it states that “Unifi OS” is a mandatory setting. At the same time it does not show in the textual config example - how is it specified? (I am missing that option and assume that causes my issues.)
Update 2: Aaaaand fixed it
This is what the textual thing config looks like:
Bridge unifi:controller:home "UniFi Controller" [ *snip*, unifios=false ] {
Update 3: It seems that startup was changed. I have some init rules (DSL) that run on startup. Since the upgrade I get errors about unknown things, or even something like logInfo (the method) unknown. This was not the case before the update.
I introduced some wait timers in the startup rules and now it works. And yes, I know I should avoid startup rules, but until now I could not find a way around them…
Please, @Kai could you first announce the update/upgrade an then replace it on all sources?
Yesterday I wanted to keep my openHabian based Pi up to date and selected “upgrade system” in openhabian-config, boy was I surprised to get a new OH3 version, late at night.
Which kinda messed up my night’s sleep, because I had to restart twice as all my things and stuff have gone rogue… still not 100% here.
Long story short: normally I do upgrades of my applications not ad hoc and test them beforehand. Please give us a notice and then update!
Thanks!
When upgrading from openHAB3.0.2 to openHAB3.1 I lost all my bindings, persistence services…
I had to re-add them by hand.
Did you wait long enough for the system to reinstall them? For me they “reappeared” automatically after a while.
4 posts were split to a new topic: Manually changed port gone on upgrade
I observe problems with all my ECMA Rules, none of them is running!
Errors like:
2021-06-28 15:25:09.065 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error while creating ScriptEngine
org.graalvm.polyglot.PolyglotException: Error: Invalid CommonJS root folder: /etc/openhab/automation/lib/javascript/personal
at org.graalvm.polyglot.Context.eval(Context.java:345) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.evalInternal(GraalJSScriptEngine.java:319) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.initGlobal(GraalJSBindings.java:94) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.initContext(GraalJSBindings.java:90) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.requireContext(GraalJSBindings.java:84) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.put(GraalJSBindings.java:127) ~[?:?]
at javax.script.SimpleScriptContext.setAttribute(SimpleScriptContext.java:246) ~[java.scripting:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.addAttributeToScriptContext(ScriptEngineManagerImpl.java:249) ~[?:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.createScriptEngine(ScriptEngineManagerImpl.java:139) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler.createScriptEngine(AbstractScriptModuleHandler.java:92) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler.getScriptEngine(AbstractScriptModuleHandler.java:88) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1183) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1035) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1051) ~[?:?]
at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:327) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[bundleFile:3.4.3]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[bundleFile:3.4.3]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[bundleFile:3.4.3]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[bundleFile:3.4.3]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[bundleFile:3.4.3]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[bundleFile:3.4.3]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.3]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:217) ~[bundleFile:3.4.3]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.3]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:791) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.40.v20210413]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1435) ~[bundleFile:9.4.40.v20210413]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1350) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.40.v20210413]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundeFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:383) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036) [bundleFile:9.4.40.v20210413]
2021-06-28 15:15:16.915 [WARN ] [e.automation.internal.RuleEngineImpl] - Fail to execute action: 2
at com.oracle.truffle.js.scriptengine.GraalJSBindings.put(GraalJSBindings.java:128) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler.setExecutionContext(AbstractScriptModuleHandler.java:117) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:60) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
Do I need to create such folder?
[Edit:]
Creating such folder did not help!
After a restart I get differnet errors when running a rule. like:
2021-06-28 17:30:14.539 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'RefreshToken_Viessmann' failed: org.graalvm.polyglot.PolyglotException: TypeError: Access to host class org.openhab.core.transform.actions.Transformation is not allowed or does not exist.
or
2021-06-28 17:31:13.045 [WARN ] [.internal.OpenhabGraalJSScriptEngine] - Failed to retrieve script script dependency listener from engine bindings. Script dependency tracking will be disabled.
2021-06-28 17:31:13.097 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "items" is not defined
at <js>.:program(<eval>:3) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:379) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:356) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[java.scripting:?]
[Edit 2]
After a reboot everything is working as it should.
Problem solved by Reboot!
You should pin openHAB to a specific version in apt. That way even if an update is available it won’t upgrade openHAB until you change the target version. See https://linoxide.com/install-specific-version-package-apt-get/.
Just updated from 3.0.2 to 3.1.0. It was a really smooth experience.
Thank you for all your good work!!!
I have also these warnings on startup
Since the upgrade or are you sure they did not show up before?
After the update, no channels show up in deconz things (switches, dimmers). I have also already cleared the cache. Unfortunately without success. It only helps if you delete the thing and create it again.
After the update. I’m 100 percent sure I haven’t seen them before.
You should be more specific. What exactly is not working with the http binding? Logs?
I’m having problems with the Verisure binding in 3.1.0. Not 100% sure if it’s due to 3.1.0 or something else, because I broke my SD card and started from scratch again. But for sure it’s not working. See my post below. Verisure binding stopped working
I’ve upgraded my docker container from 3.1.0.M5 to 3.1.0 went smoothly except for the Homematic Binding. Some of my Homematic things are shown as Config:Error, mostly Homematic IP devices. The error says that device-id “xyz” is not found on gateway-id “abc”. Reverting back to 3.1.0.M5 solves the issue and everything works as expected. (Also the 3.1.0.RC1 had the same issue)
I’m using Raspberrymatic for the Homematic CCU in Version 3.57.5.20210525. Docker is running on Ubuntu 20.04 with the latest updates.
I’ve no idea what went wrong or where I can look for a more detailed error log.
Also trying the 3.2.0-snapshot version didn’t helped.
Can someone lead my into the right direction or give me some tipps on what I can do?
Thanks.
I created an own topic for this specific issue: Update to Openhab 3.1.0 breaks Homematic Binding
Same here…
…and I have a problem with some “NON”-IP-Sensors, they appear as online, but do not send any data.
3.1.0.M5 is working fine.
Err, well. There have been threads on each and every milestone, including code freeze announcement IIRC, plus as a long term user you should be aware of the release cycle and that it’s missing the projected date by a day or two at most - shouldn’t you ?
Sorry but to upgrade right around this date is just very bad timing of yours and that’s even more true for ad hoc action.
Sure it’s always nicer to get yet another announcement beforehand, on the other hand side how long do you expect devs to wait so everyone has “enough” time to prepare ? Not everybody is a daily forum user. No that wouldn’t work.
Plus you must not disappoint those eager to get hold of the final code asap.
Dear community members,
please only post to this thread if you believe your post is specific to the 3.1 release and of general interest to 3.1 users (or wannabes).
Any specific sort of problem of yours or issues that have been there in recent milestones already, please open your own thread. Remember just because an issue is new to you it’s not necessarily new to others.
If you don’t, this thread will quickly become overloaded and useless to all of us. Thank you.
PS: and mind the general posting guideline. Remember to provide at least a comprehensive description and code or logs that show the problem.
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
