UI Widget: Weather
This looks pretty cool - can you share the yaml file?
how do you impliment these into habpanel? ive got the top example working in OH3 under the developer setting to add widgets and added it to a page but cant work out how to get working in habpanel?
Those widgets cannot be used in habpanel.
Dear all
Based on thermostat widget by Nico_R I create widgets for personal weather station
Here
Any suggestion are welcome
These widgets look very nice.
I’ve never done this before, but I guess the items and things are created using with Developer Tools/Add Items from textual definition. I copied the text there, but it didn’t work:
Could you give me a tip what needs to be done?
Let’s suppose I get this running, do I create the OWM-weather ITEMS the same way or is this only for THING-creation?
@Ursusprimus did you check OP. There is a guide on how to add owm things and items.
This guide worked for me very well.
Hey @Ursusprimus
you can add the things / items either via the UI or with textfiles. It seems you try to add the *.things definition as item (which won’t work).
I would advise you using the UI, if you’re new to openHAB. Have a look here for a more detailed explanation of how to set-up.
@RGroll
Thank you for the link which helped me understand what to do.
I seem to have made a mistake though and am not sure which and where. Looks like my items have the wrong name; at least they aren’t found by the widget.
Is there a simple way to either change it in the widget or the item-names? If not and I should create the items again: Any idea where I might have gone wrong and what the name structure should be like?
Another thing: In the description it says that the widget is supposed to be part of a popup. I didn’t find a popup widget in the page-library. Where should I look?
Sorry for such simple questions but OH is a little overwhelming for a beginner …
Hey @Ursusprimus
everything seems fine with the item naming. You have to add the itemPrefix in the widget configuration like described in the first post of this thread:
:exclamation: Info: If you used the above item-naming pattern you’ve to assign OneCallAPIweatherandforecast_ as itemPrefix (and Localweatherandforecast_ as additional itemPrefix if you want to show the Location automatically) within the widget-configuration.
Thank you! With your help even I got it running :wink:
Hi @RGroll
Thanks for the great work and the effort you have been putting in.
I really like your "Weather popup #2 (extended), which I have managed to get working nicely. But then wanted to add to it…
I managed to add the UV Index without too much hassle. As you will see below.
Next I want to add the Daily Min and Max temperatures next to the Daily Temp, Something like:
From looking at your other examples and trying to work out how it all works it looks like I need to use an f7-row for the Current Temp and Min and Max as "labels inside that.
I am however stuck at just putting the Current Temp in its won row - it throws most of the rest of the layout off completely and I just cannot work out what I have done to break it.
Any pointers to references for the F5-block, row etc would be appreciated. I tried looking at the docs referenced in “Building Pages: Components & Widgets” but I do not get how they tie back to the blocks, rows and columns in OpenHab. Maybe because I have zero CSS knowledge.
So this is what I get right now:
Any guidance on what I have done wrong to “lose” the Current Temp and mess up the alignment of the rest?. Would love to move one step forward and try and get the rest working myself - or even just have the MIN and MAX words there and can try figure the rest out.
How do you work on your layout? Do you use the Widget Builder directly or some other tools?
My Current YAML Code follows
uid: weatherPopup_extended_uv_feel_min_max
tags:
  - weather
  - popup
  - daily forecast
  - OpenWeatherMap
  - extended
props:
  parameters:
    - description: <b>Optional prefix</b> for item names.
      label: Item prefix
      required: false
      type: TEXT
      groupName: general
    - description: <b>Additional prefix</b> for item names that belongs to another Things channel (valid for 'StationName' as it might differ)
      label: Additional item prefix
      required: false
      type: TEXT
      groupName: general
      advanced: true
    - description: The number of hours you want to forecast (<u>default:</u> <b>12</b>)
      label: Number of hours to forecast
      required: false
      type: TEXT
      groupName: general
    - description: The number of days you want to forecast (<u>default:</u> <b>3</b>)
      label: Number of days to forecast
      required: false
      type: TEXT
      groupName: general
    - description: Activate day & night Indication on hourly forecast (background color & sunrise / sunset indicator icon)
      label: Show sunrise & sunset
      required: false
      type: BOOLEAN
      groupName: general
    - description: Acitvate 24-hour clock-format (<u>default:</u> <b>12-hour clock-format</b>)
      label: 24h clock-format
      required: false
      type: BOOLEAN
      groupName: general
    - description: Add suffix to the timestamp
      label: Custom timestamp suffix
      required: false
      type: TEXT
      groupName: general
    - description: Overwrite the location header
      label: Location title
      required: false
      type: TEXT
      groupName: general
    - description: Folder where you stored your weather-images (<u>default:</u> <b>/static/files/weather_img/</b>)
      label: Image folder
      required: false
      type: TEXT
      groupName: images
    - description: Select a local sight as a centered image (preferably *.svg with the <b>image-content aligned at the bottom</b>)
      label: Local sight image-name
      required: false
      type: TEXT
      groupName: images
    - description: Select a global background-image which will be visible on daytime
      label: Global background image (day-cycle)
      required: true
      type: TEXT
      groupName: images
    - description: Select a global background-image which will be visible on nighttime
      label: Global background image (night-cycle)
      required: true
      type: TEXT
      groupName: images
    - description: Disable background images (local sight & background-image)
      label: Disable local-sight image
      required: false
      type: BOOLEAN
      groupName: images
      advanced: true
    - description: Alternative title for 'x-hour forecast' within the segmented control, where x gets replaced by the number of hours automatically. (<u>default:</u> <b>-hour forecast</b>)
      label: Translation 'x-hour forecast'
      required: false
      type: TEXT
      groupName: wording
    - description: Alternative title for 'x-day forecast' within the segmented control, where x gets replaced by the number of days automatically. (<u>default:</u> <b>-day forecast</b>)
      label: Translation 'x-day forecast'
      required: false
      type: TEXT
      groupName: wording
    - description: Alternative title for 'Now' in the 12-hour forecast tab
      label: Translation 'Now'
      required: false
      type: TEXT
      groupName: wording
    - description: Alternative title for 'Today' in the 3-day-forecast tab
      label: Translation 'Today'
      required: false
      type: TEXT
      groupName: wording
    - description: Alternative text for 'Sunrise at' in the icon-tooltip (only visible if you've activated the day & night indication)
      label: Translation 'Sunrise at'
      required: false
      type: TEXT
      groupName: wording
    - description: Alternative text for 'Sunset at' in the icon-tooltip (only visible if you've activated the day & night indication)
      label: Translation 'Sunset at'
      required: false
      type: TEXT
      groupName: wording
  parameterGroups:
    - name: general
      label: General settings
      description: All settings which are related to the usage of this widget
    - name: images
      label: Image settings
    - name: wording
      label: Language settings
      description: Set alternative wordings
timestamp: Mar 3, 2021, 3:02:56 PM
component: f7-page
  style:
    background: "=(dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state) ? 'linear-gradient(to bottom, #355b8e, #c0d4f0)' : 'repeat-x radial-gradient(white, rgba(255,255,255,.2) 2px, transparent 5px) 50px 0px/420px 420px, repeat-x radial-gradient(white, rgba(255,255,255,.2) 2px, transparent 5px) 10px 0px/650px 650px, repeat-x radial-gradient(white, rgba(255,255,255,.2) 2px, transparent 5px) 200px 0px/450px 450px, repeat-x radial-gradient(white, rgba(255,255,255,.2) 2px, transparent 5px) 200px 80px/350px 350px, repeat-x radial-gradient(white, rgba(255,255,255,.2) 2px, transparent 5px) 0px 0px/260px 260px, repeat-x radial-gradient(white, rgba(255,255,255,.15) 1px, transparent 3px) 50px 0px/200px 200px, repeat-x radial-gradient(white, rgba(255,255,255,.1) 2px, transparent 4px) 130px 0px/250px 100px, repeat-x radial-gradient(rgba(255,255,255,.4), rgba(255,255,255,.1) 2px, transparent 1px) 50px 0px/150px 50px, repeat-x radial-gradient(white, rgba(255,255,255,.2) 1px, transparent 2px) 50px 0px/280px 480px, repeat-x radial-gradient(white, rgba(255,255,255,.2) 1px, transparent 2px) 70px 0px/180px 350px, repeat-x radial-gradient(white, rgba(255,255,255,.1) 1px, transparent 1px) 80px 0px/200px 120px, repeat-x radial-gradient(white, rgba(255,255,255,.1) 2px, transparent 2px) 100px 0px/200px 180px, repeat-x radial-gradient(white, rgba(255,255,255,.1) 1px, transparent 5px) 100px 0px/350px 600px, linear-gradient(to bottom,#413D8F 0%,#CE9FC8 100%)'"
    background-repeat: repeat-x
    -ms-user-select: none
    -moz-user-select: none
    -webkit-user-select: none
    user-select: none
    overflow: hidden
    --f7-page-navbar-offset: none
    --f7-page-toolbar-top-offset: none
    --f7-page-subnavbar-offset: none
    --f7-page-searchbar-offset: none
    --f7-page-content-extra-padding-top: none
    --f7-page-toolbar-bottom-offset: none
    --f7-page-content-extra-padding-bottom: none
    --f7-theme-color: none
    --f7-bars-bg-color: none
    --f7-bars-border-color: none
    --f7-navbar-shadow-image: none
    --f7-navbar-text-color: white
    --f7-bars-text-color: white
    --f7-navbar-link-color: white
    --f7-navbar-bg-color-rgb: none
    --f7-bars-bg-color-rgb: none
    --f7-bars-translucent-opacity: none
    --f7-bars-translucent-blur: none
    backdrop-filter: none
    --f7-button-border-radius: 0
    --weather-condition-icon-size: 30px
    --weather-label-text-transform: normal
    --weather-font-size-xsmall: 14px
    --weather-font-size-small: 16px
    --weather-font-size-medium: 18px
    --weather-font-size-hero: 91px
    --weather-font-color-main: white
    --weather-forecast-location-font-color: rgba(255,255,255,.7)
    --weather-forecast-text-shadow-light: 2px 2px rgba(0,0,0,.15)
    --weather-forecast-text-shadow-strong: 2px 2px rgba(0,0,0,.35)
    --weather-forecast-font-color-light: rgba(0,0,0,.35)
    --weather-forecast-font-color: rgba(0,0,0,.7)
slots:
  default:
    - component: Label
        text: "=!props.locationTitle ? items[(!props.itemPrefix2 ? (!props.itemPrefix ? '' : props.itemPrefix) : props.itemPrefix2) + 'StationName'].state : props.locationTitle"
        class:
          - text-align-right
          - padding-right
        style:
          text-overflow: ellipsis
          overflow: hidden
          line-height: var(--f7-navbar-link-line-height,var(--f7-navbar-height))
          font-size: var(--weather-font-size-xsmall)
          color: var(--weather-forecast-location-font-color)
          text-shadow: var(--weather-forecast-text-shadow-light)
          text-transform: uppercase
    - component: f7-block
        text-align: center
        class:
          - no-margin
          - no-padding
      slots:
        default:
          - component: f7-row
              class: justify-content-center
              slots:
                default:
                  - component: Label
                      text: "=(!props.itemPrefix) ? Math.round(items.Current_Temperature.state.split(' ')[0]) + '°' : Math.round(items[props.itemPrefix + 'Current_Temperature'].state.split(' ')[0]) + '°'"
                      style:
                        font-size: var(--weather-font-size-hero)
                        font-weight: lighter
                        line-height: var(--weather-font-size-hero)
                        color: var(--weather-font-color-main)
                        text-shadow: var(--weather-forecast-text-shadow-strong)
                        white-space: nowrap
                        overflow: hidden
          - component: f7-row
            slots: {}
          - component: Label
              text: "=(!props.itemPrefix) ? items.Current_Apparenttemperature.state : 'Feels Like: ' + items[props.itemPrefix + 'Current_Apparenttemperature'].state "
              class:
                - align-self-center
              style:
                font-size: var(--weather-font-size-medium)
                white-space: nowrap
                overflow: hidden
                z-index: 999
          - component: Label
              text: "=(!props.itemPrefix) ? items.Current_Condition.state : items[props.itemPrefix + 'Current_Condition'].state"
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
          - component: Label
              text: "=(!props.itemPrefix) ? items.UVIndex.state : 'UV Index: ' + items[props.itemPrefix + 'UVIndex'].state "
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
          - component: Label
        class:
          - no-margin
          - no-padding
        style:
          background: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01d') ? '' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01n') ? '' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02d') ? 'no-repeat top center/750px url(' + ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + '02.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '02.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03d') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '03.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '03.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04d') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '04.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '04.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09d') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '09.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '09.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10d') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '10.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '10.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11d') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '11.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '11.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13d') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '13.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '13.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50d') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '50.svg)' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50n') ? 'no-repeat top center/750px url(' + ((props.imageFolder === undefined) ? '/static/files/weather_img/' : props.imageFolder) + '50.svg)' : '?'"
          height: 100%
          width: 100%
          position: absolute
          top: 0
          left: 0
          right: 0
    - component: oh-image
        url: "=(dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state ) ? ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + 'sun.svg' : ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + 'moon.svg'"
        style:
          width: 100%
          max-width: 150px
          min-width: 70px
          position: absolute
          top: 5px
          left: -50px
          z-index: 999
        style:
          overflow: hidden
          position: absolute
          bottom: 105px
          width: 100%
          height: 100%
          z-index: -1
      slots:
        default:
              visible: =!props.disableLocalSightBg
              url: "=(dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state ) ? ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + props.globalBackgroundDayImg : ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + props.globalBackgroundNightImg"
              style:
                position: absolute
                bottom: 0
                right: 0
                left: 0
                margin-right: auto
                margin-left: auto
                width: 100%
                min-width: 800px
                max-width: 1200px
        url: "=((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + props.localSightImg"
        style:
          position: absolute
          bottom: 138px
          right: 0
          left: 0
          margin-right: auto
          margin-left: auto
          width: 100%
          min-width: 150px
          max-width: 280px
          z-index: 1
        class:
          - text-align-center
          - align-content-bottom
          - no-margin
        style:
          border-top: 60px solid white
          border-image-source: "='url(' + ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + 'bottom_mask-white.svg' + ')'"
          -moz-border-image-source: "='url(' + ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + 'bottom_mask-white.svg' + ')'"
          -webkit-border-image-source: "='url(' + ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + 'bottom_mask-white.svg' + ')'"
          -o-border-image-source: "='url(' + ((!props.imageFolder) ? '/static/files/weather_img/' : props.imageFolder) + 'bottom_mask-white.svg' + ')'"
          -webkit-appearance: none
          border-image-slice: 100% 0 0 0
          border-image-width: 1 0 0 0
          position: absolute
          bottom: 0
          left: 0
          width: 100%
      slots:
        default:
              class:
                - no-margin
                - no-padding
              style:
                position: absolute
                left: 0
                bottom: 0
                height: calc(100% + 2px)
                width: 100%
                background: white
                -webkit-box-shadow: 10px 10px 10px 20px white
                -moz-box-shadow: 10px 10px 10px 20px white
          - component: f7-segmented
              strong: true
              style:
                --f7-segmented-strong-button-active-box-shadow: 0 4px 0px -2px gray
                --f7-segmented-strong-button-font-color: gray
                --f7-segmented-strong-bg-color: white
                z-index: 999
            slots:
              default:
                - component: oh-button
                    text: '=(!props.wordingForecastHours && !props.forecastHours) ? "12-hour forecast" : (props.wordingForecastHours && !props.forecastHours) ? 12 + props.wordingForecastHours : (!props.wordingForecastHours && props.forecastHours) ? props.forecastHours + "-hour forecast" : props.forecastHours + props.wordingForecastHours'
                    active: =!vars.tab || vars.tab === 'hourly_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: hourly_forecast
                    style:
                      color: '=(vars.tab === "daily_forecast") ? "lightgray" : "black"'
                    text: '=(!props.wordingForecastDays && !props.forecastDays) ? "3-day forecast" : (props.wordingForecastDays && !props.forecastDays) ? 3 + props.wordingForecastDays : (!props.wordingForecastDays && props.forecastDays) ? props.forecastDays + "-day forecast" : props.forecastDays + props.wordingForecastDays'
                    active: =vars.tab === 'daily_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: daily_forecast
                    style:
                      color: '=(!vars.tab || vars.tab === "hourly_forecast") ? "lightgray" : "black"'
          - component: f7-swiper
              visible: =!vars.tab || vars.tab === 'hourly_forecast'
              navigation: true
              class:
                - padding-top
                - padding-bottom
              params:
                initalSlide: 0
                runCallbacksOnInit: true
                grabCursor: true
                observer: true
                observeSlideChildren: true
                updateOnWindowResize: true
                spaceBetween: 5
                mousewheel: true
                keyboard: true
                watchOverflow: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "240":
                    slidesPerView: "=(!props.forecastHours) ? 2 : ((props.forecastHours < 2) ? Math.round(Number(props.forecastHours) + 1) : 2)"
                  "320":
                    slidesPerView: "=(!props.forecastHours) ? 3 : ((props.forecastHours < 3) ? Math.round(Number(props.forecastHours) + 1) : 3)"
                  "480":
                    slidesPerView: "=(!props.forecastHours) ? 4 : ((props.forecastHours < 4) ? Math.round(Number(props.forecastHours) + 1) : 4)"
                  "640":
                    slidesPerView: "=(!props.forecastHours) ? 5 : ((props.forecastHours < 5) ? Math.round(Number(props.forecastHours) + 1) : 5)"
              style:
                --swiper-navigation-size: 20px
                --swiper-navigation-color: gray
            slots:
              default:
                - component: oh-repeater
                    sourceType: range
                    for: hour
                    rangeStart: 0
                    rangeStop: "=(!props.forecastHours) ? 12 : Number(props.forecastHours)"
                    fragment: true
                  slots:
                    default:
                      - component: f7-swiper-slide
                          style:
                            background: "=(props.sunIndicator === true) ? ((dayjs().add(loop.hour,'hour').format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state && dayjs().add(loop.hour,'hour').format() <= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state) ? 'rgba(44,130,201,.15)' : 'rgba(190,144,212,.15)') : 'none'"
                            border-radius: 5px
                        slots:
                          default:
                            - component: f7-icon
                                visible: "=(dayjs().add(loop.hour,'hour').startOf('hour').format() === dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).startOf('hour').format() && props.sunIndicator === true)"
                                f7: sun_max_fill
                                color: black
                                tooltip: "=((!props.wordingSunrise) ? 'Sunrise at ' : props.wordingSunrise + ' ') + ((!props.dateFormat) ? dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).format('h:mm A') : dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).format('H:mm')+' h') + '<br><b>' + dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).fromNow() + '</b>'"
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 9999
                                visible: "=(dayjs().add(loop.hour,'hour').startOf('hour').format() === dayjs(items['Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).startOf('hour').format() && props.sunIndicator === true)"
                                f7: moon_fill
                                color: black
                                tooltip: "=((!props.wordingSunset) ? 'Sunset at ' : props.wordingSunset + ' ') + ((!props.dateFormat) ? dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).format('h:mm A') : dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).format('H:mm') + ' h') + '<br><b>' + dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).fromNow() + '</b>'"
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 9999
                            - component: f7-row
                                class:
                                  - justify-content-center
                              slots:
                                default:
                                  - component: Label
                                      text: "=(loop.hour === 0) ? ((!props.wordingNow) ? 'Now' : props.wordingNow) : ((!props.dateFormat) ? dayjs().add(loop.hour,'hour').startOf('hour').format('h A') : dayjs().add(loop.hour,'hour').startOf('hour').format('H')) + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix)"
                                      style:
                                        font-weight: 400
                                        color: var(--weather-forecast-font-color)
                                        text-transform: var(--weather-label-text-transform)
                            - component: f7-row
                                class:
                                  - align-items-center
                              slots:
                                default:
                                      f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '01d') ? 'sun_max' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '01n') ? 'moon_stars' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '02d') ? 'cloud_sun' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '02n') ? 'cloud_moon' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '03d') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '03n') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '04d') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '04n') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '09d') ? 'cloud_heavyrain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '09n') ? 'cloud_heavyrain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '10d') ? 'cloud_sun_rain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '10n') ? 'cloud_moon_rain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '11d') ? 'cloud_sun_bolt' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '11n') ? 'cloud_moon_bolt' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '13d') ? 'cloud_snow' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '13n') ? 'cloud_snow' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '50d') ? 'cloud_fog' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '50n') ? 'cloud_fog' : ''"
                                      style:
                                        padding-right: 5px
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Temperature'].state.split(' ')[0]) + '°'"
                                      style:
                                        font-size: var(--weather-font-size-small)
                                        font-weight: 700
                            - component: f7-row
                                class:
                              slots:
                                default:
                                      f7: umbrella
                                      style:
                                        color: var(--weather-forecast-font-color-light)
                                        padding-right: 3px
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1)) + '_Precipprobability'].state.split(' ')[0]) + '%'"
                                      style:
                                        font-weight: 400
              visible: =vars.tab === 'daily_forecast'
              navigation: true
              class:
                - padding-top
                - padding-bottom
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                watchOverflow: true
                mousewheel: true
                keyboard: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "210":
                    slidesPerView: "=(!props.forecastDays) ? 2 : ((props.forecastDays < 2) ? Math.round(Number(props.forecastDays) + 1) : 2)"
                  "480":
                    slidesPerView: "=(!props.forecastDays) ? 3 : ((props.forecastDays < 3) ? Math.round(Number(props.forecastDays) + 1) : 3)"
                  "640":
                    slidesPerView: "=(!props.forecastDays) ? 4 : ((props.forecastDays < 4) ? Math.round(Number(props.forecastDays) + 1) : 4)"
              style:
            slots:
              default:
                    sourceType: range
                    for: day
                    rangeStart: 0
                    rangeStop: "=(!props.forecastDays) ? 3 : Number(props.forecastDays)"
                    fragment: true
                  slots:
                    default:
                        config: {}
                        slots:
                          default:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      text: "=(loop.day === 0) ? ((!props.wordingToday) ? 'Today' : props.wordingToday) : dayjs().add(loop.day,'day').startOf('day').format('dddd')"
                                      style:
                                f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '01d') ? 'sun_max' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '01n') ? 'moon_stars' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '02d') ? 'cloud_sun' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '02n') ? 'cloud_moon' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '03d') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '03n') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '04d') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '04n') ? 'cloud' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '09d') ? 'cloud_heavyrain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '09n') ? 'cloud_heavyrain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '10d') ? 'cloud_sun_rain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '10n') ? 'cloud_moon_rain' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '11d') ? 'cloud_sun_bolt' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '11n') ? 'cloud_moon_bolt' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '13d') ? 'cloud_snow' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '13n') ? 'cloud_snow' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '50d') ? 'cloud_fog' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '50n') ? 'cloud_fog' : '?'"
                                style:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + ((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + (loop.day_idx))) + '_Maxtemperature'].state.split(' ')[0])+'°'"
                                      style:
                                        font-weight: 700
                                  - component: Label
                                      text: ""
                                      style:
                                        color: rgba(0,0,0,.2)
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + ((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + (loop.day_idx))) + '_Mintemperature'].state.split(' ')[0])+'°'"
                                      style:
                                        font-weight: 700
Many Thanks for any suggestions or ideas?
Mark
Hey @Mark_VG
first of all, thank you!
One problem was, that the indentation is a bit off. The slot of your f7-row isn’t correctly aligned.
Further more you need to put 2 columns inside the f7 row, to align the contents (Current temp & Min/Max Temp) correctly.
See the f7-docs for more informations on the used components:
Framework7 grid (f7-row / f7-col)
f7-block (only used as a wrapper for the components)
Just a quick drawn explanation of whats happening here:
to give you a first dirty soloution, without optimizing stuff, it would work like:
tags:
  - weather
  - popup
  - daily forecast
  - OpenWeatherMap
  - extended
props:
  parameters:
      label: Item prefix
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      advanced: true
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: BOOLEAN
      groupName: general
      required: false
      type: BOOLEAN
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      label: Image folder
      required: false
      type: TEXT
      groupName: images
      required: false
      type: TEXT
      groupName: images
      required: true
      type: TEXT
      groupName: images
      required: true
      type: TEXT
      groupName: images
      required: false
      type: BOOLEAN
      groupName: images
      advanced: true
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
  parameterGroups:
    - name: general
    - name: images
    - name: wording
timestamp: Mar 4, 2021, 2:42:29 PM
component: f7-page
  style:
    user-select: none
    overflow: hidden
slots:
  default:
    - component: Label
        class:
          - text-align-right
          - padding-right
        style:
          overflow: hidden
        text-align: center
        class:
          - no-margin
          - no-padding
          - text-align-center
      slots:
        default:
          - component: f7-row
              class:
                - display-flex
                - justify-content-space-between
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                      - align-self-center
                      - align-items-flex-end
                      - flex-direction-column
                  slots:
                    default:
                      - component: Label
                          style:
                            white-space: nowrap
                            overflow: hidden
                - component: f7-col
                    class:
                      - display-flex
                      - align-self-center
                      - align-items-flex-start
                    style:
                      z-index: 99
                  slots:
                    default:
                      - component: Label
                          text: "Min: 21°C"
                      - component: Label
                          text: "Max: 30°C"
          - component: Label
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
          - component: Label
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
          - component: Label
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
        class:
          - no-margin
          - no-padding
        style:
          height: 100%
          width: 100%
          position: absolute
          top: 0
          left: 0
          right: 0
        style:
          width: 100%
          max-width: 150px
          min-width: 70px
          position: absolute
          top: 5px
          left: -50px
          z-index: 999
        style:
          overflow: hidden
          position: absolute
          bottom: 105px
          width: 100%
          height: 100%
          z-index: -1
      slots:
        default:
              style:
                position: absolute
                bottom: 0
                right: 0
                left: 0
                margin-right: auto
                margin-left: auto
                width: 100%
                min-width: 800px
                max-width: 1200px
        style:
          position: absolute
          bottom: 138px
          right: 0
          left: 0
          margin-right: auto
          margin-left: auto
          width: 100%
          min-width: 150px
          max-width: 280px
          z-index: 1
        class:
          - text-align-center
          - no-margin
        style:
          position: absolute
          bottom: 0
          left: 0
          width: 100%
      slots:
        default:
              class:
                - no-margin
                - no-padding
              style:
                position: absolute
                left: 0
                bottom: 0
                width: 100%
                background: white
              strong: true
              style:
                z-index: 999
            slots:
              default:
                    action: variable
                    actionVariable: tab
                    style:
                    action: variable
                    actionVariable: tab
                    style:
              navigation: true
              class:
                - padding-top
                - padding-bottom
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                mousewheel: true
                keyboard: true
                watchOverflow: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "240":
                  "320":
                  "480":
                  "640":
              style:
            slots:
              default:
                    sourceType: range
                    for: hour
                    rangeStart: 0
                    fragment: true
                  slots:
                    default:
                          style:
                            border-radius: 5px
                        slots:
                          default:
                                f7: sun_max_fill
                                color: black
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 9999
                                f7: moon_fill
                                color: black
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 9999
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        font-weight: 400
                            - component: f7-row
                                class:
                              slots:
                                default:
                                      style:
                                        padding-right: 5px
                                  - component: Label
                                      style:
                                        font-weight: 700
                            - component: f7-row
                                class:
                              slots:
                                default:
                                      f7: umbrella
                                      style:
                                        padding-right: 3px
                                  - component: Label
                                      style:
                                        font-weight: 400
              navigation: true
              class:
                - padding-top
                - padding-bottom
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                watchOverflow: true
                mousewheel: true
                keyboard: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "210":
                  "480":
                  "640":
              style:
            slots:
              default:
                    sourceType: range
                    for: day
                    rangeStart: 0
                    fragment: true
                  slots:
                    default:
                        config: {}
                        slots:
                          default:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                style:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        font-weight: 700
                                  - component: Label
                                      text: ""
                                      style:
                                  - component: Label
                                      style:
                                        font-weight: 700
Hi @RGroll
Thank you. That is pretty much what I wanted. I managed to get a bit further during the day today after I took out all the variables and just had flat text to try and understand what was happening.
I see now that the indentation makes all the difference. Also had just realized that I needed the columns and was battling with that.
Will go through the suggested docs and see if I can understand better.
Always appreciate your work.
Hi @RGroll
I think understand the rows, columns etc now. I would have battled forever without your help. The alignment was clearly my biggest issue.
Can you point me to a resource for the different style components etc?
For example: z-index: 999 etc.
I have an issue now that on my Android Mobile the Current Temp is “behind” the SUN? So not clearly visible. Trying to fix that.
Cheers
mark
Hey @Mark_VG
glad it helped you. There are tons and tons of ressources regarding css properties - this is nothing OH-specific.
Regarding the z-index, you can find some information here for example.
I personally like the explanation of css stuff from this site:
To fix the “Sun problem” you have to set the z-index of the image-component, to a lower value than the one from the Label component which shows the current temp - something like:
YAML with min/max values (and a lower z-index)
tags:
  - weather
  - popup
  - daily forecast
  - OpenWeatherMap
  - extended
props:
  parameters:
      label: Item prefix
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      advanced: true
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: BOOLEAN
      groupName: general
      required: false
      type: BOOLEAN
      groupName: general
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
      label: Image folder
      required: false
      type: TEXT
      groupName: images
      required: false
      type: TEXT
      groupName: images
      required: true
      type: TEXT
      groupName: images
      required: true
      type: TEXT
      groupName: images
      required: false
      type: BOOLEAN
      groupName: images
      advanced: true
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
      required: false
      type: TEXT
      groupName: wording
  parameterGroups:
    - name: general
    - name: images
    - name: wording
component: f7-page
  style:
    user-select: none
    overflow: hidden
slots:
  default:
    - component: Label
        class:
          - text-align-right
          - padding-right
        style:
          overflow: hidden
        text-align: center
        class:
          - no-margin
          - no-padding
          - text-align-center
      slots:
        default:
          - component: f7-row
              class:
                - display-flex
            slots:
              default:
                - component: f7-col
                    class:
                      - display-flex
                      - align-self-center
                  slots:
                    default:
                      - component: Label
                          style:
                            white-space: nowrap
                            overflow: hidden
                            z-index: 99
                - component: f7-col
                    class:
                      - display-flex
                      - align-self-center
                    style:
                      z-index: 99
                  slots:
                    default:
                      - component: Label
                          text: "Min: 21°C"
                      - component: Label
                          text: "Max: 30°C"
          - component: Label
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
          - component: Label
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
          - component: Label
              style:
                white-space: nowrap
                overflow: hidden
                z-index: 999
        class:
          - no-margin
          - no-padding
        style:
          height: 100%
          width: 100%
          position: absolute
          top: 0
          left: 0
          right: 0
        style:
          width: 100%
          max-width: 150px
          min-width: 70px
          position: absolute
          top: 5px
          left: -50px
          z-index: 91
        style:
          overflow: hidden
          position: absolute
          bottom: 105px
          width: 100%
          height: 100%
          z-index: -1
      slots:
        default:
              style:
                position: absolute
                bottom: 0
                right: 0
                left: 0
                margin-right: auto
                margin-left: auto
                width: 100%
                min-width: 800px
                max-width: 1200px
        style:
          position: absolute
          bottom: 138px
          right: 0
          left: 0
          margin-right: auto
          margin-left: auto
          width: 100%
          min-width: 150px
          max-width: 280px
          z-index: 1
        class:
          - text-align-center
          - no-margin
        style:
          position: absolute
          bottom: 0
          left: 0
          width: 100%
      slots:
        default:
              class:
                - no-margin
                - no-padding
              style:
                position: absolute
                left: 0
                bottom: 0
                width: 100%
                background: white
              strong: true
              style:
                z-index: 999
            slots:
              default:
                    action: variable
                    actionVariable: tab
                    style:
                    action: variable
                    actionVariable: tab
                    style:
              navigation: true
              class:
                - padding-top
                - padding-bottom
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                mousewheel: true
                keyboard: true
                watchOverflow: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "240":
                  "320":
                  "480":
                  "640":
              style:
            slots:
              default:
                    sourceType: range
                    for: hour
                    rangeStart: 0
                    fragment: true
                  slots:
                    default:
                          style:
                            border-radius: 5px
                        slots:
                          default:
                                f7: sun_max_fill
                                color: black
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 9999
                                f7: moon_fill
                                color: black
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 9999
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        font-weight: 400
                            - component: f7-row
                                class:
                              slots:
                                default:
                                      style:
                                        padding-right: 5px
                                  - component: Label
                                      style:
                                        font-weight: 700
                            - component: f7-row
                                class:
                              slots:
                                default:
                                      f7: umbrella
                                      style:
                                        padding-right: 3px
                                  - component: Label
                                      style:
                                        font-weight: 400
              navigation: true
              class:
                - padding-top
                - padding-bottom
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                watchOverflow: true
                mousewheel: true
                keyboard: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "210":
                  "480":
                  "640":
              style:
            slots:
              default:
                    sourceType: range
                    for: day
                    rangeStart: 0
                    fragment: true
                  slots:
                    default:
                        config: {}
                        slots:
                          default:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                style:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        font-weight: 700
                                  - component: Label
                                      text: ""
                                      style:
                                  - component: Label
                                      style:
                                        font-weight: 700
Hi @RGroll
Once again , thanks for all the help. I am however clearly missing the basics with the F7 grids stuff.
Firstly battling to see how that ties in to the OH3 implementation… But also seem to have an issue with the alignments again.
I have been trying to add features to your PopupWidget#2 to get a grasp of the layout etc, and am now stuck with the following:
I have added the Sunrise and Sunset icons and times. This is done using columns (4 ), but then I saw your one suggestion that this may work better as just a row with the icon and text in a line?
So tried to implement that above the values shown - all I get however is a space created and nothing displays (so I think I must have messed up the alignment, but just can’t fix it.
Widget.txt (50.2 KB)
What I have "added is the following:
              class:
                - padding
              slots:
                default:
                  - component: f7-row
                      style:
                        flex-wrap: nowrap
                        z-index: 999
                    slots:
                      default:
                            f7: sunrise
                            color: white
                            class:
                              - padding-right
                  - component: Label
                      text: "Test Text"
                      style:
                        font-size: 18px
                        line-height: 30px
                        text-align: left
                        white-space: nowrap
                        overflow: hidden
My end goal is to have two columns in two rows with Today and Tomorrow with eh Sunrise and Sunset for each day.
Can you see what I have done wrong?
Mark
these are very nice widgets great work… I am using the weathercard widget. It works fine except the Icon dont show off did someone else have problems with the Icons?
Hey @Faruk
thank you!
Which icons do you mean? All of them? Did you linked the additional iconId channels which will show up when you check the “Show advanced” box on the top right of your channel overview, like mentioned here for example?
thx i just overread it that someone else had the same problem. Now it is shown all of the items.
@RGroll for the weather icon, I use this:
f7: =items[props.weather_prefix + 'Current_Iconid'].displayState
Using the MAP for the format string:
String Weather_Current_Iconid "[MAP(weathericon-f7.map):%s]" {channel="openweathermap:onecall:bridge:local:current#icon-id"}
weathericon-f7.map:
01d=sun_max_fill
01n=moon_stars_fill
02d=cloud_sun_fill
02n=cloud_moon_fill
03d=cloud_fill
03n=cloud_fill
04d=cloud_fill
04n=cloud_fill
09d=cloud_heavyrain_fill
09n=cloud_heavyrain_fill
10d=cloud_sun_rain_fill
10n=cloud_moon_rain_fill
11d=cloud_sun_bolt_fill
11n=cloud_moon_bolt_fill
13d=cloud_snow_fill
13n=cloud_snow_fill
50d=cloud_fog_fill
50n=cloud_fog_fill
