Squeezebox favorites
yes. explicitely stopped and uninstalled the 2.5.4 version from console.
2.5.5. xxxx is marked active and the other control functions are working.
generally the configuration is straight forward, so difficult for me to understand why it is not working. also activated squeezebox binding logging but nothing much to derive errors from.
When the binding starts, there should be some log messages indicating that the server is sending the favorites to the player(s).
So i can add Favorites and the server sends them to Openhab.
[rnal.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100
They show in the server List item. First one is a radio station. Second is a single song i just added a minute ago
squeeze_server_favorites 0=1 LIVE,2=Oh What A Night
Yet the Selection item in the sitemap stays empty, respectively on Firefox only gives a grey overlay.
In IOS App it is going to an empty list.
Meanwhile updated LM server to version 8.0.0. which seems to be the actual current version
Openhab 2.5.4
Your binding as posted a few hours ago version 2.5.5.
No Sony Binding (actually tried to install those but did not give any effect)
Running bindings
Logitech Harmony Hub
Hue
Xiaomi Mi
Pioneer
Nanoleaf
ZWave
Denon/Marantz
Astro
Exec
Expire
Mqtt
It would be really helpful if I could see the first 10 seconds of debug logs after a binding restart. Otherwise, I can’t be of much help.
sure no problem. this a restart of the binding just now:
22:20:58.318 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:000420268757' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
22:20:58.321 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from ONLINE to UNINITIALIZED
22:20:58.322 [DEBUG] [ernal.handler.SqueezeBoxPlayerHandler] - player thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c disposed for mac 00:04:20:2a:0b:6c
22:20:58.336 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
22:20:58.336 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxserver:bdc389b8' changed from ONLINE to UNINITIALIZED
22:20:58.338 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - disposing server handler for thing squeezebox:squeezeboxserver:bdc389b8
22:20:58.338 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - setting squeeze server listener terminate flag
22:20:58.338 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Squeeze Server listener exiting.
22:20:58.340 [DEBUG] [.SqueezeBoxPlayerDiscoveryParticipant] - canceling RequestPlayerJob
22:20:58.341 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxserver:bdc389b8' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
22:21:04.760 [INFO ] [smarthome.event.ThingUpdatedEvent    ] - Thing 'nanoleaf:controller:1627EE307799' has been updated.
22:21:12.267 [INFO ] [smarthome.event.ItemStateChangedEvent] - miNetLife changed from 66905 to 66965
22:21:13.526 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
22:21:13.526 [DEBUG] [.SqueezeBoxPlayerDiscoveryParticipant] - Request player job scheduled to run every 60 seconds
22:21:13.529 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxserver:bdc389b8' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
22:21:13.531 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - initializing server handler for thing squeezebox:squeezeboxserver:bdc389b8
22:21:13.532 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - listener connection started to server 10.194.82.191:9090
22:21:13.533 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxserver:bdc389b8' changed from INITIALIZING to ONLINE
22:21:13.547 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: players 0
22:21:13.547 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: listen 1
22:21:13.550 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: 00:04:20:2a:0b:6c status - 1 subscribe:10 tags:yagJlNKjc
22:21:13.550 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: 00:04:20:26:87:57 status - 1 subscribe:10 tags:yagJlNKjc
22:21:13.562 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:000420268757' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
22:21:13.563 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:000420268757' changed from INITIALIZING to ONLINE
22:21:13.563 [DEBUG] [ernal.handler.SqueezeBoxPlayerHandler] - player thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 initialized with mac 00:04:20:26:87:57
22:21:13.567 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
22:21:13.574 [DEBUG] [ernal.handler.SqueezeBoxPlayerHandler] - player thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c initialized with mac 00:04:20:2a:0b:6c
22:21:13.574 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from INITIALIZING to ONLINE
22:21:16.547 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100
22:21:23.527 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: players 0
Ok, let’s try TRACE mode.
Look for lines like this…
2020-05-01 16:39:52.195 [DEBUG] [queezebox.internal.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100
2020-05-01 16:39:52.201 [TRACE] [queezebox.internal.handler.SqueezeBoxServerHandler] - Message received: favorites items 0 100 [snip]lots-of-stuff[\snip] count%3A31
2020-05-01 16:39:52.201 [TRACE] [queezebox.internal.handler.SqueezeBoxPlayerHandler] - Player b8:27:eb:5b:05:dc updating favorites list with 29 favorites
2020-05-01 16:39:52.201 [TRACE] [queezebox.internal.handler.SqueezeBoxPlayerHandler] - Player b8:27:eb:c7:d4:cc updating favorites list with 29 favorites
2020-05-01 16:39:52.201 [TRACE] [queezebox.internal.handler.SqueezeBoxPlayerHandler] - Player 00:26:18:57:f0:31 updating favorites list with 29 favorites
2020-05-01 16:39:52.201 [TRACE] [queezebox.internal.handler.SqueezeBoxServerHandler] - Updating favorites channel for squeezebox:squeezeboxserver:BD72319C-1EC2-4FD3-8A1C-877B6796A80C to state [snip]list of favorites[/snip]
Also, could you run this command in the console? I’d like to see which bindings are using state options.
openhab> services | grep StateDescriptionProvider
The output should look something like this.
[org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.somfymylink.internal.handler.SomfyMyLinkStateDescriptionOptionsProvider]
[org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.sony.internal.providers.SonyDynamicStateProvider, org.openhab.binding.sony.internal.providers.SonyDefinitionProvider, org.eclipse.smarthome.core.thing.binding.ThingTypeProvider, org.eclipse.smarthome.core.thing.type.ChannelGroupTypeProvider, org.openhab.binding.sony.internal.providers.SonyModelProvider]
[org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.zm.internal.ZmStateDescriptionOptionsProvider]
[org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.squeezebox.internal.SqueezeBoxStateDescriptionOptionsProvider]
Really strange. From the trace you can see that it is updating the player lists
My items:
String og_squeeze_PlayFavorite "Favoriten [%s]" { channel="squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c:playFavorite" }
//***************Server
String squeeze_server_favorites { channel="squeezebox:squeezeboxserver:bdc389b8:favoritesList"}
My sitemap:
Text 			label="Squeezebox Anton" icon="receiver" {
				Text			item=squeeze_server_favorites
				Selection   		item=og_squeeze_PlayFavorite
				Text			item=og_squeeze_PlayFavorite
A TRACE during restart of the binding
08:37:54.312 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
08:37:54.312 [TRACE] [box.internal.SqueezeBoxHandlerFactory] - creating handler for bridge thing org.eclipse.smarthome.core.thing.internal.BridgeImpl@c376bd23
08:37:54.314 [TRACE] [box.internal.SqueezeBoxHandlerFactory] - registering player discovery service
08:37:54.315 [DEBUG] [.SqueezeBoxPlayerDiscoveryParticipant] - Request player job scheduled to run every 60 seconds
08:37:54.315 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Registering player listener
08:37:54.318 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxserver:bdc389b8' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
08:37:54.325 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - initializing server handler for thing squeezebox:squeezeboxserver:bdc389b8
08:37:54.325 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - attempting to get a connection to the server
08:37:54.326 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Squeeze Server connection stopped.
08:37:54.328 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:000420268757' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
08:37:54.328 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - listener connection started to server 10.194.82.191:9090
08:37:54.329 [TRACE] [box.internal.SqueezeBoxHandlerFactory] - creating handler for player thing org.eclipse.smarthome.core.thing.internal.ThingImpl@a0f38367
08:37:54.329 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxserver:bdc389b8' changed from INITIALIZING to ONLINE
08:37:54.329 [TRACE] [box.internal.SqueezeBoxHandlerFactory] - Registering an audio sink for player thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c
08:37:54.339 [TRACE] [box.internal.SqueezeBoxHandlerFactory] - creating handler for player thing org.eclipse.smarthome.core.thing.internal.ThingImpl@9e9891fe
08:37:54.340 [TRACE] [box.internal.SqueezeBoxHandlerFactory] - Registering an audio sink for player thing squeezebox:squeezeboxplayer:bdc389b8:000420268757
08:37:54.348 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: players 0
08:37:54.348 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
08:37:54.349 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:000420268757' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
08:37:54.350 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: listen 1
08:37:54.351 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: players 0  count%3A2 playerindex%3A0 playerid%3A00%3A04%3A20%3A2a%3A0b%3A6c uuid%3A265e785f5dfa86060a3eb3cec2bb115c ip%3A10.194.83.128%3A52420 name%3AAnton seq_no%3A25 model%3Ababy modelname%3ASqueezebox%20Radio power%3A0 isplaying%3A0 displaytype%3Anone isplayer%3A1 canpoweroff%3A1 connected%3A1 firmware%3A7.7.3-r16676 playerindex%3A1 playerid%3A00%3A04%3A20%3A26%3A87%3A57 uuid%3A8badcea77ed326e0bc3635b95269d3fa ip%3A10.194.82.250%3A47607 name%3ABedroom seq_no%3A12 model%3Ababy modelname%3ASqueezebox%20Radio power%3A1 isplaying%3A0 displaytype%3Anone isplayer%3A1 canpoweroff%3A1 connected%3A1 firmware%3A7.7.3-r16676
08:37:54.353 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: 00:04:20:2a:0b:6c status - 1 subscribe:10 tags:yagJlNKjc
08:37:54.356 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: 00:04:20:26:87:57 status - 1 subscribe:10 tags:yagJlNKjc
08:37:54.358 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: listen 1
08:37:54.358 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A2a%3A0b%3A6c status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3AAnton player_connected%3A1 player_ip%3A10.194.83.128%3A52420 power%3A0 signalstrength%3A75 mode%3Astop time%3A23.9965741157532 rate%3A1 duration%3A195.533 can_seek%3A1 mixer%20volume%3A45 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A25 playlist_cur_index%3A4 playlist_timestamp%3A1588366206.68254 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A4 id%3A26043 title%3AShe's%20A%20Killer year%3A2011 artist%3AGuano%20Apes genre%3ARock artwork_track_id%3A66055554 album%3ABel%20Air coverart%3A1 coverid%3A91b9f385
08:37:54.358 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A2a%3A0b%3A6c'
08:37:54.358 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:37:54.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:37:54.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:37:54.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:37:54.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:37:54.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3AAnton'
08:37:54.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:37:54.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.83.128%3A52420'
08:37:54.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A75'
08:37:54.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:37:54.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:37:54.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:37:54.368 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A25'
08:37:54.369 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366206.68254'
08:37:54.370 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:37:54.371 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A4'
08:37:54.372 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:000420268757' changed from INITIALIZING to ONLINE
08:37:54.373 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26043'
08:37:54.374 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel title for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state She's A Killer
08:37:54.374 [DEBUG] [ernal.handler.SqueezeBoxPlayerHandler] - player thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c initialized with mac 00:04:20:2a:0b:6c
08:37:54.374 [DEBUG] [ernal.handler.SqueezeBoxPlayerHandler] - player thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 initialized with mac 00:04:20:26:87:57
08:37:54.376 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A66055554'
08:37:54.377 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel coverartdata for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state raw type (image/jpeg): 33211 bytes
08:37:54.380 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel remotetitle for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state
08:37:54.382 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel artist for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state Guano Apes
08:37:54.383 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel album for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state Bel Air
08:37:54.383 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel genre for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state Rock
08:37:54.384 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel year for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 2011
08:37:54.384 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A26%3A87%3A57 status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3ABedroom player_connected%3A1 player_ip%3A10.194.82.250%3A47607 power%3A1 signalstrength%3A0 mode%3Astop time%3A0 rate%3A1 duration%3A662.943 can_seek%3A1 mixer%20volume%3A14 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A12 playlist_cur_index%3A12 playlist_timestamp%3A1588366413.35996 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A12 id%3A26990 title%3ASturz%20In%20Die%20Schlucht year%3A2003 artist%3AA%20Fragezeichen genre%3AHoerspiel artwork_track_id%3A1beae404 album%3A112%20-%20Schlucht%20der%20Daemonen coverart%3A1 coverid%3A1beae404
08:37:54.385 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A26%3A87%3A57'
08:37:54.385 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:37:54.385 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:37:54.386 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:37:54.386 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:37:54.386 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:37:54.386 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3ABedroom'
08:37:54.387 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:37:54.387 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.82.250%3A47607'
08:37:54.387 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel power for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state ON
08:37:54.389 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A0'
08:37:54.391 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel control for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state PAUSE
08:37:54.393 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel playPause for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state OFF
08:37:54.393 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel stop for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state ON
08:37:54.393 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlayingTime for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 0
08:37:54.394 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:37:54.394 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel duration for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 662
08:37:54.395 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:37:54.395 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel volume for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 14
08:37:54.395 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlaylistRepeat for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 0
08:37:54.400 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlaylistShuffle for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 0
08:37:54.400 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:37:54.400 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A12'
08:37:54.400 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c' changed from INITIALIZING to ONLINE
08:37:54.401 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel playListIndex for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 12
08:37:54.401 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366413.35996'
08:37:54.401 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel numberPlaylistTracks for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 13
08:37:54.402 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:37:54.402 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A12'
08:37:54.402 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26990'
08:37:54.403 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel title for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state Sturz In Die Schlucht
08:37:54.403 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A1beae404'
08:37:54.408 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel coverartdata for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state raw type (image/jpeg): 176198 bytes
08:37:54.411 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel remotetitle for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state
08:37:54.411 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel artist for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state A Fragezeichen
08:37:54.412 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel album for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 112 - Schlucht der Daemonen
08:37:54.412 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel genre for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state Hoerspiel
08:37:54.412 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel year for thing squeezebox:squeezeboxplayer:bdc389b8:000420268757 with mac 00:04:20:26:87:57 to state 2003
**08:37:57.350 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100**
**08:37:57.351 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: favorites items 0 100 title%3AFavorites id%3A0 name%3A1%20LIVE type%3Aaudio isaudio%3A1 hasitems%3A0 id%3A1 name%3A1.0 type%3Aplaylist isaudio%3A1 hasitems%3A1 id%3A2 name%3AOh%20What%20A%20Night type%3Aaudio isaudio%3A1 hasitems%3A0 count%3A3**
**08:37:57.352 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Player 00:04:20:2a:0b:6c updating favorites list with 2 favorites**
**08:37:57.352 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Player 00:04:20:26:87:57 updating favorites list with 2 favorites**
**08:37:57.352 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Updating favorites channel for squeezebox:squeezeboxserver:bdc389b8 to state 0=1 LIVE,2=Oh What A Night**
08:37:57.628 [INFO ] [smarthome.event.ItemStateChangedEvent] - Shellyswitch25_692602_temp changed from 52.96 to 52.87
08:37:58.563 [INFO ] [smarthome.event.ItemStateChangedEvent] - Shellyswitch25_BA8E46_temp changed from 51.42 to 51.52
08:38:01.115 [INFO ] [smarthome.event.ItemStateChangedEvent] - Shellyswitch25_BA6D8C_temp changed from 48.37 to 48.46
08:38:01.287 [INFO ] [smarthome.event.ItemStateChangedEvent] - Shellyswitch25_BA7002_temp changed from 53.76 to 53.87
08:38:04.315 [DEBUG] [ernal.handler.SqueezeBoxServerHandler] - Sending command: players 0
08:38:04.317 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: players 0  count%3A2 playerindex%3A0 playerid%3A00%3A04%3A20%3A2a%3A0b%3A6c uuid%3A265e785f5dfa86060a3eb3cec2bb115c ip%3A10.194.83.128%3A52420 name%3AAnton seq_no%3A25 model%3Ababy modelname%3ASqueezebox%20Radio power%3A0 isplaying%3A0 displaytype%3Anone isplayer%3A1 canpoweroff%3A1 connected%3A1 firmware%3A7.7.3-r16676 playerindex%3A1 playerid%3A00%3A04%3A20%3A26%3A87%3A57 uuid%3A8badcea77ed326e0bc3635b95269d3fa ip%3A10.194.82.250%3A47607 name%3ABedroom seq_no%3A12 model%3Ababy modelname%3ASqueezebox%20Radio power%3A1 isplaying%3A0 displaytype%3Anone isplayer%3A1 canpoweroff%3A1 connected%3A1 firmware%3A7.7.3-r16676
08:38:04.356 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A2a%3A0b%3A6c status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3AAnton player_connected%3A1 player_ip%3A10.194.83.128%3A52420 power%3A0 signalstrength%3A75 mode%3Astop time%3A23.9965741157532 rate%3A1 duration%3A195.533 can_seek%3A1 mixer%20volume%3A45 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A25 playlist_cur_index%3A4 playlist_timestamp%3A1588366206.68254 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A4 id%3A26043 title%3AShe's%20A%20Killer year%3A2011 artist%3AGuano%20Apes genre%3ARock artwork_track_id%3A66055554 album%3ABel%20Air coverart%3A1 coverid%3A91b9f385
08:38:04.357 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A2a%3A0b%3A6c'
08:38:04.357 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:04.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:04.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:04.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:04.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:04.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3AAnton'
08:38:04.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:04.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.83.128%3A52420'
08:38:04.360 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel power for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state OFF
08:38:04.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A75'
08:38:04.360 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel control for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state PAUSE
08:38:04.360 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel playPause for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state OFF
08:38:04.361 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel stop for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state ON
08:38:04.361 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlayingTime for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 23
08:38:04.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:04.361 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel duration for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 195
08:38:04.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:04.361 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel volume for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 45
08:38:04.361 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlaylistRepeat for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 0
08:38:04.362 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlaylistShuffle for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 0
08:38:04.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:04.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A25'
08:38:04.362 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel playListIndex for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 4
08:38:04.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366206.68254'
08:38:04.362 [TRACE] [ernal.handler.SqueezeBoxPlayerHandler] - Updating channel numberPlaylistTracks for thing squeezebox:squeezeboxplayer:bdc389b8:0004202a0b6c with mac 00:04:20:2a:0b:6c to state 13
08:38:04.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:04.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A4'
08:38:04.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26043'
08:38:04.371 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A66055554'
08:38:04.372 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A26%3A87%3A57 status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3ABedroom player_connected%3A1 player_ip%3A10.194.82.250%3A47607 power%3A1 signalstrength%3A0 mode%3Astop time%3A0 rate%3A1 duration%3A662.943 can_seek%3A1 mixer%20volume%3A14 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A12 playlist_cur_index%3A12 playlist_timestamp%3A1588366413.35996 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A12 id%3A26990 title%3ASturz%20In%20Die%20Schlucht year%3A2003 artist%3AA%20Fragezeichen genre%3AHoerspiel artwork_track_id%3A1beae404 album%3A112%20-%20Schlucht%20der%20Daemonen coverart%3A1 coverid%3A1beae404
08:38:04.373 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A26%3A87%3A57'
08:38:04.373 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:04.373 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:04.374 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:04.374 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:04.375 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:04.375 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3ABedroom'
08:38:04.375 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:04.376 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.82.250%3A47607'
08:38:04.376 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A0'
08:38:04.379 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:04.379 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:04.380 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:04.380 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A12'
08:38:04.381 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366413.35996'
08:38:04.381 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:04.381 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A12'
08:38:04.382 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26990'
08:38:04.382 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A1beae404'
08:38:12.029 [INFO ] [smarthome.event.ThingUpdatedEvent    ] - Thing 'nanoleaf:controller:1627EE307799' has been updated.
08:38:12.407 [INFO ] [smarthome.event.ItemStateChangedEvent] - miNetLife changed from 17527 to 17587
08:38:14.358 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A2a%3A0b%3A6c status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3AAnton player_connected%3A1 player_ip%3A10.194.83.128%3A52420 power%3A0 signalstrength%3A75 mode%3Astop time%3A23.9965741157532 rate%3A1 duration%3A195.533 can_seek%3A1 mixer%20volume%3A45 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A25 playlist_cur_index%3A4 playlist_timestamp%3A1588366206.68254 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A4 id%3A26043 title%3AShe's%20A%20Killer year%3A2011 artist%3AGuano%20Apes genre%3ARock artwork_track_id%3A66055554 album%3ABel%20Air coverart%3A1 coverid%3A91b9f385
08:38:14.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A2a%3A0b%3A6c'
08:38:14.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:14.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:14.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:14.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:14.359 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3AAnton'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.83.128%3A52420'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A75'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A25'
08:38:14.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366206.68254'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A4'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26043'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A66055554'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A26%3A87%3A57 status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3ABedroom player_connected%3A1 player_ip%3A10.194.82.250%3A47607 power%3A1 signalstrength%3A0 mode%3Astop time%3A0 rate%3A1 duration%3A662.943 can_seek%3A1 mixer%20volume%3A14 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A12 playlist_cur_index%3A12 playlist_timestamp%3A1588366413.35996 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A12 id%3A26990 title%3ASturz%20In%20Die%20Schlucht year%3A2003 artist%3AA%20Fragezeichen genre%3AHoerspiel artwork_track_id%3A1beae404 album%3A112%20-%20Schlucht%20der%20Daemonen coverart%3A1 coverid%3A1beae404
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A26%3A87%3A57'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:14.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3ABedroom'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.82.250%3A47607'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A0'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:14.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A12'
08:38:14.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366413.35996'
08:38:14.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:14.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A12'
08:38:14.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26990'
08:38:14.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A1beae404'
08:38:17.253 [INFO ] [smarthome.event.ItemStateChangedEvent] - Shellyswitch25_691EE5_temp changed from 56.29 to 56.40
08:38:24.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A2a%3A0b%3A6c status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3AAnton player_connected%3A1 player_ip%3A10.194.83.128%3A52420 power%3A0 signalstrength%3A73 mode%3Astop time%3A23.9965741157532 rate%3A1 duration%3A195.533 can_seek%3A1 mixer%20volume%3A45 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A25 playlist_cur_index%3A4 playlist_timestamp%3A1588366206.68254 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A4 id%3A26043 title%3AShe's%20A%20Killer year%3A2011 artist%3AGuano%20Apes genre%3ARock artwork_track_id%3A66055554 album%3ABel%20Air coverart%3A1 coverid%3A91b9f385
08:38:24.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A2a%3A0b%3A6c'
08:38:24.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3AAnton'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.83.128%3A52420'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A73'
08:38:24.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:24.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:24.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:24.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A25'
08:38:24.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366206.68254'
08:38:24.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:24.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A4'
08:38:24.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26043'
08:38:24.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A66055554'
08:38:24.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A26%3A87%3A57 status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3ABedroom player_connected%3A1 player_ip%3A10.194.82.250%3A47607 power%3A1 signalstrength%3A0 mode%3Astop time%3A0 rate%3A1 duration%3A662.943 can_seek%3A1 mixer%20volume%3A14 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A12 playlist_cur_index%3A12 playlist_timestamp%3A1588366413.35996 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A12 id%3A26990 title%3ASturz%20In%20Die%20Schlucht year%3A2003 artist%3AA%20Fragezeichen genre%3AHoerspiel artwork_track_id%3A1beae404 album%3A112%20-%20Schlucht%20der%20Daemonen coverart%3A1 coverid%3A1beae404
08:38:24.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A26%3A87%3A57'
08:38:24.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:24.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:24.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:24.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:24.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:24.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3ABedroom'
08:38:24.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:24.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.82.250%3A47607'
08:38:24.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A0'
08:38:24.367 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:24.367 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:24.367 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:24.367 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A12'
08:38:24.368 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366413.35996'
08:38:24.368 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:24.368 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A12'
08:38:24.368 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26990'
08:38:24.369 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A1beae404'
08:38:27.638 [INFO ] [smarthome.event.ItemStateChangedEvent] - Shellyswitch25_692602_temp changed from 52.87 to 52.96
08:38:28.570 [INFO ] [smarthome.event.ItemStateChangedEvent] - Shellyswitch25_BA8E46_temp changed from 51.52 to 51.42
08:38:34.360 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A2a%3A0b%3A6c status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3AAnton player_connected%3A1 player_ip%3A10.194.83.128%3A52420 power%3A0 signalstrength%3A75 mode%3Astop time%3A23.9965741157532 rate%3A1 duration%3A195.533 can_seek%3A1 mixer%20volume%3A45 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A25 playlist_cur_index%3A4 playlist_timestamp%3A1588366206.68254 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A4 id%3A26043 title%3AShe's%20A%20Killer year%3A2011 artist%3AGuano%20Apes genre%3ARock artwork_track_id%3A66055554 album%3ABel%20Air coverart%3A1 coverid%3A91b9f385
08:38:34.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A2a%3A0b%3A6c'
08:38:34.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:34.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:34.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:34.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:34.361 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3AAnton'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.83.128%3A52420'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A75'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A25'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366206.68254'
08:38:34.362 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A4'
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26043'
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A66055554'
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Message received: 00%3A04%3A20%3A26%3A87%3A57 status - 1 subscribe%3A10 tags%3AyagJlNKjc player_name%3ABedroom player_connected%3A1 player_ip%3A10.194.82.250%3A47607 power%3A1 signalstrength%3A0 mode%3Astop time%3A0 rate%3A1 duration%3A662.943 can_seek%3A1 mixer%20volume%3A14 playlist%20repeat%3A0 playlist%20shuffle%3A0 playlist%20mode%3Aoff seq_no%3A12 playlist_cur_index%3A12 playlist_timestamp%3A1588366413.35996 playlist_tracks%3A13 digital_volume_control%3A1 playlist%20index%3A12 id%3A26990 title%3ASturz%20In%20Die%20Schlucht year%3A2003 artist%3AA%20Fragezeichen genre%3AHoerspiel artwork_track_id%3A1beae404 album%3A112%20-%20Schlucht%20der%20Daemonen coverart%3A1 coverid%3A1beae404
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '00%3A04%3A20%3A26%3A87%3A57'
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
08:38:34.363 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
08:38:34.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
08:38:34.364 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
08:38:34.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3ABedroom'
08:38:34.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
08:38:34.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.194.82.250%3A47607'
08:38:34.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A0'
08:38:34.365 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
08:38:34.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
08:38:34.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
08:38:34.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A12'
08:38:34.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1588366413.35996'
08:38:34.366 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
08:38:34.368 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A12'
08:38:34.369 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A26990'
08:38:34.369 [TRACE] [ernal.handler.SqueezeBoxServerHandler] - Unhandled status message type 'artwork_track_id%3A1beae404'
And the services:
[org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.homeconnect.internal.type.HomeConnectDynamicStateDescriptionProvider]
[org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.mqtt.generic.MqttChannelStateDescriptionProvider]
Using only Basic UI but the selection stays empty
Thanks for following up so thoroughly on my personal issue :slight_smile:
It is the Home Connect binding…
I tried disabling it and immediately the Favorites became available.
Hmm. What is that? I didn’t see it in your list above, and it doesn’t appear to be in the distribution.
This likely is the same issue as the Sony binding. Given that Home Connect uses state options, and that the squeezebox favorites started working immediately after you disabled Home Connect, I’m assuming its implementation of getStateDescription is broken. We need to get the Home Connect developer to fix the binding.
If interested, you can read more about the issue here.
@DUSAG0211 Is this what you’re using?
I found the PR for Home Connect and will try to get this fixed.
See here.
https://github.com/openhab/openhab-addons/pull/6794/files#r418949107
yes that is the one. Actually not really using it as I found out that the API lacks functions I need.
But the beta binding was still active.
Indeed not listed before since I kind of forgot about it.
Glad we got it sorted out. A while back I went through all the bindings in the distro looking for ones that had broken getStateDescription implementations. Since you weren’t using the Sony binding, I knew it had to be something else…
Hi all,
I seem to have a similar problem, but i can’t figure it out.
Running OH 2.5.4-1 freshly installed 2 days ago after a corrupted SD card…
installed bindings
-Astro
-Hue
-MQTT
-MTP
-Samsung TV
-Sonos
-Squeezebox (the fixed version mentioned above)
-Z-wave
The restart of the binding gives the following messages:
2020-05-13 16:49:21.254 [DEBUG] [SqueezeBoxPlayerDiscoveryParticipant] - Request player job scheduled to run every 60 seconds
2020-05-13 16:49:21.321 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - initializing server handler for thing squeezebox:squeezeboxserver:squeezeserver
2020-05-13 16:49:21.338 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - listener connection started to server 192.168.0.146:9090
2020-05-13 16:49:21.371 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: players 0
2020-05-13 16:49:21.376 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: listen 1
2020-05-13 16:49:21.413 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:42:2c:f4 status - 1 subscribe:10 tags:yagJlNKjc
2020-05-13 16:49:21.501 [DEBUG] [rnal.handler.SqueezeBoxPlayerHandler] - player thing squeezebox:squeezeboxplayer:squeezeserver:b827eb422cf4 initialized with mac b8:27:eb:42:2c:f4
2020-05-13 16:49:24.375 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100
2020-05-13 16:49:31.260 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: players 0
2020-05-13 16:50:31.262 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: players 0
2020-05-13 16:55:36.106 [TRACE] [rnal.handler.SqueezeBoxPlayerHandler] - Player b8:27:eb:42:2c:f4 updating favorites list with 4 favorites
Item is set and linked to channel but is not populated and empty in my sitemap.
Does anyone have a clue?
Kind regards,
Tedje
Please run this on the console and report back the output.
Hi Mark,
Thanks for helping me!
This is the output:
[org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.sonos.internal.SonosStateDescriptionOptionProvider]
Those bindings all have well-behaved StateDescriptionProviders, so that doesn’t appear to be an issue.
And from the log you posted, the SqueezeBoxServerHandler clearly is sending the favorites to the Player Handler.
Can you share your item and sitemap definitions for the Player Handler’s playFavorite channel?
Also, if you have an item linked to the SqueezeBox Server’s favoritesList channel, can you share the state of that item?
From the console, run this and post the result.
smarthome:items list | grep NameOfTheItem
The output from the console:
wkradio_fav (Type=StringItem, State=NULL, Label=Play Favorite, Category=null)
Item:
String wkradio_fav    "Play Favorite [%s]"  { channel="squeezebox:squeezeboxplayer:squeezeserver:b827eb422cf4:playFavorite" }
Sitemap:
Selection item=wkradio_fav label="Favorites" icon="office"
