ZRAM status
This article is to track and document the current status of the ZRAM feature in openHABian.
I’ll update it if there’s significant news.
What is ZRAM and how does it work ?
The ZRAM config utility for swap, directory & log is an OS enhancement for IoT / maker projects for reducing SD, NAND and eMMC block wear caused by write operations such as logging and persistence in openHAB. It uses compression to minimise precious memory footprint and extremely infrequent write outs and near RAM speed working dirs with memory compression ratios depending on your data and the compression algorithm you choose.
ZRAM is available as an install option in openHABian, use menu option 38 to install or the next (unnumbered) option to uninstall.
ZRAM uses a table in /etc/ztab where any combination and number of ZRAM drives can be created. This implementation uses an OverlayFS mount with ZRAM so that copying data from disk into RAM on boot is not needed. This should allow for quicker boots and larger directories as no complete directory copy is needed. It’s all the lower mount in the OverlayFS.
ZRAM is enabled per default for new openHABian installations.
In an openHABian implementation, swap, /var/log/* and /var/lib/openhab2/persistence are moved into ZRAM. All of that is expendable data, i.e. even if should things go badly wrong, your openHAB system should keep running. There’s a log in /usr/local/share/zram-config/log/.
We’ve changed this for new openHABian deployments. If you have been using ZRAM for /var/lib/openhab2, you can edit your /etc/ztab to make that change on your existing system, too. Requires to reboot after that.
OverlayFS and mounting
On proper service shutdown (zram-config stop or reboot/shutdown), zram’ed directories (OverlayFS) will be synced to the ‘lower’ filesystem (the same dirname on / filesystem located on default boot medium) and the ‘upper’ filesystem (the part in memory) will be lazily unmounted.
Lazy unmounting means there can still be processes to have open files on this directory. That’s required to run (and keep running) system processes using dirs such as e.g. /var/log.
DOs and DON’Ts
  • you must not switch off your openHABian server unless you have properly shut it down.
    This has been a requirement unrelated to ZRAM and essentially ever since UNIX exists. Also put it on an Uninterruptable Power Supply (UPS) to safeguard yourself against power outages.
  • don’t use zram-config sync (even if available in your installed version)
    This is known to not work in a number of situations and may cause data loss.
  • Make use of a backup solution such as Amanda to have daily backups of your zram’ed directories (and all the rest of your system, of course). ZRAM cannot protect against power outages or HW failures.
  • double-check your OH logging settings (log:get in openHAB console) and make sure it won’t generate more logs than you need. Check also their number and sizes: /var/lib/openhab/etc/log4j2.xml. The accumulated logs need to fit into that ZRAM directory as defined in /etc/ztab (and note there’s system logging to also go there, but by default it’s just a minor amount in comparison to OH logs).
  • you shouldn’t use ZRAM unless you’re on a SBC (small, “single board” computer such as Raspberry Pis) to run its OS off a flash memory based medium such as SD card or USB stick.
    USB sticks are no better or safer than internal SD cards ! - another good reason for ZRAM.
  • don’t run ZRAM on machines to have even less than 1GB of RAM such as a RPi Zero.
  • don’t run it on non-SBCs or modified SBCs to run off “safe” media such as SSD or HDD.
    Well you can do, but there’s just a negligible benefit in doing that so the cost/risk-to-benefit ratio is bad.
  • If (and only if) you have a SBC system with more than 1 GB such as a Raspi 4 with 2,4 or 8 GB or any other SBC with 2 GB or more, you may increase the amount of RAM assigned to ZRAM in /etc/ztab, starting with /var/lib/openhab2.
    Don’t worry ZRAM will not occupy that full maximum amount unless it really needs to.
  • you may change the list and size of directories to cache by changing entries in /etc/ztab .
    For example if you consider it to be too risky to run all of /var/lib/openhab2 off ZRAM because you want say the Karaf cache to not be on there (as it’s large and pretty much write-once only), you can put a comment sign in front of that line or replace it with 2 lines for /var/lib/openhab2/jsondb and …/persistence.
    But be aware that on the downside any such change will increase write load on your SD and thus the likelihood of getting hit by wearout.
    See GitHub - mstormi/openhabian-zram: zram extensions for openHABian for explanation on ztab fields.
  • there’s statistics available: run zramctl without options.
    For advanced stats, the file /sys/block/zram<id>/mm_stat has all the info you need.
    For the complete set of statistics see the kernel docs.
Known issues
You might run into a misbehavior. Please let me know when you do and let me know the relevant details, have you done anything latety which possibly was a trigger ? Edited a .items or .rules file ? Added a thing or binding that might come with a problem ? Changed openHAB version (incl. milestones, snapshot)?
You might run into errors about read-only files(ystem).
If so, issue zramctl and compare the TOTAL column of the ZRAM device for /var/lib/openhab2 (that usually is the 2nd line in the output with /dev/zram1).
If that value is greater or equal to what you have assigned to that share in /etc/ztab, even the compressed data just does not fit in. Assign more space. It’ll only be used by the system if there is a need See OH upgrade procedure.
  • after systemctl stop zram-config or /usr/local/bin/zram-config stop, a ZRAM device /dev/zramX might persist (X is a number). You can try removing it via zramctl -r /dev/zramX. If that fails, reboot to get rid of it. Eventually systemctl disable openhab2 before so it doesn’t start automatically after boot.
  • you might see permission denied messages saying the system cannot write to disk into either of these directories or files below because they’re read-only.
    This has not been reported by users but occasionally showed up during testing. There’s a lot of potential reasons for this and it is still subject to investigation as to what’s the most likely/most frequent reason to cause this.
    ZRAM does never sync to disk unless you stop it (doing so syncs every file that changed into and then unmounts the ZRAM directories). On next start, it’ll not copy these to RAM again so little RAM usage.
Just like on disk, the amount of RAM that ZRAM needs to have available must be larger than the amount of data to store in there but it’s a little more complicated than that because the data also is compressed with a varying compression factor so the exact amount of raw data to fit in is unknown. The amount of memory ZRAM has available is static (defined in /etc/ztab).
Now if something happens to write more changed data to zram’ed directories than there fits into, ‘permission denied’ is (most often) how the system protects itself against even more severe impacts.
You can try deleting zram’ed data but usually you would need to (and the safer method clearly is to) shutdown your system.
@mstormi Markus,
My system with zram is misbehaving. I suspect I have corrupted the zram configuration. I tried to re-install zram using openhabian-config but it can no longer find you zram repository in gitHub. Does this mean that this BETA trial is not moving forward at this time? If your repository is no longer available, should the openhabian-config entry be deleted as well?
I have disabled zram (systemctl disable zram-config) for now. Is there anything I need to do to remove the directories/mounts? Any other cleanup?
At this point, utilities cannot seem to be able to write any logs. I have run the “fix permissions” entry in openhabian-config. I’ve had to disable logging for mosquitto for it to function properly. Something is seriously hosed and I need to resolve it. Any guidance is greatly appreciated.
Regards.
Mike
No. I’m waiting for the original author to transfer his repo, he’s slow to answer unfortunately. Meanwhile you can install from his, see this thread.
You might also be able to fix your install, unless you deleted binaries or directories I believe all you need to do is fix /etc/ztab (if you changed it), re-enable and reboot. The original is at /opt/openhabian/includes/ztab. I’d suggest to increase disksize for /var/lib/openhab2 to 600+MB while you’re at it.
No, you need to stop and eventually reboot. See if df and zramctl show any remainders.
Anything else I’m afraid likely is no zram issue.
Thanks Markus. I’ll make note of that thread for future reference.
I have decided to revisit ZRAM at a later date. Right now the Chromecast binding (and others) are in conflict with the REST Docs (Jackson library incompatibility). I am planning to migrate to MQTT2 and leveraging the REST Docs to clone my Things more easily (than hundreds of PaperUI clicks). All this to say that I’ll revisit ZRAM when I revisit MQTT2 (hopefully M4 resolves the Jackson library issues).
Mike
P.S.
I’m not sure what happened with Mosquitto. I had to uninstall it and reinstall it to resolve the issue. My openHAB deployment is stable again… I hope :wink:
Sorry for maybe asking a dumb question, but I have a hard time trying to get Z-RAM to work an Obenhabian. I just updated the config tool (openhabian-config) and tried again (like many weeks before already) to activate Z-RAM support but unfortunately with the same error:
grafik
Am I missing something or are you all still waiting for an update? Thank you very much for any advice or pointing me in the right direction!
I’m waiting for this PR to get merged. You can apply it yourself to make this work (essentially just replace the repo name “zram-config” in /opt/openhabian/functions/zram.bash by “openhabian-zram”).
Thank you very much, works like a charm, excellent!
By the way, what takes 27(!) days to get a PR merged? I am just wondering why all users still need to suffer just because no one approves a PR which already is 4 weeks old???
It’s merged now so you should be able to use openhabian-config now to install ZRAM.
I use the latest openhabian image together with an RPI4 4GB. How is the proper way to shutdown? Only shutdown -r? I use the PiJuice UPS to proper shutdown. The internal scripts are sending SYS_FUNC_HALT and Power Off completelly one minute later. Is it safe to use this script so that all ZRAM content is synched to the SD-Card? Also I use often sudo reboot to restart the RPI. Is this also not allowed anymore?
I hope somebody can describe the best way to do an proper shutdown and reboot a little bit more in detail.
best regards René
RTFP
Yes the full one. I don’t write essays because I like to write.
To properly power off the RPi you should use sudo shutdown -h (halt the system) instead of sudo shutdown -r (reboot the system).
@mstormi
Just some follow up questions in a proper thread:
  • Does this has been tested on RPI 4?
  • Are there any downside of using ZRAM? Like using more CPU or anything like this…
It works in openHABian 1.5 which is buster based. The Pi model does not make a difference.
Read the post #1
I’ve started to play with this some more. It seems to be stable enough to rely upon on a remote machine.
It is probably worth mentioning that if you use openhab-cli backup, you will want to move the zip files out of /var/lib/openhab2/backups. There’s no reason to have these files loaded into zram.
Great, thanks. An upcoming openHABian PR will unmark it from being beta. No not exclusively because of this statement of yours, but thanks nevertheless.
Right. @benjy could you please take care of that ?
Dunno which repo openhab-cli belongs to else would have filed an issue there.
I already implemented a similar thing with openHAB log files:
In essence, you’ll need to schedule a cron job to relocate the backup files to another location outside the control of ZRAM, e.g. somewhere in /home/openhabian).
openhab-cli provides the shortcut for the distro’s backup script, (which has a default directory of ${OPENHAB_USERDATA}/backups). But that’s only if a path isn’t specified.
You can also change the default directory by setting ${OPENHAB_BACKUPS} in the /etc/defaults/openhab2 file. I’d reccomend doing this during the zram setup stage and notifying the user of the change.
@mstormi, does zram sync after an apt update changes the contents of the /var/lib/openhab2 directory? I’m not entirely convinced that the whole folder should be included.
Well changes are active but not synced to disk/SD. No you cannot force syncs with the fs online so it’s just “virtual” changes until you shutdown (w/ sync).
I agree we could spend some more thoughts on what to include and what not, but note it’s not possible to exclude subdirs if the upper dir is included so that sort of forces some bundling we eventually wouldn’t want to have.
I think the safest approach would be to check if zram is active and temporarily disable it during the openHAB upgrade process.
