Thank you so much, I upgraded a couple of days ago, and although I am ok with programming rules, blockly is just so easy and fast.
This release really feels like openhab matured a great bit.
Just two minor things:
In the logs, I often get a penhab.event.ItemStateChangedEvent or even hab.event.ItemStateChangedEvent. This is not always the case and is not really a problem, but just wanted to tell you about it.
Also it would be great if the item state suggestions I can put behind an MQTT item would show up everywhere I interact with the item, for example blockly.
Thanks, had the same bug, updating from the last milestone using openhabian upgrade.
I agree. I’ve tried OH a few times before and never felt comfortable and when I came across issues they always seemed to be known and awaiting a fix in a future version so I reverted to HA This seems very solid.
Well done to all those involved in 3.2
After updating to 3.2 I see my MainUI on a wall mounted display (iOS) not reacting to button presses anymore after a couple of hours and the button does not reflect the actual state anymore. However, a press on the three dots to open an expandable card still works.
THIS problem did not appear with 3.1 Milestone releases.
Error log:
2021-12-23 19:24:27.893 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - No message body reader has been found for class java.lang.String, ContentType: application/octet-stream
2021-12-23 19:24:27.918 [WARN ] [s.impl.WebApplicationExceptionMapper] - javax.ws.rs.WebApplicationException: HTTP 415 Unsupported Media Type
at org.apache.cxf.jaxrs.utils.JAXRSUtils.readFromMessageBody(JAXRSUtils.java:1473)
at org.apache.cxf.jaxrs.utils.JAXRSUtils.processRequestBodyParameter(JAXRSUtils.java:950)
at org.apache.cxf.jaxrs.utils.JAXRSUtils.processParameters(JAXRSUtils.java:881)
at org.apache.cxf.jaxrs.interceptor.JAXRSInInterceptor.processRequest(JAXRSInInterceptor.java:215)
at org.apache.cxf.jaxrs.interceptor.JAXRSInInterceptor.handleMessage(JAXRSInInterceptor.java:79)
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308)
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121)
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265)
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234)
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208)
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160)
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:217)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.base/java.lang.Thread.run(Thread.java:829)
I just successfully upgraded from 3.1 to 3.2. No hiccup at all. And I was able to remove the MyQ jar file in the add-ons folder now that it’s part of the 3.2 distribution. Love the new binding UI. Thanks all and happy holidays!
I use Zulu 11 OpenJDK. It was installed via openhabian.
In the meantime I’ve set up a fresh openhabian install. Unfortunately, the problem (see Error message during start-up after updating from 3.1.1 to 3.2: [core.karaf.internal.FeatureInstaller] - Failed installing add-ons) persits when I restore my configuration.
Not quite, it is to eventually discuss identified and confirmed issues with the software that were introduced in 3.2. This thread is to quickly get maintainers an overview of what’s eventually bad in most recent changes, strictly speaking that would be changes between the last milestone i.e. 3.2M5, and the final 3.2 release.
Getting that overview will not work if we discuss any 3.2 related issue here so my request regarding discussion on the milestone applies here likewise and I will keep splitting if necessary.
Since update from 3.1.1 to 3.2 rrd4j items with COUNTER in services/rrd4j.cfg
seems not to work anymore. The values included in database are all zero. Has there something been changed? I only could find that rrd4j was updated to a newer version.
ctr24h.def=COUNTER,900,0,U,60
ctr24h.archives=AVERAGE,0.5,1,480:AVERAGE,0.5,10,144
ctr24h.items=Item1,Item2
No issues upgrading to 3.2 from 3.1 via apt on Ubuntu 20.04.
I only use a small number of bindings. Current details below:
runtimeInfo:
version: 3.2.0
buildString: Release Build
locale: en-GB
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.13
javaVendor: Azul Systems, Inc.
javaVendorVersion: Zulu11.52+13-CA
osName: Linux
osVersion: 5.11.22-5-pve
osArchitecture: amd64
availableProcessors: 2
freeMemory: 111027184
totalMemory: 299892736
bindings:
- astro
- gpstracker
- http
- mqtt
- network
Well done to everyone involved, and Merry Christmas!
I have just made my second attempt to update from 3.1.1-1 to 3.2, after a first attempt on 23/12.
For the second time it just blew up my OH system, flooding the log with errors (generating some 40MB or errors in the log in less than a minute), forcing me to restore the previous version.
Prior to posting here I did read this thread and a couple of issues mentioned here applied to me.
- I did encounter the karaf error about failing to install add-ones (see below), but had been under the impression that the underlying issue for that had been fixed in the meantime; or, at least, from this discussion, that this was not a fundamental issue preventing the proper functioning of the system.
2021-12-28 13:34:23.538 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-tr064, openhab-persistence-mapdb, openhab-binding-senechome, openhab-misc-openhabcloud, openhab-binding-avmfritz, openhab-binding-network, openhab-persistence-influxdb, openhab-ui-habpanel, openhab-automation-jsscripting, openhab-binding-shelly, openhab-binding-nuki, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-ipcamera, openhab-binding-homematic, openhab-binding-systeminfo, openhab-binding-mail, openhab-persistence-jdbc-mariadb, openhab-transformation-javascript, openhab-binding-sonos, openhab-transformation-regex, openhab-transformation-jsonpath, openhab-ui-basic, openhab-binding-http, openhab-binding-astro': null
- I also saw a mention of the System Info binding causing issues, so I uninstalled that prior to upgrading the second time.
- Also noticed a mentioned issue with Influxdb, but that sounded like it only applied to fresh installs where existing data gets copied in.
Hence asking whether anyone can make sense of the issues I am facing:
Here’s what I do / observe in my case (without really noticing any difference between first and second upgrade attempts):
- upgrade to 3.2 via apt full-upgrade
- in the logs I see the system restarting, loading all models and items
- I also start seeing some output from rules running at system start which post a number of default values to related number items (which are not connected to any bindings)
- then I start getting quite few error messages saying that transformation services MAP and JS are not available (plus all the states to be transformed are NULL) → suggesting that the bindings are not working at this stage?
2021-12-28 13:33:25.780 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'FboxKurtpresent' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2021-12-28 13:33:25.879 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'SonosWohnzimmerStecker19216817828DeviceUptime' with pattern 'JS(secstotimeshort.js):%s': Couldn't transform value because transformation service of type 'JS' is not available.
- then I have many rules and also scheduled jobs failing, again because of the NULLs
- also warning that no queryable persistance service influxdb (which is my default service)
2021-12-28 13:33:28.099 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'influxdb'
- then the above-mentioned karaf error of failed installing bindings
- after that OH restarts, starts loading items and rules again
- and then all hell breaks lose, with lots of “Error executing EValidator” or “resolution of uriFragment failed” errors on all the rules; and each of those errors fills 1-2k lines in the logs, hence quickly blowing up the logs. (See start of the first EValidator error message and start of first “resolution of uriFragment” errors below).
2021-12-28 13:35:04.274 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'allother.rules'
2021-12-28 13:35:06.076 [ERROR] [xtext.validation.CompositeEValidator] - Error executing EValidator
java.lang.UnsupportedOperationException: Missing type computation for expression type: QuantityLiteral / ExpressionTypeComputationState: ExpressionAwareStackedResolvedTypes: [
parent: [
parent: [
parent: [
types:
JvmOperation: Tmp_allotherRules._Elternbad Temperatur() (visibility: PUBLIC, simpleName: _Elternbad Temperatur, identifier: Tmp_allotherRules._Elternbad Temperatur(), deprecated: <unset>) (varArgs: false) (static: true, final: false, abstract: false, synchronized: false, default: false, native: false, strictFloatingPoint: false) -> void
declaredTypeParameters:
parent: [
types:
JvmField: Tmp_allotherRules.counter (visibility: PRIVATE, simpleName: counter, identifier: Tmp_allotherRules.counter, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> Number
JvmField: Tmp_allotherRules.draussenkaelter (visibility: PRIVATE, simpleName: draussenkaelter, identifier: Tmp_allotherRules.draussenkaelter, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> boolean
JvmField: Tmp_allotherRules.ElternbadKalt (visibility: PRIVATE, simpleName: ElternbadKalt, identifier: Tmp_allotherRules.ElternbadKalt, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> boolean
JvmField: Tmp_allotherRules.KinderbadKalt (visibility: PRIVATE, simpleName: KinderbadKalt, identifier: Tmp_allotherRules.KinderbadKalt, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> boolean
JvmField: Tmp_allotherRules.STOP (visibility: PRIVATE, simpleName: STOP, identifier: Tmp_allotherRules.STOP, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> StopMoveType
JvmField: Tmp_allotherRules.PLAY (visibility: PRIVATE, simpleName: PLAY, identifier: Tmp_allotherRules.PLAY, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> PlayPauseType
2021-12-28 13:35:20.794 [ERROR] [xbase.resource.BatchLinkableResource] - resolution of uriFragment '|::0.2.0.2.0.0.7.0::0::/1' failed.
parent: [
parent: [
parent: [
types:
parent: [
types:
If anyone had any ideas what might be causing this, it would be greatly appreciated!
I recommend to update through openhabian-config menu as the scripts perform some pre-update tasks.
But I do not know of that is the root of your problem.
After updating from 3.1.1 to 3.2.0, my Honeywell TH6320ZW thermostat is not detected properly any more. Seems like Chris removed it from the ZWave binding and has it added back in 3.3.0-SNAPSHOT according to posts in this thread, though I haven’t tested this myself:
In openhab.log I get a new error
2021-12-28 13:00:29.562 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 0039:0011:0008::1.3
The thermostat does still work with any existing Items. But if you try to create a new Item, you can’t - the Thing is empty.
