Zigbee and zwave manual install script
@Vir Did you get that?
https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/org/openhab/addons/bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
is the URL for the ZWave which I’m guessing means that
https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/org/openhab/addons/bundles/org.openhab.binding.zigbee/2.5.0-SNAPSHOT/org.openhab.binding.zigbee-2.5.0-SNAPSHOT.jar
is Zigbee.
Not sure why the script tries to pull them from Jenkins. (I’m sure there’s a valid reason, I just don’t know it) Anyhow, you can follow the manual install instructions that are in the script’s README.md.
I THINK that fixed my problem, not sure yet.
Cheers! :slight_smile:
=C=
I assume it’s because this is where the files ultimately come from. ie they are built and distributed from Jenkins in the first place.
The (reasonably new) OH server thought isn’t particularly reliable, so this might be contributing to the issues and other downstream servers may be better choices these days.
Do you know if they re working to resolve this or are funds just that tight?
I know there have been cloud server load issues too.
I have no idea how this works - if it’s a physical server or somewhere on the cloud.
When I said it was new, I didn’t mean that someone had just bought a new server, but previously we used to use cloudbees which was a public CI server, and for reasons I forget, we changed to using CI on the openhab domain which has been slightly flaky at times (I should add that most of the time it is fine) which may contribute to this issue.
Who would? Specifically, who could I ask about setting up a downstream mirror? I’ve got spare capacity and would be happy to rsync every night and make the packages available to anyone.
=C=
Probably Kai, but the artefacts are already published downstream so is there really a need for another one? I would suggest there isn’t such a need - it’s just another source of confusion and something else to go wrong isn’t it?
@chris
I looked at the script quickly and at least some pieces seem to come from your server.
http://www.cd-jackson.com/downloads/openhab2/org.openhab.binding.zwave-${OH_VERSION}-SNAPSHOT.jar
I don’t really know why - I suspect that this is only if you choose a specific option to use a custom development version supplied by me? It shouldn’t be something that people are using at all these days.
I will look at this the first chance I get, but I’m a bit busy ATM.
That is what you get with the “Development” version of the zwave binding. In the past, this is where the version with security was located before it was merged. I left it in the script since Chris has thrown some bindings out there for people to test.
Seems to work so far with Openhab 2.5.0.M3 and org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar and installed per the README manual install instructions (including adding stream and installing the serial transport feature, thanks
I’m also getting the error message in the JAR files
[21:12:29] openhabian@openHABianPi:/usr/share/openhab2/addons/archive/zwave$ ls -l
total 12
-rw-rw-r-- 1 openhab openhab 854 Sep 28 14:07 org.openhab.binding.zwave-2.5.0-SNAPSHOT.20190928141422.old
-rw-rw-r-- 1 openhab openhab 854 Sep 30 20:47 org.openhab.binding.zwave-2.5.0-SNAPSHOT.20190930205104.old
-rw-rw-r-- 1 openhab openhab 854 Sep 30 20:51 org.openhab.binding.zwave-2.5.0-SNAPSHOT.20190930210809.old
[21:12:32] openhabian@openHABianPi:/usr/share/openhab2/addons/archive/zwave$ cat org.openhab.binding.zwave-2.5.0-SNAPSHOT.2019093021*
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=utf-8"/>
<title>Error 403 Trying to access a file outside of the directory, target: org.openhab.addons.bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar</title>
</head>
<body><h2>HTTP ERROR 403</h2>
<p>Problem accessing /job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zwave/artifact/org.openhab.addons.bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar. Reason:
<pre>    Trying to access a file outside of the directory, target: org.openhab.addons.bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar</pre></p><hr><a href="http://eclipse.org/jetty">Powered by Jetty:// 9.4.z-SNAPSHOT</a><hr/>
</body>
</html>
This may be contributing to my timeout error. I am on openhab 2.4 stable, on openhabian on a Raspberry Pi 3B.
After running into challenges correctly getting the zwave binding updated, I deleted the binding with the script successfully, confirmed the serial binding was installed (the binding and the logs told me it was), and then tried to re-update the binding with the script.
sudo -u openhab ./zzManualInstall.sh
[... selecting update zwave ]
     *****     SUMMARY     *****
Addons path: /usr/share/openhab2/addons
OpenHAB account: openhab
Requested action: Install or upgrade Z-Wave binding
Current OpenHAB snapshot version: 2.5.0
Requested Z-Wave version: OpenHAB snapshot
Is this correct?
1) Yes, start now                      3) Exit
2) No, take me back to the first menu
#? 1
Uninstalling any managed binding(s) and installing serial transport...
Logging in as openhab
... a 'No matching bundles' error mesage is normal, if a binding had not been previously installed.
Backing up and uninstalling any unmanaged installs of Z-Wave...
!!!!! It has taken more than two minutes to uninstall the Z-Wave binding, so exi                                             ting !!!!!
And looking at the logs:
2019-09-30 21:07:57.782 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-09-30 21:07:57.821 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:713fde47' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-09-30 21:07:59.322 [INFO ] [internal.service.FeaturesServiceImpl] - The specified feature: 'openhab-transport-serial' version '2.4.0' is already installed
2019-09-30 21:07:59.325 [INFO ] [internal.service.FeaturesServiceImpl] - Adding features: openhab-transport-serial/[2.4.0,2.4.0]
2019-09-30 21:08:08.497 [INFO ] [internal.service.FeaturesServiceImpl] - Changes to perform:
2019-09-30 21:08:08.504 [INFO ] [internal.service.FeaturesServiceImpl] -   Region: root
2019-09-30 21:08:08.506 [INFO ] [internal.service.FeaturesServiceImpl] -     Bundles to install:
2019-09-30 21:08:08.507 [INFO ] [internal.service.FeaturesServiceImpl] -       mvn:org.openhab.binding/org.openhab.binding.zwave/2.4.0
2019-09-30 21:08:08.518 [INFO ] [internal.service.FeaturesServiceImpl] - Installing bundles:
2019-09-30 21:08:08.519 [INFO ] [internal.service.FeaturesServiceImpl] -   mvn:org.openhab.binding/org.openhab.binding.zwave/2.4.0
2019-09-30 21:08:09.160 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
The relevant directory structure and permissions:
[21:11:56] openhabian@openHABianPi:/usr/share/openhab2/addons$ ls -l
total 580
drwxrwxr-x+ 4 openhab openhab   4096 Sep 28 14:07 archive
-rw-rw-r--  1 openhab openhab 548391 Sep 30 20:51 org.apache.servicemix.bundles.xstream-1.4.7_1.jar
-rw-rw-r--  1 openhab openhab     70 Dec 17  2018 README
-rwxrw-r--  1 openhab openhab  35992 Sep 28 14:03 zzManualInstall.sh
total 12
My inferences from this, please correct me if I’m wrong:
  1. The script is attempting to download an incorrect file, at least from my stock openhabian stable 2.4 install.
  2. I’m pretty sure I have the script in the correct location, am running as the correct user,e tc.
  3. When no correct zwave binding is installed, somehow the old binding was re-installed. (I initially saw all my zwave devices not working, and had restarted the whole raspberry pi. Upon restarting, zwave was running using the old version I believe.
If this helps,
The path in the error jar file was:
I have no idea if there is a prefix that is assumed.
The currently correct and working path was:
My solution, following the readme instructions here GitHub - 5iver/openHAB-utils: Utilities for use with openHAB :
[given that these commands are so often obliquely referred to, I include the full command for others’ references]
I went into karaf
openhab-cli console
removed the current zwave binding
bundle:uninstall org.openhab.binding.zwave
downloaded the correct file to the addons directory with wget
wget https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/org/openhab/addons/bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
exited karaf
logout
and restarted the whole system (sudo reboot now). I assume this could have been done in karaf, but this works and old habits & all.
Going back into karaf console and running (bundle:list | grep ZWave) gave me:
267 x Active   x  80 x 2.5.0.201909300431     x openHAB Add-ons :: Bundles :: ZWave Binding
I assume this means I’m up and running with the most recent zwave snapshot.
Frustratingly, my new LZW30 switch is still not recognized. This is a concern for another thread.
While I initially started this post to troubleshoot the script and getting the latest zwave snapshot updated, when successful, I decided to leave it as a more complete how-to for others trying to do the same thing when 5iver’s update script is giving the download errors/incorrect jar files.
[also, perhaps it will help 5iver update his script for this not uncommon error, should it be applicable]
It can’t because it is not yet merged from the database to the zwave binding:
https://github.com/openhab/org.openhab.binding.zwave/tree/master/src/main/resources/ESH-INF/thing/inovelli
I finally made some time to test and push a new release that corrects the download URLs. The script had been downloading an ~800KB file that was not a jar. Unfortunately, the links in the README downloaded the same file. Some error checking should be put into the script for this sort of thing… should be easy to check if the files are jars.
Future updates…
  • Remove CI server URLs and use bintray for everything
  • Rework script to use bundle:update (which lets Karaf resolves the dependencies) instead of copying jars to /addons/
I just pushed another update that uses bintray for all downloads. This should help with some of the intermittent download errors experienced with the CI server.
You need me to test this later this week?
No, thank you… I’ve tested it for zwave and I’m sure I’ll hear about it if there is a problem!
I can confirm that the zwave binding is working, unfortunately the zigbee is not. I’ve tried 1.2.3, 1.2.5 and 1.2.6, all of them causing the logfile to fill up with errors…
Some of the logs:
2019-10-19 16:42:19.483 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/inbox/zigbee:coordinator_telegesis:0000000C/approve
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[82:org.eclipse.jetty.security:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
	... 15 more
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
	at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	... 15 more
Caused by: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
	at com.sun.proxy.$Proxy148.<clinit>(Unknown Source) ~[?:?]
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
	at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:?]
	at java.lang.reflect.Proxy.newProxyInstance(Proxy.java:739) ~[?:?]
	at org.eclipse.smarthome.core.internal.common.SafeCallerBuilderImpl.lambda$0(SafeCallerBuilderImpl.java:68) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.smarthome.core.internal.common.SafeCallerBuilderImpl.build(SafeCallerBuilderImpl.java:59) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.doInitializeHandler(ThingManagerImpl.java:770) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.initializeHandler(ThingManagerImpl.java:672) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.registerAndInitializeHandler(ThingManagerImpl.java:1074) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.thingAdded(ThingManagerImpl.java:457) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:209) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:129) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1) ~[?:?]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:154) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:1) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:56) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:74) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:78) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.add(AbstractManagedProvider.java:61) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.add(AbstractRegistry.java:322) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.addThingSafely(PersistentInbox.java:599) ~[?:?]
	at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.approve(PersistentInbox.java:172) ~[?:?]
	at org.eclipse.smarthome.io.rest.core.internal.discovery.InboxResource.approve(InboxResource.java:104) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
	... 15 more
Which version of OH? Using S1725, I just successfully installed Zigbee (w/ 1.2.5 libs), which I haven’t been able to do since the ESH reintegration.
OH 2.4, it installs ok according to the script, but doesn’t work and gives loads of errors. I wonder if the correct versions of all the dependencies are fetched? I use a Telegesis controller.
What errors? Please post some logs.
The binding is not controller dependent, by the way.
